Question about Apple HP DeskJet 840c InkJet Printer
Hp deskjet printer
When iask my computer to add printer because it is not there the reply is operation could not be completed.
  • 4,889 Answers
Directly install the device drivers..which you can find at the link below..
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=59868&lc=en&dlc=en&cc=us&lang=en
Posted on Oct 23, 2007
    Novelist:
    Champion:
  • 382 Answers
Download the driver for your computer and that printer, or run the cd. If you are on a mac and have osx, the drive should be in the os. If not, DL it with the printer disconnected. Launch the installer and then go to system preferences and choose PRINT/FAX. See if it's been configured properly.
I have an hp deskjet 3420 printer. How do I connect with this device on mew computer?
According to HP, this printer is not supported in Windows 8. Thus, if you are trying to connect using a Windows 8 PC, there are no drivers that are compatible. You may need a new printer. If you have an older operating system, you get go to the link below, select you operating system, and download the "Driver-Product Installation Software". Run this and follow the instructions top install the printer on your new PC.
HP Deskjet 3420 Color Inkjet Printer Drivers
Jan 10, 2015 | HP Deskjet 3420 InkJet Printer
Tip
HP Deskjet F4200 Series All-in-One Printers Protection Fault Problem
A lot of HP Deskjet F4200 Series All-in-One printer users complain about the installation problem experienced with this product, especially those using the Windows XP operating system. The driver installs perfectly; it performs the alignment and prints the test page. But as soon as you print a document, photo, or anything from the computer, the printer fails and says "The program has encountered a problem and needs to close". When you go to the printer properties, you'll get a message: Function address 0x500a0490 caused a protection fault. (Exception code 0xc0000005) Some or all property page(s) may not be displayed.
The problem can be resolved by completely uninstalling the driver and installing it again. When the installation is complete, click the START button on the lower left corner of your screen then on the right pane, click 'Printers and Faxes'.
Under the printer tasks, click 'Add a printer' then click Next on the Add Printer Wizard dialog box. Select 'Local printer attached to this computer' and uncheck 'Automatically detect and install my Plug and Play printer' then click Next. Click 'Use the following port' and select LPT1: (Recommended printer port) then click Next.
Select HP under the Manufacturer list and under the Printer list, select hp deskjet 990c then click Next. Select 'Keep existing driver (recommended)'; click Next, name your printer, select Yes to set your printer as the default printer then click Next. Select Yes to print a test page, click Next then Finish to complete the setup. Click OK when a dialog box appears.
Go back to the 'Printer and Faxes' folder and right-click on the name of your printer. Select Properties and click Ports/Connections then check 'USB...Virtual printer for.....hp deskjet 990c'. Click Apply then OK and you should now be able to use your HP Deskjet F4200 Series All-in-One printer.
on Apr 11, 2010 | HP DeskJet F4280 All In One Printer InkJet
HOW CAN I DOWNLOAD DESKJET PRINTER SERIES 1500 COPY I
I'm not sure that you mean the HP Deskjet D1500 series. In case this is correct there is no 1500 series. Follow the proper links for your product:
* HP Deskjet D1520 Printer
* HP Deskjet D1530 Printer
* HP Deskjet D1550 Printer
* HP Deskjet D1558 Printer
* HP Deskjet D1560 Printer
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Apr 27, 2011 | Computers & Internet
How can I make my printer compatable with windows vista.
Windows Vista has the basic drivers for HP deskjet printers. Please follow the steps below:
1. Just turn off your computer, and then connect the parallel cable to the computer and printer.
2. Turn on the computer. You will be prompted to a Found New Hardware window.
3. Select Locate and Install Driver. Make sure to click Allow if the User Account Control screen pops up.
4. Windows will search for the drivers, if it was able locate the drivers then the installation is complete. If not then click Cancel.
5. Go to Control Panel -> Hardware and Sound -> Printers. Select Add Printer.
6. Click Add a local printer. Then click Next.
7. Select Use an existing port. It should be LPT1 (Printer Port). Then click Next.
8. On the Install the printer driver screen, select HP in the list of manufacturers. Then select the model of your printer. If it is not listed, click HP Deskjet 500c. Click Next.
9. Type the name of the printer, then click Next. The printer driver installs. You may click Print a test page to test if it is working.
10. Click Finish.
I hope this helps! Good luck!
Jan 22, 2010 | HP DeskJet 5550 InkJet Printer
I have a HP Psc 2355 All-In-One InkJet Printer Bottom of page is cut off sometimes printing from vista computer
USB Cable Connection:
=== HP Deskjet 990c Drivers on Vista ===
* Click on the Windows button.
* Type 'Printers' without the quotes and press enter.
* In Printer folder, click 'Add a printer' button on top.
* Click on the option 'Add a local Printer'.
* Put a check mark beside 'Use an existing port' and choose DOT4_001 or USB001 or USB002 from the drop down box.
* Click on next.
* Choose 'HP' from the list of manufacturers and 'HP Deskjet 990c'from the list of printer.
* Click on next.
* Follow the onscreen instructions to configure the drivers.
NOTE: While printing, please choose the all-in-one as HP Deskjet 990c all-in-one and then try printing
Network printer:
* Put a check mark beside 'Use an existing port' and choose TCP/IP from the drop down box.
* Click on next.
* Click on next.
Oct 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Still cannot use my hpdeskjet 5850 printer because can't find driver disk to install it I'm in germany
No Worries!
Click this link below to select the correct operating system of your printer.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=305980&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Don't worry HP Software is for free just download and install..
Sep 23, 2009 | HP DeskJet 5850 InkJet Printer
Need hp deskjetf4288 software
HI Its better if you use the default printer drivers available in the computer.
go to printers and faxes --->choose add a local printer--->make sure you check the right port,
for HP Deskjet it should either be DOT4 and most likely the USB0001 port--->when you get the manufacturers list---->choose HP and in the right pane look for Hp Deskjet 550c,
this works as the default printing drivers and you shouldn't face any issues as far as printing from the computer is concerned,
for further clarifications you may reply here.
Jun 09, 2009 | Office Equipment & Supplies
Printer
Windows comes with drivers for many HP printers.
You can try to install your HP deskjet 5440 by going to (depending on operating system) "Start", "Printers and Faxes", "Add Printer". Select a local port. Select "HP" and Model "HP Deskjet 5440".
If 5440 is not in your list, or if you want the latest driver, you can download the driver for your specific operating system here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=445441&lc=en&cc=us&dlc=en&lang=en&cc=us
Aug 02, 2008 | HP Deskjet 5440 InkJet Photo Printer
How do I add the Deskjet 670c without the CD ROM?
you can go to support.hp.com click on support and drivers Select Download drivers and software (and firmware) Type in Deskjet 670c in the box and press enter Select your operating system Continue with the instruction!! Good Luck! regards, babb
May 03, 2007 | HP DeskJet 670c InkJet Printer
Apple HP DeskJet 840c InkJet Printer Logo
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Don  Farrell
Don Farrell
neOen
Level 1 Expert
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
