Question about Bosch Televison & Video
I need spare parts for a Bosh Remote Control No. 239-2 for car alarm.
  • 3 more comments
  • rbzimm May 31, 2009
    Bosch agent in Israel does not import this specific remote control for car alarms anymore and it is hard to get a new one in the local market.
    The button which activates the alarm does not respond. Not even when I open the plastic case and press directly it from the board. Even contact cleaner did not help.
    I believe I need to buy a new R.C. or at least the electronic board.
    Thanks,
    Roberto
    I see a large list of remotes in the page you addressed me.
    can you be more specific?
    There is a long list of remotes in the page.
    Can you be more specific and recommend one that will surely work?
    Thanks,
    Roberto
    I see it, But it seem to be a remote for home appliances. Too big to be holden with the car keys.
    I need something not bigger than 2.5 inches by 1 inch.
    any idea?
    Can you recommend a smaller remote that can be attached to the car keys?
  • 3,230 Answers
Please let me know what part do you need...?
Thanks
Posted on May 31, 2009
  • 2 more comments
  • Mukesh Kumar May 31, 2009
    Ok..
    This remote is not avliable..
    But you can try a universal remote, purchase universal remote from the above link -
    http://www.google.com/products?client=op...
    Regards
    all-guru
    Ok..
    Go to the below link -
    http://www.sonystyle.com/webapp/wcs/stor...
    Thanks
    Please follow the above link.
    Ok please follow the link below -
    http://www.fadfusion.com/selection.php?p...
    Thanks
Wont crank alarm set is on,on the dash
Is the key not disarming the alarm. Get an auto locksmith / autoelectrician to check and test. for faults. Do you have a spare key/ alarm remote control?
Jul 01, 2014 | Chrysler Aspen Cars & Trucks
I have an after market alarm the model number on it is 118c1123 -- other than that I do not know what it is called. Sometimes the car will not unlock when pressing the remote many times. It only does...
hi
first i would change the remote control battery's
if that works i would buy compatible remotes and reprogram via that working remote for a spare
i that didnt work
i would open the car via the key remove the cover under the dash below the steering wheel
there are normally 2 fuses to a car alarm remove the fuse on the red power led that will disable the alarm
but it will also disable the remote central locking
but you will b able to unlock the door with the key a start the car
aries
Oct 16, 2013 | Prestige Replacement Alarm Antenna...
LG CA-20F69, sampoorna iii # need remote
Four digit universal remote codes for LG TV are:
0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
If you buy one universal remote control, the set must be synchronised by one among these codes. If you contact the authorised service center for LG, you can buy one new original remote control for your set. If you have its old remote control with you now, you can buy one like that from open electronic spare part market. Remote controls are very easy to get from open electronic spare part market now a days.
Jun 20, 2012 | LG Televison & Video
Hi, I have a 1995 Toyota 4runner... That said, I'm
Well if they were able to cut this wire, I am assuming they were able to get into the car? But if your dad can open the hood and take the negative wire cable off of the battery then he can bridge the wire that was cut, hopefully.
He will need a small wire clamp kit that they can get at an AutoZone or Atuo Parts store. After he fixes the wire that was cut, he will need to disconnect the positive wire cable from the battery and then reconnect both of them. that should keep the alarm from going back off, however it may reset the system. Either way if he has the spare remote they should be back in business and can get your care moved and the alarm to work again.
Good Luck!
May 29, 2012 | 1995 Toyota 4Runner
Hi i have a bosh 862 alarm system and it arms it self during the night and if i get out of bed to go to the bathroom the motion detector picks up my movement sounding the alarm off. I do not activate the...
I believe that this system utilizes your power line as it signal path (for arming etc). the problem is your are getting voltage spikes during the night (most likley all the time). the only way to eliminate these spikes is to use a power line conditioner, however if you do you may not be able to arm your system with the remote control (as the power conditioner may isoltate your device from the line, (needed for communications). if you can find a line conditioner that ony filters voltage spikes and not an isolation type unit, your remotes may still work. You can arm the unit at the control box however. good luck
Mar 22, 2011 | Garden
Battery died on remote. No spare battery, how can get into the car without the alarm going off
put key in lock and hold over for 30 secs,then unlock car normally and car should start,without alarm going off.as long as car recognises key(s) all part of the anti theft system.
Apr 03, 2010 | 1999 Audi A6
Toyota 1.8 vvti celica key thob alarm problems
THE FACTORY KEY FOBS ARE IDENTIFIED BY
THE NUMBER OF BUTTONS AND THE NAME ONE THE BACK
IE: DENSO, TRW, TOYOTA,NGK OR BOSH
BUT THE REMOTE THE YOU DISCRIBE SOUNDS LIKE YOU HAVE AN AFTER MARKET REMOTESTART/ ALARM SYSTEM
Oct 23, 2009 | 2000 Toyota Celica
98 Jeep how do you disengage alarm. Only have one remote
there is no way to do that being that the factory alarm is controled by the BCM (body control module) your only option is to go to the dealer and buy two new remotes and have them set to the frequency of your vehicle.
Sep 09, 2009 | 1998 Jeep Grand Cherokee
Televison & Video Logo
83 people viewed this question
Top Bosch Televison & Video Experts
richie46
Paul Unsworth
Level 1 Expert
Are you a Bosch Televison and Video Expert? Answer questions, earn points and help others
