Question about Acer Aspire 5735 Notebook
New lap has green diagnal lines in the display. Disrupts all viewing quality
Green diagnal lines in new laptop screen acer aspire. Running windows vista
Display is not comming
yes one more victim! your killer was "dust"
your laptop was getting hot right? fans running loud right? then you have a GPU problem, your graphic chip is dead. it needs a new graphic chip.
www.laptopreballing.co.uk
Jun 05, 2010 | Acer Aspire 5315 Notebook
Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Dec 01, 2009 | Acer Aspire 5720-6661 Notebook PC
Fan for my acer 3690 spins, green light is on but no display show
Look to See If Your Hard Drive/Data Indicator Light is on and blinking (or solid)..
You need to try and hook up a desktop monitor to the laptops serial port.. Reboot with the External Screen Plugged Into The Laptop.. If You See Windows Booting From The External Monitor - Then You Have A Faulty Screen, or possibly a faulty Display Cable.. Most Likely The Screen Has Failed Though... Also, Hold The Screen Up To A Bright Light while its powered on, You Might have just lost the backlight and have a display still, It will be REAL faint but holding it up to a light and looking to see if you can see Windows Running..
If No Display on the External Monitor When Connected To The Laptop, Then You Have GPU/Graphics Failure, Due To Thermal Damage.. This Is A Motherboard Issue Because The Chips Are Integrated.. A ReBake/ReFlow Of The Chips Will Get Your Video Back, Or Replacing The Motherboard.....
Nov 15, 2009 | Acer Aspire 3690-2196 Notebook
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
Blank screen when i turn on my lap top
If you place your ear to the laptop and you can hear the system running i.e. the fan running etc, it is your display that has a problem. It could be that the screen is burnt or the vga signal cable is burnt. But if the system is not running at all, your motherboard needs attention or it is gone bad.
Aug 16, 2009 | Acer Aspire 5735 Notebook
Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
May 20, 2009 | Acer Aspire 5315 Notebook
How can i replace the backlight of teh LCD Monitor
Before bying parts hold down the "Fn" key and hold down the up arrow - this usually increases screen brightness
Apr 26, 2009 | Acer TravelMate 4320 Notebook
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Acer Aspire 5735 Notebook Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
