Question about Euro-Pro 473
Needle will not pick up bobbin threat
My Euro-Pro Shark 473 was bunching the thread under the fabric when sewing and also wrapping the thread around the shuttle driver. The Euro-Pro website states that the upper thread is probably threaded wrong, but I followed the instructions verbatim and had sewed one seam on the fabric with no problem, but when I tried to sew the next seam, this occurred. I removed the shuttle driver cleared the thread that was around it and replaced the bobbin, but now the needle is not picking up the bobbin thread. The website states that for that problem, a technician should check it out since the timing was probably forced (whatever that means). I paid less than $100 for the machine and haven't used it more than three times in the past two years. I hate to incur an expense like this after such short usage. Has anyone dealt with this problem before and fixed it on their own? same here, after changing the bottom case, it won't pick u pthe thread !
    President:
  • 2,976 Answers
Try flipping the bobbin spool so the thread comes off in the other direction.
Forcing means that the needle has been jammed against the sewing plate ant the needle is now out of timing with the bobbin pickup.
Posted on May 31, 2009
  • iplyball Oct 16, 2010
    so how would you fix the problem or do we need to find someone to repair
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Oct 02, 2016 | Euro-Pro Sewing Machines
Shark Euro Pro 473: The needle won't go up and down when I press the pedal. Power is on, light too and machine running but no action. Any suggestions other than rethreading everything? Thanks!
Is the bobbin winder engaged? The smaller handle inside the balance wheel, the large handle. If the bobbin winder is engaged the thread will only wind around the bobbin and the needle does not move.
May 29, 2015 | Sewing Machines
My needle is not picking up my bobbin thread. How can I correct this issue?
Could be you are using the wrong needle. If it is too short it will not pick up the bobbin thread. Or your machine could be out of time.
Oct 20, 2014 | Euro-Pro Shark 9110 Sewing Machine
Hello, I have a Shark euro-pro sewing machine. I am sewing denim on denim using singer needles that were suggested for denim. The numbers on the package are 2020 110/18 808 R 130/705H 05 un I...
The size of needle is fine for sewing on denim so unless the needle is bent (and even so) I doubt that is the problem. Breaking upper thread typically has more to do with the threading, ie wrapped around some place along the way or misthreaded somehow, of even if you somehow got knots or that it has somehow got thread around the spindle for the spool. So first recheck the threading. Best to do by simply totally unthreading it, looking closely at the spool and winding and then rethreading it again. Make sure your upper tension hasn't been accidentally tightened too.
Next check the bobbin and bobbin thread. First pull on the thread. Is it pulling real tightly or does it flow out readily? Take the bobbin out and look at it. Check the tension also. Is it too tight? That too can cause the upper thread to break.
Is the needle penitrating the material smoothly? Again examine the needle closely to see if it's developed a burr. Better yet just swap the needle with a new needle and try it.
The majority of the time it is one of these things that will cause the top thread to break.
May 18, 2011 | Euro-Pro Shark 80 - 7133
I have a euro- pro model 385x. Every time I try to sew, the needle jams and the bobbin is surrounded by thread. I have tried loosening the bobbin as well as tightening it but to no avail. I get a big...
The problem is likely the threading. Double check the threading, look twice or three times at the diagram. Even me, a tech sometimes threads a machine or serger wrong.
Derek
Jan 17, 2011 | Euro-Pro 473
I can't get the bottom thread to come up with the needle on my euro-pro shark intelli-sew
try this
make sure there is a 3-5 inch tail on bobbin thread
make sure there is a 3-5 inch tail on top thread, then hold the top thread tail with your fingers (away from the needle) & with your other hand turn the hand wheel manually on the right side of the sewing machine,, slowly letting down the needle down into the bobbin area & see if the bobbin thread will pick up this way
Sep 25, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Upper Thread will not pick up Bobbin Thread
Make sure the needle is installed according to the manual.
Thread the machine with the presser foot up.
Refer to the manual to make sure the bobbin thread is feeding from the bobbin correctly and though the guides.
Hold on to the end of the top thread, lower and raise the needle to bring up the bobbin thread.
Take both threads under the presser foot and to the back of the machine.
Test the stitching on a scrap of fabric and if the machine is still not forming a stitch, the machine may need the timing adjusted by a service tech.
Mar 12, 2010 | Euro-Pro Shark 80 - 7133
Janome Sew Mini bobbin problem
Hi, Usually wrap-ups in the bobbin area are caused by the lack of tension on the top thread. The slack arm ( shinny lever that moves up and down while sewing) has to pull the loop around the bobbin case and it does so only if the tension on the top thread is sufficient to keep it from pulling more thread of the spool.
Try this: Thread the top of the machine all the way just short of the needle eye. When the presser foot is up the thread should pull through easily. Now drop the presser foot (this closes the tension discs) and pull the tread while adjusting the upper tension control.
If everything is working correctly you should feel the drag on the thread change if not something is keeping the discs from closing.
Most Janomes aren't too difficult to remove the nose cover, usually just one screw and you can get a look at the thread path. Look for thread wrapped around the mechanism.
Sorry, no easy answer but I hope this helps.
Mar 16, 2017 | Janome Sewing Machines
I had the exact same problem. The timing is off. You can actually fix this yourself all you need is an allen wrench. If you look at the rod the needle is inserted into and follow it up to about 2 inches below the top of the machine there should be a clamp. use the allan wrench to loosen the clamp and adjust the needle height. I used this website as a guide to getting the timing correct. http://www.sewusa.com/Sewing_Machine_Repair/Repair_Pictures/timing1.gif
now if only I could figure out why my thread keeps getting jammed under the bobbin!
Feb 02, 2008 | Euro-Pro 473
Euro-Pro 473 Logo
470 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
