Question about Samsung L100 Digital Camera
Pushed the Format button on my L100 Samsung Digital camera and my memory card was erased??? Please explain this?
I pushed the Format button on my L100 Samsung Digital camera and my memory card was erased??? Please explain this?
  • 56 Answers
Formatting the memory card automatically erases all the files in the memory card.
it's like restoring the memory card to factory settings to be compatible with your camera.
when you format the memory card using the camera the camera erases everything then creates folders that the camera needs to store pictures in your memory card.
you can try to look for software that can TRY to retrieve the images but i cannot assure you that this will work
Posted on Jul 02, 2009
  • chris garcia Jul 03, 2009
    When you format a memory card it does two things.
    1) It erases all its information
    2) It now puts in folders needed for use on a certain device
    It is like rebooting your memory card in a way to be compatible with your unit by creating ROOT folders that your device needs
    hope this answer your question
    Genius:
  • 1,234 Answers
Hii
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    2 Suggested Answers
    • 66 Answers
    SOURCE: Format button deleted my memory card???
    Format will wipe clean your memory-card like new - Always.
    so normally avoid that button.
    if you lost some photos using the format then there maybe some chance to get them back.
    take out the card and put it in external card reader.
    Now get hold of some file recovery software like 'GetDataBack for FAT32' (buy/borrow/steal :) ) install it on your computer, GetDataBack should be able to pull back the data.
    Let me know if any more clarifications needed.
    Posted on May 31, 2009
    I have a samsung l100 cam.but my cusine destry the lens.so what can i do please say..........................
    Hi there please follow the steps and let me know the result.
    1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
    2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
    3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
    4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
    5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
    i hope it will gives you success.
    Jan 25, 2011 | Samsung L100 Digital Camera
    How do you erase all of the stored pics on the sd card at once?
    Use the Format command to quickly delete all images from the memory card. This will also prevent fragmenting of the memory - which can significantly slow the transfer of images to your computer - and increase the amount of time it takes to save a picture after pressing the shutter button.
    To format a card on in your camera, at the main menu choose "Settings" then select "Format".
    I hope this helped!
    Oct 22, 2010 | Samsung L100 Digital Camera
    How do I erase all of the photos on the memory stick?
    The best way to erase all photos on the memory card is to format it. This should be done every time you finish downloading your pictures to your computer, to prevent the card from getting fragmented.
    To format a card on the L100, from the main menu select Settings (the gear and wrench icon). From there select Format.
    Jun 22, 2010 | Samsung L100 Digital Camera
    Memory card error?
    Hi, Check if other memory card is working on your camera. This is one way of checking if your memory card if still working or there is an issue wither the camera. Formatting Memory card **you should always format a new memory card or one from which you wish to erase all images and other data. ** Please note that formatting a memory card erases all data, including protected images and other file types. 1. (Set up) Menu [Format]
    2. Select [OK] and press FUNC SET button.
    Low Level format, recommended by cannon
    Select the [Low Level Format] when you think that the recording/reading speed of a memory card has dropped. A low level format may require 2 to 3 minutes with some memory cards.
    Apr 12, 2010 | Canon PowerShot A610 Digital Camera
    I have a Nikon L100 and lost my manual. I can't
    format the memory cards after you back it up. if that doesn't work, try another brand.
    Nov 19, 2009 | Nikon COOLPIX L100 Digital Camera
    Samsung l100 digital camera. Pressed menu, then "format" in settings. Why did all my photos disappear??
    Format completely erases the card and optimizes it to take more pictures. Why did you press it?
    Oct 24, 2009 | Samsung L100 Digital Camera
    May 31, 2009 | Samsung L100 Digital Camera
    Card error on L100 samsung camera, help please.
    copy all the pictures/files saved in your memory card to your PC then format the card, you can format the card by going to MENU > SET UP > FORMAT
    make sure that you have a copy of the files in the memory card because formatting the memory card will erase all the files that are saved in it.
    Mar 04, 2009 | Samsung L100 Digital Camera
    SAmsung L100
    take out the memory card look for a lock tab at the side of it, push it up and insert the memory card back. that should do it
    card lock is a feature of the memory card so that you won't accidentally erase the files that are saved in it
    hope this helps
    Feb 01, 2009 | Samsung L100 Digital Camera
    Formatting memory stick.
    You can use the MEMORY FORMAT functions to completely delete all images and options on the Memory Card, including protected images. * The format function restores the Memory Card to its initial state. * The Memory Card supplied with this camcorder has been formatted already. Attention If you execute the MEMORY FORMAT function, all images will be erased completely and erased images cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The sub menu will appear. 5. Select FORMAT from the list and press the ENTER button. 6. "ALL FILES ARE DELETED! FORMAT REALLY?" appears on the screen. 7. Using the MENU DIAL, select the item. NO : To return to previous menu YES : To start formatting. 8. Press the ENTER button. If you selected the YES, COMPLETE! appears on the screen when the MEMORY CARD formatting is finished. 9. To exit the menu, push the MENU button.
    Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
    Samsung L100 Digital Camera Logo
    188 people viewed this question
    Top Samsung Cameras Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Computer Links
    Are you a Samsung Camera Expert? Answer questions, earn points and help others
