Question about Philips DVP642 DVD Player
Power button flashing. Dvd player won't respond or open.
Power button is flashing. Won't open or respond to any commands by remote or directly. Unplugged machine. No change. power light is flashing, cannot open or operate the player in anyway The power button is flashing, but the DVD player will not turn or or open.
SOURCE: Philips HDRW720/17 won't turn on
For all you guys that own these frustrating DVD writers I have good news. I too had the same problem with the writer dying and was able to fix it. I can't be sure if your writers have the same exact problem as mine but I would agree with Stewo69 that it is your burner drive that's the problem. I have the HDRW 720/17 with the IDE writer. I was a pain in the *** to use, buggy, the timer hardly worked, and took forever to figure it out. But, it did produce really nice DVDs. And, I got about 600 disks out of it. So, I thought it was worth fixing.
What I did was buy a used DVD+R writer drive pulled the old one and popped the new one in. I did have the try different configurations with the drive jumper. I found it worked on the slave setting. I first bought the HP dvd200i and it worked. But, it has trouble playing some newer disks. I just ordered the dvd300i. We’ll see it that works better…and I bet it will. The key is that you have to have a DVD+R. Also, you may have to trim the front plastic panel on the unit (where the tray slides through) to get the tray to slide through. A Philips writer may work too (and possibly a LiteOn). I think Philips makes them all. I’m just leery of buying anything Philips again. Other DVD+R’s may work too but I can’t be sure of that.
If this sounds like a pain…it is a bit but I like conquering **** like this. I beat that crappy frustrating machine that makes great DVDs. If you don’t want to do it I may be interested in helping a few of you out, as I know how to do it now. Email me if you want to talk about it. You’d have to ship me your machine, a working replacement DVD+R writer, shipping back money and maybe little something for my time. My email is: michael888@charter.net
Later,
Mike
Posted on Mar 25, 2008
  • 79 Answers
SOURCE: Sony Video Cassette Recorder/DVD Recorder
Hold the "Enter" button and press number 1 on the keypad simultaneously for more than 5 seconds. This takes you back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down for more than 5 seconds.
Hope this helps
Thanks for reading!
Posted on May 02, 2008
SOURCE: DVP642/37 Power light flashing constantly.....won't power on
This origional post has been up since June 2006. The answer(s) about the 1000mf capacitor are right on target and has helped people even up to today (Aug. 26, 2008). It worked for me and the following might help others.
First find the power supply board. It is the one with the power cord attached to one end (make sure you unplug all power first!). This power supply has about nine minature electrolytic capacitors in the output of the supply. There is a large electrolytic near the input (elecrtical cord). Disregard this one and go to the other end of the board. The 1000mf, 10volt component you are looking for is near the middle of the 9 or so capacitors on this end. It will probably be the largest in this group (because it has the highest electrolytic value of the group) and the board surface will have an I.D. number of C316 adjacent to it.
DO NOT ASSUME THAT THE CAPACITOR WILL HAVE ANY SIGN OF A BULDGE, DISCOLORATION, OR ANYTHING THAT WOULD IDENTIFY IT AS A FAILURE! In my case the replacement solved the problem but there was absolutely no signs on, or around the capacitor. After replacing it, I checked the old capacitor with a (ANALOG) multimeter. The test showed leakage across the capacitor. In other words it was still working but had a high resistance path through the capacitor. This is exactly what I expected because when I checked the output voltage of the supply to the other 2 boards, voltage was present but was reading about 1/2 of what it was supposed to. The markings on the front (output) edge of the board indicate a -24 volts between ground (pin 4) and pin 3. Mine was reading approximately -12 to -13 volts.
I hope this will help others. As a matter of interest, this is an electrolytic capacitor and you should notice that the component taken out is marked negative ( - ) near one lead. Be certain to install the new one with the negative lead in the same manner! Also, any replacement you might find with a higher voltage rating should be at least 16 volts but a 200 or 1000 volt rating will work fine. Although, the higher the rating, the larger it will physically be. You probably would not be able to physically install anything over 50volt rating. The 35volt rating seems to be very available and a very good choice. With regard to microfarad (mf) value, 1000mf are very common but a 1200mf to 1500mf in a power supply circuit will work fine. Do not use anything less than 1000mf. Hope this helps others. This is going to contiue for this Phillips product until they all die.
Posted on Aug 26, 2008
SOURCE: command mode
I did the same thing and lost all remote control to the recorder. Try holding ENTER & 3 in unison for as long as it takes (30 secs or more ) to view change on TV screen. This should get u back to system menu where u can change back to dvd 3 (default ) If doesn't work get a one for all remote and enter code 0533 which will get u in to the recorder command lines. PS enter & 3 worked 4 me.
Posted on Nov 08, 2008
SOURCE: My dvd model is philips dvp 3005 and it is in standby mode
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Posted on Feb 18, 2009
DVD player is broken and won't open and I have a disc stuck in there
you have 3 alternatives for open:
1) with the button eject or close/open
2) remote control. button open/close or eject
3) with small knife pull out the carrousel for to bring the disk, with carefully.unppluged the power cord.
otherwise you must go to the repair shop TV for fix it
God bless you
Jul 21, 2012 | Philips Magnavox MDV453 DVD Player
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Sony RDR-GX360 won't respond to any buttons on unit or remote. Only function that works is power button. Disk tray won't even open.
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Aug 11, 2011 | Sony DVP-S360D DVD Player
The player does not respond to commands from the remote. The sensor on the player does not light up when the remote's buttons are pressed. The light on the front of the remote does not go on when the...
Your remote may have gone bad. Using a digital camera there is a way of checking out a remote for proper operation. Google it and see what happens with fresh batteries.
Jul 23, 2017 | Koss KD260 DVD Player
Remote RMT-D240A not working with RDR-VX525 DVD Player that it came with. Only get DVD Screen saying DVD 3, will not even turn ON/OFF.
You may have to reset the remote to the current command code. Here is the link for how to do that. http://community.sony.com/t5/Remote-Controls/RDR-VX525-Changed-to-DVD3-on-command-control-and-remote-won-t/td-p/158777
Dec 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
Crk76vbl1 remote manual codes. I need codes
You haven't specified which devices you need codes for, so I've provided a link where you view/download your manual containing all the codes and the programming instructions:
http://help.mtaonline.net/dtv/remotes/rca/images/Remote%20Codes.pdf
The manual will open in a new browser window. You can then print it - or save it to your desktop/documents folder for future reference by clicking on "File" in the top left corner of the browser window and choosing "Save As..." from the resulting drop-down menu. If you are unable to see the manual after clicking on the above link you may also need to download Adobe Reader:
http://get.adobe.com/reader/
Here is also a summary of the programming instructions for your remote:
Direct Entry
1. Turn on the component to be programmed.
2. Look up the brand and code number(s) for the component on the code list in this section.
3. Point the remote at the component.
4. Press and hold the component button you want to program on the remote.
5. Enter the 4-digit code from the remote control code list on the following pages. If the indicator flashes, you have either entered an invalid code or the button isn't programmable. For example, if your remote came with your DVD player, you cannot program the DVD button to control another DVD player.
6. Release the component button, and then press ON-OFF to see if the component responds to the command. If it doesn't, try pressing the component button and then ON-OFF again.
If you get no response, repeat these steps using the next code listed for your brand,
until the component responds to the remote commands.
If you try all the codes for your component brand and none work, try the automatic
code search method. If automatic code search doesn
't find the code, the remote is not
compatible with your component.
Hope this helps.
Regards,
BElectric
Nov 21, 2010 | Televison & Video
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
DVDrecorder not responding
try a power on reboot. hold the power button for 12 seconds until it reads "recover"
Rolling picture could be a loose cable or TV on the wrong channel.
Jan 06, 2008 | Philips DVDR3320 DVD Recorder/VCR
Non responsive dvd600 by Oritron
Can you take led off, see if DVD stuck inside unit? Find the tray release button and manually open the tray and replug. and see if unit respond.
Aug 10, 2007 | Oritron DVD600 DVD Player
Philips DVP642 DVD Player Logo
403 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
