Question about Toshiba Satellite A60 Notebook
Satelite a60 shuts down after 3 seconds
Removed cmos battery to clear lost bios password, now when I start it up it shuts down in seconds, was told I need to reset the bios to default settings tried jumping c561 terminals in wifi during these 3 seconds to no avail, Is there any other way to get my default settings during these 3 seconds of start up?
SEND ME LAPTOP TOSHIBA PSA60L OC9003 VGA DRIVER
Posted on Jun 03, 2009
BIOS PASS WORD LOST
To remove the bios password you need to clear the CMOS.
Open your laptop casing look at your motherboard. locate the CMOS jamper it is near the battery. To clear remove the jamper and turn your computer on with in 5 to 10 seconds and turn it off. Reinsert the jamper back to there proper place and try to turn go to BIOS if there will be a password box appear.
You need to open your laptop and look at the motherboard and locate the CMOS battery. Just remove it with in 5 minutes to clear BIOS password.
Jun 26, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Need to know how to reset power on password for hp
If this is a BIOS Lockout Password, then you would need to Pull the CMOS battery From the laptop... Which most likely means Complete Disassembly of the laptop just to get to the battery... You would have to unplug the battery... Make sure the Laptops Charging Battery is also Removed and the AC Adapter is NOT plugged in...
Once the CMOS battery is removed, Hold the power button down for 30 seconds... then replace the battery and see if it is bypassed/removed..
There is a good chance that the BIOS password is on a security chip on the motherboard and if this is the case, then pulling the CMOS battery will do you no good... You will need to replace the motherboard if this is the case...
Nov 16, 2009 | HP Compaq 6510b NoteBook Intel Core 2 Duo...
I need to reset the bios password on my metrobook ltplus
At his time you need to open the back cover of you laptop to solve the problem. You need to reset the CMOS battery of jamper to clear BIOS password. To open the back cover you need to remove first the laptop battery after that fine and remove some screw.
Once you have already remove the screw and the cover you can see there a small circle CMOS battery you need to remove is to clear all stored password in CMOS memory. You can also see there a jamper near the CMOS battery just remove that and turn on your laptop with in 10 seconds and turn off. Reinsert the jamper with the same position.
Now the CMOS password are already clear just turn on your laptop first before you close the cover.
Oct 25, 2009 | MetroBook DT Plus PII-300 (MB-DT-P300) PC...
Bios password cant boot password protected
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 09, 2009 | Dell Latitude D505 Notebook
Compaq 8150p bios password need to be reset. Is the cmos battery soldered on or unplugable.
The BIOS battery could be a button type battery or it could be a battery with a plug-in lead.
Oct 08, 2009 | HP Compaq 8510p Notebook
How to remove cmos/bios password ?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
How to break bios password
remove CMOS battery for 1 minute then try to install it back
Jun 08, 2009 | Intel D945GCCR Motherboard
Toshiba Protege 2000 Lost BIOS Password
if you are getting password in the booting of the pc then it is bios password plz check the link
http://www.tech-faq.com/reset-bios-password.shtml
if it is not then try to boot in the safe mode and change the password
Jun 24, 2008 | Computers & Internet
Administrator Password for BIOS lost
HP laptop 9000 need help installing webcam
Feb 22, 2008 | HP Compaq nx6110 PC Laptop
Remove bios password
There are lots of tools/software available to reset bios password. Just google for "reset bios password" and you will find one of them, else just open your back side of your notebook. Open the screws and remove the bios battery (a circular shaped sitll battery). If possible change the battery with a new one or keep that battery out of laptop for some time. Now start notebook without the battery and shut down.Then reinsert the battery to laptop and start again. The password should be resetted by this process.
Feb 17, 2008 | Computers & Internet
Toshiba Satellite A60 Notebook Logo
484 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
