Question about Sony PlayStation 2 (PS2) Console
My controller works for only a few seconds, then stops working.
Its not working My controller was working fine. But now it works for a few seconds, then stops working. and repeats.
Pls visit authorized personnel for servicing!! no other way!!
Posted on May 31, 2009
DeLonghi DD70PE Dehumidifier. Why does pump often stop working and F/P shows an error code until reset?
id be inclined to think that for some reason the pump is taking too long to pump tank out (or it thinks it is ) this would cause the fault you describe and the safety control shuts pump off for fear of a problem
Aug 18, 2015 | DeLonghi Dehumidifiers
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
My S107 worked fine the fist 5 minute flight. On my second attempt nothing would happen. The green light on the controller just blinks. Occasionally when I turn them both on the chopper just takes off...
Seems like your controller is not working. Try to change its batteries.
With new batteries try the following:
1. Turn the controller ON. Wait until green light stops blinking.
2. Turn the helicopter ON.
3. Give it throttle few times until it starts working.
Sometimes controller can still work even if has a blinking light. But these cases are very rare.
Mar 23, 2011 | SYMA Toys industrial New Syma S107 Radio...
Kenmore Oven Model 278 4298891 everything appears to work but the oven turns on then a few seconds later goes off???
My daughters just experienced the same problem. I've tested what I could and only found some bad solier joints on the control board for the dial. I re soldiered the connections but still have the same problem. The temp sensor ohms at 1100 roughly and changes with temp changes. The elements pass a continuity check. The bake and broil relays seem to work fine but a few seconds after the relays close the oven just stops heating. Stumped! I guess I will look for a new control board.
Jan 17, 2011 | Kenmore 27841
The airconditioning fan runs for a few seconds then quits. The rear operates fine.
Sounds like your blower motor has quit if it is inop on all levels. If high speed works and the other speeds do not, then its probally the rheastat or resistor pack
May 05, 2009 | GMC Envoy XL Cars & Trucks
Will not run after a few seconds
sounds like a main pc board and or capacitor problem
Sep 17, 2007 | Kenmore 54351 Dehumidifier
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
