Question about Microsoft Computers & Internet
When I starnt my pc all programmas which is run suddenly stopped,
How can I remove virus for from RAM?
  • ultimitloozr May 11, 2010
    Do you already have an antivirus product installed on your computer? If so, which one?
    Brigadier General:
  • 10,406 Answers
According to the manager of Security Programs at Microsoft, there is _NO_ way to completely "remove" a computer-virus -- you just don't know "where" the virus has planted itself, and what other "settings" it may have changed.
So, backup your data (to CD/DVD-writable or to USB-memory-stick), and reinstall Windows, choosing to "format" the disk-drive, and then run Windows Update to get all the required security updates. Install an anti-virus solution, and restore your data.
Posted on May 31, 2009
Toshiba laptop won't power ON
Did you run a bios updateand has an anti virus programme installed? If you did the bios is corrupt and stopping the system from running.
I would remove the RAM and Hard drive. Power up without the battery and look for error messages on the screen. Ensure the RAM is correct and place one strip in at a time.
Nov 25, 2013 | Toshiba Satellite C655-s5090
Tip
Sign of a Virus Infected PC and How to Fix it
A computer virus is something that often interfere with your daily activities. Computer viruses usually spread unbeknownst to us, from one computer to another. One of media dissemination of computer viruses is via e-mail. After you run the attachment in an e-mail so sometimes you still do not realize that you're running is a computer virus.
What are the signs or indicators of computer viruses in your computer? Please just look at some of the following signs.
  • Your computer runs slower than usual and lasted consistently.
  • Computer suddenly stopped or not responding and it is often the case.
  • Computer suddenly restarts or crashes and this happened a few minutes.
  • Computer suddenly restart and could not walk normally again.
  • Computer application is not running properly.
  • Hard drive or disk drive is inaccessible.
  • Print activity is not working properly.
  • It often happens that strange error messages and do not usually.
  • Often visible menu or dialog box that is damaged.
The above is a common symptom that a computer infected by computer virus, but it can also occur due to interference with the hardware or software as well. The main solution is to install antivirus software that is always up-to-date.
Tips how to remove a virus that can not be handled Anti-virus
There is a very powerful tips to remove the virus, if the various Anti Virus that we use entirely powerless against it (probably only detect, but can not delete it). To do this would require a Bootable CD that contains a minimum of the File Manager program, such as Ultimate Boot CD, BartPE, and the like. Some programs are DOS-based and others are windows based. Or we could use a Linux Live CD, like Knoppix, Ubuntu Live CD and others. In General, the following steps:
  1. Find the location of the virus, especially the origin of the virus is running on your computer (the host)
  2. Once obtained, note (note) information such as file size, date (although the virus can change the size and date, but most always the same size and date. Can find similar files and recorded their location.
  3. Once obtained, use one of the Bootable CD and restart the computer to boot from a CD (you might need his first set its BIOS to first boot the CD / DVD-ROM).
  4. Open the file manager program, which is available. If using windows NT, XP or above, make sure the program supports reading NTFS format
  5. Find the file / virus and delete or if still in doubt, just rename from *. exe to *. VRS example. To convince, use the search facility to find files with the same size or nearly the same date. If found , you can rename it.
  6. Back restart the computer and check again
on Apr 17, 2010 | Computers & Internet
Extremely slow running
Slow computer If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. After scanning is completed then the computer will be faster.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Mar 29, 2013 | eMachines T5274 Desktop PC
Suddenly stopped working ,won't restart my PC?
First of all disconnect all peropheral connected to your motherboard. Take out Your RAM and clean it with soft clothe. Reinsert ram and restart your PC. If you can get display at this point then shut down your PC connect all peripheral back and restart your PC.
If not you will need to replace your ram.
Nov 29, 2012 | Computers & Internet
Running very slow
have you run a virus scan? run your anti virus software... have you done a defragment? go to my computer, right click on C drive..properties/ tool tab/ defrag button....have you downloaded any software that is taking up a lot ram (maybe you need to add more RAM you can go up to 1 gig (pc-2100 is the speed of ram) ) ? or you might want to stop some programs that start up automatic that is not being used.
Nov 28, 2010 | Compaq Presario s4020wm (DK214AR#ABA) PC...
My laptop has problem when I turn it on then it suddenly shut down so what is the problem? that's the big problem.
Sounds like it could be a RAM problem. If you have more than one RAM chip in your computer remove one and try the computer again. If it works then either the RAM chip that you removed has failed or the RAM slot it goes is has. Shut down the computer and take the working RAM chip and place in the empty slot to see if the computer boots up. This will tell you then if it's the chip or the slot. If the computer doesn't boot up, just to make sure it's the RAM slot, take the other piece of RAM and place in the other slot and try to boot up the computer.
Aug 19, 2010 | Computers & Internet
Computer suddenly shut down and won't restart
This type of shutdown problem occurs mainly due to following few reasons, 1) SMPS problem 2) RAM failure 3) Over heated mother board chip(s) or seldom over heated CPU 4) Virus or worm problem or OS problem. 5) Over heated power cords
Do the following steps one by one (to detect the exact source of problem) First replace the CMOS battery, change SMPS, check power cord, run the PC directly (without UPS), remove the data cable from hdd. if it runs well then set the data cable with hdd, if it does not work then definitely there is mother board/cpu problem. And if it creates same problem after fitting the data cable - change the hdd or format hdd and reinstall os. your problem would be solved.
Jun 05, 2010 | Gateway GT5465E Refurbished Intel Desktop...
It all of a sudden shuts down
for your suddenly shut down there might be a virus in your motherboard ''Brontoc'' or ''foooool''
they might harm your motherboard install the anti-virus you trust ''best use avg free 8.5.87,download from www.filehippo.com''
second for your ram you can increase them as much as you want so you can reach your limit to 4GB RAM
i wish this helped you
Apr 11, 2009 | HP Pavilion dv4000 Notebook
My computer has a virus I can't remove
Try and boot into windows safe mode by pressing the F8 key before windows loads and then try running the browser and check if it crashes. Perform the same process by scanning with an anti virus and see what happens. You might have two problems, either the RAM the actual memory is bust or something in the OS has gone really wrong and got the OS unstable. Try the safe mode test to confirm.
Feb 24, 2009 | Fujitsu LifeBook T4215 (FPCM10951) PC...
Free virus removal from Dell PC
you can try avast at:
http://www.avast.com/eng/avast_4_home.html
or
malwarebytes at:
http://www.malwarebytes.org/
both softwares are good and free.
the memory of the system will depend on the capacity of the RAM installed on the system. you can either upgrade the memory (RAM) or stop applications from running at start-up
Oct 26, 2008 | Dell Dimension 4700 PC Desktop
Computers & Internet Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
