thanks for information dear SWAN 34 but i dont know how to check weather my IR-2000 have duplex unit or now, could you tell me how to check?
Regards
Re: how to make automatic duble sided copy on IR-2000
These machines have a duplex unit all machines this size does, now a duplex unit is where the paper double sides in the machine, like doing a double sided copy.
i know off some people think that a duplex unit is the DADF (document feeder).
Mam/Sir,
Did you match the proper paper with the machine paper weight on print driver must match the draw and the paper weight on the paper package such as Thick 1, 2, 3 and the weight on the paper package g/m2. use copier spec page to determine Thickness. also try running it though once for one side then second time requires no duplex re-running a second time from same draw. But a tech coming out to look at the machine might know if you have a registration problem on double side copies, he might also have a firmware update he can install the correct the problem.
I would suggest you check the manual of the kyocera 1815 copier. this should be stated clearly on the user manual. so check the user manual for the information as regards this.
sorry but you haven`t duplex on your machine. you need to buy dublex unit or you can print on one side end insert the paper again and print on the other side.
