Question about Nokia 3110 Cellular Phone
My computer dsplay the message "NTLDR is missing".plz tell me about this.
This message is showing because your OS has failed to install OS means operating system like vista etc.reinstall your OS
Posted on Jun 02, 2009
  • 53 Answers
Hi I'm mhel, this message appear when you replace your motherboard with a new one without formating your harddrive or maybe some virus attack, so the only possible solution is to format your hard drive to get rid of this messag. hope this will help
mhel
mijamhel@yahoo.com
mhel_services@yahoo.com
Posted on May 31, 2009
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
I have lenovo g560 laptop with win XP OS and i get message like "NTLDR is missing" plz help me what i can do.?
reformatting your laptop will solve your problem, if you have your windows xp cd then you can easily fix it..
just reply if you have any question
Sep 04, 2012 | Lenovo G560 - 15.6 - 500GB - Black -...
When i strt my dell latitude d600, powering on there appears" NTLDR is missing", message and below that another message is" Press Ctrl-Alt-Del to restart", but when do so after...
NTLDR is the abbreviation for New Technology Loader. That is a boot sequence for loading Windows 2000,XP, Win 7 etc. It is telling you that the boot file ntldr is missing or corrupt and gives you another chance at loading another system, that is if you have dual booting, however,when you restart the same thing happens. There are many detail specifics about this subject on the internet, so enter the phrase "ntldr is missing" into google and read all about it and how to fix it.
Jan 02, 2011 | Computers & Internet
Recovery on presario 1692 NTLDR is not responding
Plz check the below link from HP. It will help you in resolving the issue. ?Missing NTLDR? Serious Error Message Appears During Startup http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00213449&cc=us&lc=en&dlc=en Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 24, 2010 | Compaq Presario 1692 Notebook
NTLDR missing issue
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Jul 29, 2009 | ASUS Eee PC 1000H Laptop
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
Ntldr missing error
Ntldr is the Operating System bootup file. To boot into Windows, Ntldr file is must..
IF you have the Operating System disk with you, do the OS repair. This will resolve your problem...............
Sometimes, OS disk might be problematic, in such cases, you need to go with another disk to reload the Operating System.
Jun 21, 2008 | Dell Microsoft Windows XP Home Edition
Computer won't boot up, tells
i think the ntldr file is currupt or is missing i will sugest yu restore windows using restor disk or better still backup yr files then format the system.
thank u
May 29, 2008 | E-Machines Computers & Internet
NTLDR is missing. Press CTRL-ALT-DEL to restart
NTLDR MISSING PRESS CTRL+ALT+DEL TO SESTART. WEN I DO THEN WINDOW WITH ALL THE SET UP COMES. PLEASE HELP!!1
Apr 24, 2008 | Compaq Evo D500 PC Desktop
Compaq Computer/Will not Boot up
your nt loader is missing or is corrupt and so u need to format the computer or repair it using windows xp boot cd.
Feb 28, 2008 | Compaq Evo D500 PC Desktop
Nokia 3110 Cellular Phone Logo
67 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
