Is it Your Phone Locked To Network Or Security Lock,It locked to Network means You cannot use with Other Network Sim card,You can find that By inserting Other Network Sim card.....It accepts means It's Unlocked from Network LOCK and You can use with any GSM Network,So it's Need some other LOCK unlock,If it not accept Other NETWORK Sim card in the Phone While insterting Other Network Sim card means ..It's Under Network Lock,You have to Unlock it Get the Unlock code and instructions from here
Mobileunlocksolutions.com and Unlock it from Network Lock ,then use with any GSM Network Sim card.....You can Try 0000 or 1234 as default code to Unlock from Security or Password lock,It not works means call the service provider get the master reset code and reset from Security Lock.You can follow the instructions Below To UNLOCK from Network Lock,You need to specify the Network and Country It locked now,to get the code...
Warning : Do not enter any wrong unlock
codes on your Nokia 5000d-2 mobile phones. If you enter over a certain
amount of wrong unlock codes on your Nokia 5000d-2 mobile phone, your
phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5000d-2 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5000d-2.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5000d-2 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5000d-2 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5000d-2
Each Nokia 5000d-2 mobile phone has an unique
unlock code. You can buy the unique unlock code for your Nokia 5000d-2
mobile phone using the form above.
nokia 5000d-2 IMEI 356924/03/767265/7
