Question about Vantec iON 2 VAN-460N (VAN460N) 460-Watt Power Supply
Not working after wrong settings
I got a new Vantec ION2 460 Watt PSU and started it up on 115 instead of 230 which it is suppose to be it. It made some funny sounds then turned off now it won't work. The instruction Manuel said to wait 5 mins then turn it back on but that doesn't work.
  • toxicitysoad May 31, 2009
    The booklet says that it has protection for things like that, but I thought I killed it. Do you know if the warranty would cover that?
    I'm hoping that its just the fuse but I don't won't to void the warranty and replace it myself. Also I sent an email to Vantec a few days ago but am still yet to receive a reply. Thanks for your help.
  • 585 Answers
You could contact Vantec about the warranty but I'm afraid you'll find that this is one is just one of of life's lessons. There is an input fuse in the power supply, but is most likely soldered in. Sometimes the fuse does save the rest of the unit from the resulting overcurrents, and maybe replacing just the fuse will fix it, but I don't know your skill level.
You mentioned protection, and the power supply may contain what's called a "crowbar circuit". That type of protection if in place will intentionally blow the fuse in a case of this nature before any other damage occurs. That being the case, the fuse will fix it.
Posted on May 31, 2009
  • Bruce Volkers
    Bruce Volkers Jul 07, 2009
    Did you ever get an answer from Vantec about the warranty?
  • 700 Answers
If your main power is 220Vac and it is set in 115Vac. It could be you actually fried your power supply.
Here is the reason, in common power supply after the rectifier diode when it is set in 115Vac, its circuit acts as a voltage doubler, its mean in its downsteams it actually uses around 220Vdc. And when you uses it in 220Vac it will connect directly as a rectifier.
When you set it in 115Vac and plug in 220Vac. In its downstream it could be in 440Vdc, then its an overvoltage everything that can't compensate will be damaged.
Hope I give you some info.
  • fougzki May 31, 2009
    Ok then try again.Or try to run the power supply on its own only with no load. If that actually doesn't work we can do nothing about it.
    On warranty issue try to see its warranty policies. Usually when it have burned marked they will not honor it, except of course if you can make them believe that its factory defect. Or how you handle the talking.
    Yeah as bat1956 say this could have some crowbar circuit in it. But if you will gonna do it yourself you can void its warranty since you gonna open the case, usually fuse are inside and usually a soldered type.
    If crowbar circuit is in it. You still have some chances to fix it. If they gonna do it. Or do it yourself, if they refuse to have it in warranty.
How do I set the Waterway Champion Pump for 115 Volts? I have the same problem, just installed and it runs for a bit then shuts off. It was mentioned that the pump is usually set for 230, so how do I set...
The voltage is not optional. What voltage are you plugging the pump into?
If you are plugging it into 115, the pump must be set for 115.
If you are plugging it into 230, the pump must be set for 230.
Usually there is a wiring diagram on the label on the pump body or if you remove the end cover, there may be instructions there. There may even be a switch or terminal that states 115 volts and another that states 230 volts.
Gary
Jun 29, 2011 | Waterway Champion 1 1/2 Hp 230v Energy...
My psu not working at all for desktop even to run the fan
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
May 02, 2011 | Compaq (176763001) 120-Watt Power Supply
On the back of this power supply, Theres a red switch with the numbers, 115 and 230. depending on which way it was switched on. Can someone please explain to me what this is?
Hi inforis,
That is a setting that will change the voltages, and you do not want to flip that switch. If you do there is a chance you will fry your computer. Different countries use different voltages. It's cheaper to make a switch & some circuits inside the PSU than make a whole new one. List of countries with frequency & voltage (http://www2u.biglobe.ne.jp/~INTECS/WorldVoltage.htm)
Hope that answers you question well enough.
Dec 29, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
My astec atx202-3515 power supply blew up. I accidently changed the watt to 115. It was 230 watts before. Will the power supply still work oe will I need to purchase a new one?
just flip it back to 115v hook it up and see if it works. if itdoesnt work replace it . I did that once it was fine the comp didnt turn on til i turned it back 115v
Mar 09, 2010 | Astec (ATX202-3555) (ATX2023555) 200-Watt...
Ok i neeed help!!!!!!!! on my power supply there is a switch which you can move to 115 volts to 230 volts. everytime i switch it to 230 volts the computer wont turn on? why is this happening? when i put it...
This is the power supply for your PC, depend on your local country power supply, some country like North US may use 110 V in their daily use electrical stuff and some country like Euro, UK use 240 V.
Your PC power supply is design to suit this 2 type of power input so can be sold everywhere. What u need to do is to make sure your local country power supply voltage and then just switch the input correctly, i think u have done it.
YBC (/\)
Oct 20, 2009 | Computers & Internet
Graphics Cards causes computer to not display
Hi there.
I'm working on the assumption that the graphics card is a PCI Express card.
Remember that if you are swapping from on-board graphics to a card you have to go into the BIOS and tell the machine that the primary graphics adapter is AGP/PCI Express.
Plug the VGA cable into the on-board graphics port, start the computer and enter the BIOS, tell the computer to use the AGP/PCI card as primary, press F10, save the changes and exit the bios.
The computer will try and restart so let it boot to post and turn it off, then put in your card and try to boot again.
Please post back if you need more help or advice.
Good luck and thanks for choosing FixYa!!
Jun 04, 2009 | Vantec iON 2 VAN-460N (VAN460N) 460-Watt...
Clicking noise in new Hayward Super Pump
It sounds like the wear ring on the impeller is hitting the diffuser. If it is new call Hayward to fix it under warrenty
Best of luck
Jun 04, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Generator electrical
On a 230 volt std hook up here's the way it is supposed to work. From black to white you should get 115 volts. From Red to white you shoudl get 115 volts. From red to black you should get 230 volts.
Concentrate on getting the correct output from the generator with the load to the house disconnected
This should be 115v (black to white, 115 volts red to white and 230 volts red to black.
On the load side (ie, the house connected) what are you using? 115 volt lights, etc on one side of the
230 volts, and some other 115 volt loads on the other side.. Are there any 230 volt loads. It could be
that one side of the 230 volts (ie, a 115 volt side is drawing a lot more current than the 2nd 115 volt leg.
Get back with me on just what the loads are botth 115 volt and 230 volt . also what are the rating on the circuit breakers.
Loringh
Oct 28, 2008 | Electrical Supplies
Power supply
Usually this will damage the power supply only. To make sure your that your motherboard is working, try to find a working power supply unit and connect it. If it does not work your motherboard may be get damaged. Also check for warranty. If your system contains a graphics card, check that too, it may also get damaged with voltage variations.
Oct 02, 2007 | ASUS P5LD2 Motherboard
Power supply
Try this, (with the slider in the right position)remove the power cord from the P.S. and push the power button for 5-10 seconds. This will usually dissipate built up charge on the system board and P.S.. Then plug it together and try it with the slider in the right position. Also, try unplugging everything except the MLB, to see if it will beep (post). If so, power down and plug things back in one at a time...
Oct 02, 2007 | Gateway Essential 500 PC Desktop
Vantec iON 2 VAN-460N (VAN460N) 460-Watt Power Supply Logo
152 people viewed this question
Top Vantec Computers & Internet Experts
Arora Singh
Arora Singh
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
