Question about Dell Inspiron 6400 Notebook
Manufacturer setting for startup
Hii,
how do i recover original start up settings by the manufacturer
  • Madhava Rao May 11, 2010
    Let me know, if you are trying to reinstall every thing on the comp by reinstalling everything on the computer to day one. is your operating system xp or vista.. Doing this you will loose all the data on the hard drive..
  • 3,940 Answers
You system's factory Image included a PC Restore Partition. Provided that hasn't been damaged, you may still be able to re-image you system to the way it was out of the box using PC Restore. NOTE ALL data you have added to the system will be lost forever.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?journalid=6B4B1614FBFE9BCCE040AE0AB6E12360&docid=336966
Posted on Jun 01, 2009
How to restore factory setting on gateway model mt6705
Step 1:
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate. Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files. It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen Click the "Start" icon in the lower-left corner of your Windows 7 home screen. Click "All Programs" in the Start menu, then click "Gateway". Click "Gateway Recovery Management" to open the Gateway Recovery Management program. Click the "Restore" header, then click "Restore System To Factory Default". Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes". Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart. When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes. Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer. Your computer will reboot. After the computer restarts you will need to configure Windows 7 with your personal preferences. b> Recover at Startup Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program. Click "Restore System From Factory Default". Click "Next" to begin the restoration process. The process could take anywhere between 30 and 90 minutes.
Feb 25, 2013 | Gateway MT6705 Notebook
Tip
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM In the next few posts i will...
In the next few posts i will post some tricks to make your phone faster and also recover precious RAM.
1. MOVE HELP FILES TO MEMORY CARD
If you are running low on phone memory and have a lot of apps installed, you can recover a part of it by transferring help files to the memory card.
Enable CAPS OFF
open Xplore or fxplorer and move C/resource/help to E/resource/help.
All the apps will find it automatically in the E drive.
This trick will increase your phone memory thereby making your phone a little bit faster.
2. DISABLE LIFEBLOG PERMANENTLY
first use jbak taskman to kill lifeblogobserver process
make sure x-plorer is set to show hidden files
then go to c/data/lifeblog/database
now delete the lifeblog.dbfile
reboot phone
now use jbak taskman to kill lifeblogobserverprocess once again!
select llifeblog.db file and press 6 tick hidden and read-only reboot phone. You'll notice the phone's boot up is faster and it will also release some RAM.
if you want to use lifeblog again go toc/data/lifeblog/database
and untick hidden and read-only
3. STOP AUTO STARTUP OF APPS ( for a faster boot up)
You can disable the third party applications to boot at start . These applications boot at startup and slow down the phone,s startup. In order to stop them to boot them use the following process.
The info of all the start up apps is stored in c:\private\100059c9\start.dat
whenever you allow any application to start automatically at startup the file start.dat is updated. The simplest method to disable the apps to load at boot up is to simply rename the start.dat file i renamed it to start.dat.txt. After renaming it your phone will boot as it boots after a fresh formating.
When ever you again want to enable the startup apps just remove the .txt extension.
You can also edit start.dat file to enable some applications to boot at start up and disabiling others but i don,t know how to edit .dat file. But you can edit it if you know how to edit it.
The easiest method of editing the .dat file is to delete the old start.dat file and then go to the applications which you want to boot at start up and rechange their setting ie (enable auto start=yes). A new .dat file will be created automatically which will only boot those apps which you want.
You can even further boost up your phone start up by renaming files like
C:\private\100012a5\DBS_101F99FB_NSmlDSSettings.db
C:\private\100012a5\DBS_101F99FB_nsmlagentlog.db
C:\private\100012a5\DBS_101F99FB_NSmlDMsettings.db
C:\private\100012a5\DBS_101F99FE_NSml_Adapterlog.d b
C:\private\100012a5\DBS_101F99FE\NSml_adapterlog?? ?.dat
C:\private\101F99FD\nsmladapterlog???.dat
C:\private\101f9a06\nsmldmtree.db
C:\private\100056cf\clockapp.dat
C:\private\100059a8\nitz.dat
C:\private\100012a5\DBS_101F9A02_nsmldmfotaadapter .db
C:\private\100012A5\101f8683_ScShortcutEngine.db
C:\private\1000850\logo*.*
C:\private\100012a5\DBS_10205030_accpolicydb.db
C:\private\1000c959\localdata\commondata.D???
C:\private\1000c959\localdata\localdata.D???
To .txt files or simply delete them.
Deleting all these files is the other name of restoring your phone to factory setting without losing any application data. Deleting these files also deletes sim data mean the network data of all the sims used in a phone. When you will rename all these files your all phone setting will be lost like clock time ,month date year. When you will again set different settings like adjust the ,adjust the date duplicate files of all the files you renamed or deleted will be created mean fresh data files .to again gainyour original setting as they were before applying the hack just delete all the duplicate files and rename all the above files as they were before renaming and restart your phone all your setting will be restored.
on May 09, 2010 | Cell Phones
GATEWAY WINDOWS 7 FACTORY
Feb 15, 2013 | Gateway LT2021u Netbook
I was told I need a recovery disk I do not have no programs no start menu , I do not know what to do, the computer was given to me and it has nothing in it
Recovery disk, is a disk from your computer manufacturer it is to recover the computer to manufacture settings.
You may visit this HP help and support site http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703#RecoverOS
then click on the link Restore the PC to its original condition with the HP Recovery Manager from within Windows Vista
or you may check "Three ways to recover the PC to the original operating condition"
May 07, 2011 | HP Hewlett Packard Pavilion Slimline...
There is no sound or audio device
Try to 'restore' to an earlier date when the audio device worked, or 'recover' to original manufacturer settings and 'update' to present windows settings.
Are you using Windows 7, Vista, or XP?
Feb 10, 2011 | Compaq Computers & Internet
How do I recover to original factory setting on my computer
Hi.
If you never deleted the recovery partition (hidden on most computers) you can enter recovery mode at startup. When you power on your computer, hit ALT F10 continuously until you enter the recovery menu. You should be able to restore to factory defaults by this procedure.
Feb 08, 2011 | Acer Aspire 4315 Notebook
How do I reconfigure, or restore to original settings?
Contact your Computer Manufacturer and ask them to send you a set of Vista Recovery disk/s.
They normally do that for a small $ cost.
Also, ask them if you have a Recovery Partition on your Computer/Laptop to restore it to Factory settings.
See if a Manual came with the computer, or go to the Manufacturer's website, email or phone them for info on how to do a Recovery.
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
They will tell you how to do that.
Each Computer Manufacturer has their own way of making Recovery Disk/s.
Dec 19, 2010 | Computers & Internet
HP dv6000 turion processor. machine starts and all blue lights appear. dvd briefly lights and then machine turns off and then turns itself back on and repeats the process.
Preforming a system recovery to return the computer to its original condition may be necessary if the operating system is damaged, or the hard drive is corrupted, or the computer is infected by a virus.
___Also look this> HP expanded the battery pack recall on May 19, 2010. Click here to validate your battery. Performing a system recovery removes all software and files saved to the hard drive, reinstalls the original operating system, and then configures the settings for the default programs. Since the merger of Compaq and HP, several different recovery tools and processes Names for these tools include: Recovery Solution, Recovery Manager, F11, Recovery Disc, Driver and Application Recovery Disc, Roxio BackOntrack, Microsoft Backup & Restore. have been provided for recovering notebook PCs to their original operating condition. To help you select the correct recovery process, the table below identifies the different models, the time frame when they were produced and sold, plus the originally configured operating systems. Click on the name of the document in the right column for detailed information. Choose the Correct Recovery Process for Your Notebook Notebook description Recovery procedure information HP and Compaq Notebook PCs and Mini PCs shipped with a Windows 7 operating system. Recover Windows 7 Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Windows 7 instead of an HP solution. Recover Windows 7 Operating System Using Microsoft Windows Backup and Restore Presario, Pavilion, and HP Compaq Business PCs shipped with a Windows Vista operating system. Recover Windows Vista Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Vista instead of an HP solution. Recover Windows Vista Operating System Using Microsoft Windows Backup and Restore HP and Compaq Mini with Windows XP using the HP solution. Recover Windows XP Operating System On Mini Notebook Using HP Recovery HP and Compaq Mini with Windows XP using the Roxio recovery feature instead of the HP solution. Recover Windows XP Operating System Using Roxio BackOn Track HP and Compaq Mini with Mobile Internet Environment (MIE ). Recover Windows MIE Operating System On Mini Notebook Using HP Recovery Presario, Pavilion, and HP Compaq Business PCs manufactured and sold in 2006 or later . Recover Windows XP Operating System Using HP Recovery (2006 or Later)
Presario and Pavilion PCs manufactured from 2001 and 2005 . Recover Windows XP Operating System Using XP Operating System Discs (2001 to 2005)
And
Recover Applications Using Drivers and Applications Recovery Disc (2001 to 2005) Pavilion PCs with Windows Media Center edition of XP manufactured from 2001 to 2005 . Recover Windows XP Media Center Edition Operating System on HP Pavilion PCs Using HP Recovery (2001 to 2005) Compaq Presario PCs supplied with a Compaq Recovery CD and manufactured from 2001 to 2005 . Recover Windows XP Operating System on Compaq Presario PCs Using HP Recovery (2001 to 2005) Omnibook and certain Pavilion PCs manufactured pre-2001 . Recover Windows XP Operating System and Applications on HP Omnibook and Pavilion models Using HP Recovery (Pre 2001)
Nov 13, 2010 | HP Pavilion dv6000z Notebook
BOOTING PROBLEM
Hii, Go to the BIOS setting by pressing DEL at the system startup and then set it Default and then save setting.
Feb 22, 2009 | Gigabyte Computers & Internet
Windows recovert cd
For Lenovo there is a Recover and rescue button just hit that on the startup
For Dell, Hp, Gateway and other big brands
PC Restore or some thing like exist on a hidden partition on your harddrive that contains an exact copy of your computer's original setup.These programs allow you to reset your computer's operating system andsoftware to the original state in which it was shipped to you.
Do the following actions to remove the recovery partition from the hard drive.WARNING: The drive will be reformatted and all user data erased. This action isnot recommended. Be sure to create a set of recovery disks BEFOREperforming this action.Turn on the PC and repeatedly press the F11 key when the HP or Dell or the computer Manufacturer logo appears
then follow the on screen instructions read them and try to to do "Format and reinstall the operating system
Regards
www.MyTechGuru.US
Aug 14, 2008 | Lenovo ThinkCentre A30 PC Desktop
Dell Inspiron 6400 Notebook Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
