Question about Hitachi CP-S225 Multimedia Projector
Is it possible to view "free to air" programs being broadcast via a normal tv set, on the Hitachi CPS 225 or can it only be viewed via a VHS or DVD recording
  • tomofwarwick May 31, 2009
    Yes it was helpful, Thank you.
    Scholar:
  • 148 Answers
YES IT IS POSSIBLE WITH THE FOLLOWING SPECIFICATIONS..IT IS..
Data Signals: VGA, S-VGA, XGA ( COMPRESSED ), PC and Macintosh computers
Video Signals: NTSC, NTSC 4.43, PAL, M-PAL, N-PAL, PAL60, SECAM, S-Video, HDTV ( 480i, 625i, 480p, 1080i, 720p )
Input: Computer RGB: D-sub 15-pin shrink terminal x 1
S-Video: Min DIN 4-pin terminal x 1
Composite Video: RCA jack terminal x 1
Component Video: RCA jack Y, Cb, Cr / Y, Pb, Pr
Audio: Mini jack x 2
Control terminal: D-sub 15-pins shrink
Posted on May 31, 2009
Cannot record externally from Humax bt you View box onto Toshiba RDXV60KB ( HDD & DVD modes). As I previously could? I am getting message E26 " Cannot record from this program". But the Tos
This error e26 gets thrown up on some digital rights management programs.this really just means you are not allowed to record...ever increasingly thanks to the big corps like sony drm carrier signals are put into some broadcasts to overcome copying infringements.there still is a way to do this with the right equipment.some tv channels get revenue from their advert counts so they put these signals in to ensure that you can only watch at broadcast or catchup on certain devices.what I can't figure out is I can record anything whilst it's being aired and still transfer to older equipment but not anything with latest ios and certainly not with sony recorders.
Jan 26, 2015 | Toshiba RDXV60KB DVD HDD VHS Recorder
Is this tv hd ready?
Yes, it should be HD ready. There should be a small label on the front of the TV if so (provided it has not been removed). You will need a HD cable box, convertor or HD satellite box (Direct TV or Dish Network) to view HD broadcasts (even from free over-the-air HD broadcasts if you live within range of a local broadcasting station). I had the same, or very similar TV but upgraded to flat screen plasma set.
Aug 14, 2012 | Hitachi 53SBX01B 53" Rear Projection...
Can record on DVD disc will not play on DVD player
Make sure the materials you're trying to record onto the DVD
is not Copyrighted. Try to record a normal TV program onto your
VHS, transfer it to your DVD and then play it. See if that will
work. A VHS movie is usually Copyrighted and Protected by
Macrovision. The picture output can be displayed on a TV set
for viewing but is scrambled black to a DVD Recorder.
Jul 16, 2011 | JVC DR-MV100B DVD Recorder/VCR
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Jan 03, 2009 | Daewoo DVRS04 DVD Recorder/VCR
No video output when played on vhs
try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
ps : check if you have to switch between tv and vcr via remote , and when you insert the vhs tape you are able to rew and frw and press play normally...if these are ok usually its a little dirt onthe cylender head....hope this helps...
Jan 01, 2009 | Panasonic DMR-E75V DVD Player/VCR
How to view and download the recordings
You need to purchase a device that converts analog video to digital. It looks like a little box (or cable) with video and audio inputs on one side and a USB or firewire connector on the other. There are lots of choices and prices depending on whether you want to edit the video or just view it on your computer.
By the way, don't be confused by those set top boxes that convert Digital TV signals to your old TV because of the February change in broadcast standards. That's completely a different issue.
Dec 31, 2008 | Panasonic NV-VZ18 Camcorder
No audio output available
if you want sound from normal digital tv you could try connecting audio jacks straight from the free view box. if you got a dvd player it will run sound through your free view also. your basicaly then just using your tv as a monitor and can turn the sound off altogether from your tv
Dec 18, 2008 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
PIP trouble
Hitachi Tricked consumers into beleiving that true PIP was possible
It's not,you can only use any 1 source( dvd vhs ) and A cable signal via the co ax input (hence the term AIR)
Sep 25, 2007 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi CP-S225 Multimedia Projector Logo
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
