Question about Vintage Keeper VP500 Wine Cooler
VP500 Cooling unit issues
The Wine Cooler will not maintain a 57 degree temp and hovers between 66-69.
It is less than 2 years old.
The manual suggested reseting the cooler, there does not appear to be a reset button on the unit.
I have put a separate air condition unit in the room to keep the ambient temperature down and that seems to help to keep the unit at between the 66-69 but that is not satisfactory.
  • 1 more comment
  • apreis Jul 09, 2008
    I too have this same unit. I purchased it approximately 4 years ago. The first unt only lasted a little over a year. I am now on my second unit and it can not seem to cool down past 70 degrees. The second unit is only a year and a half old as well.
  • Anonymous Jan 19, 2009
    I also have had TWO cooling units fail on the Koolspace 500 wine cellar in 4 years. The manufacturer (vintage keeper) says they will sell me another on for $300. Fool me twice, I'm an idiot...fool me three times, I'm a huge idiot. This product is garbage...I'm getting a unit from someone else and retrofitting it...don't buy anything from these morons.
  • Anonymous Mar 16, 2014
    It's switches on but it's sitting at 20 degrees even if I put the thermostat down to 7 or 8. Have turned it off and left it for a while but them I put it on again just goes to a higher temp. Any suggestions?
  • 4,655 Answers
above is a link to the Vintage Keeper manual PDF format manual and problems and trouble shooting guide
Posted on Oct 23, 2007
Wine cooler too cold
The 2 @ 47 degrees may be low in refrigerant gas. Refrigerators are design to operate with an exact amount of gas. When the gas charge gets slightly low the system will operate colder for a time and when the gas charge loses a couple of ounces the system stops cooling. Another cause may be the thermostat isn't operating properly and or the temperature sensing bulb may be too close to a source of heat.
Feb 09, 2014 | Frigidaire 35 Bottle Wine Cooler
I have my Emerson FR966T wine coller set for 60 degrees, but my cooler never seems to get the high. It always hovers around 58-59. When I heat my house up (never above 68) my cooler seems to warm up to...
Yes, because the fridge is a heat exchanger. The trade off for cooling the inside is a condenser coil on the outside which is warm. If you raise the temperature on the outside it will affect the inside a little. Having said that, the thermostat should keep the temperature within specifications. If you have it set for 60 and it is 58 or 59, to me it is within spec.The difference in 2 or 3 degrees Fahrenheit is tiny.
Also it should be pointed out this is a $63 cooler from Walmart. If you want a good one for storing thousand dollar bottles of Chateau Margeaux, you need a $600 wine cooler with a solid state digital thermostat and controls that talks to your smartphone when the temperature is one degree off..
Oct 21, 2017 | Refrigerators
We have our wine cooler for less than two years. We came home one day and it was making a terrible noise and the temp said 67 degrees instead 54. What's wrong...?
It is not the compressor. This unit uses a peltier cooling system. It has no compressor. It relies on applying a voltage to two dissimilar metals connected at two junctions and when this is attached to a heat sink, allows for the cooling effect. I know this doesn't help, but I thought I should point this out.
Mar 20, 2010 | Emerson (025806803716) Wine Cooler
On two recent occasions, my unit has chilled the wines down to about 36 deg.F. It has otherwise run fine for about two years, maintaining about 57 deg. F, consistently. Any idea what would cause such...
wine coolers are usually installed in cabinets or in a bar type situation where the airflow to them becomes more critical. the cooler has two sets of coils that can collect dust and dirt. once the coils clog with dirt, the fans cannot do there jobs by passing air over the coils. This is how the heat transfer takes place. One coil absorbs the heat from the inside of the cooler and the other rejects the heat into your home or outside of the unit. They should be cleaned once a month just like your refrigerator. This will make it run more effeciently. If this is not the problem, check to see if there is a supply register from your central heating and air system close to it. you may be able to get a diverter to push the air away from the cooler
Dec 05, 2009 | Transtherm Ermitage Wine Cooler
Vinotemp wine cooler temerature won't stay on 54 degrees
If the unit is a thermoelectric unit it can be the cooling system.
If the unit is a compressor unit it will be the thermostat.
Aug 28, 2009 | VinoTemp 32 Bottle Stainless Wine Cooler
Magic Chef Dual temp. wine Cooler #MCWBC77DZC
I suspect the cooler can only actually regulate one of those temperatures and the other one just drags along behind. Perhaps the weather is now warmer and the cooler has to keep the motor on longer to keep cool. The unregulated bottom temperature ends up cooler as a consequence.
Either that or the opposite effect is doing it.
The answer might be to find a 61 degree place in your house to keep the reds.
Apr 28, 2017 | Magic Chef MCWC30MCG Compact Wine Cooler
Temperature setting doen not work
Welcome to Fixya.
You said, you have the Magic chef wine cooler and it is not cooling. I unplugged it when the temp was reading 78 degrees!!! It was cooler to unplug it!! Does anyone know where you can get this repaired?
here in our fixya site there are serviceres from all round the country.
click on Browse the Repair Directory an you may find a serviser in your area.
let me know you found some one!
Please remember to leave me a rating before you leave me!
Oct 03, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Vintage Keeper VP500 Wine Cooler Logo
610 people viewed this question
Top Vintage Keeper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
