Question about BoxWave Corporation HTC Wings DirectSync - Car Charger Bundle
HAND SET NOT RESPONDING. GETTING STUCKED
MY PHONE HTC WING IS NOT RESPONDING EVEN AFTER CLICKING , OR AFTER TAKING OUT ITS BETARY , IT IS WORKING SLOW AND GETS STUCK.
    Problem Solver:
  • 8 Answers
Try Checking the Handsets Memory, if you have too much stored on the memory, eg: Ringtones, Txt's this can slow down the phone. Try deleting some things, or moving them onto a removable memory device.
Posted on May 31, 2009
HTC Wildfire Sense not responding
I have a few questions hopefully i can help if you are still having this problem. What version of Android are you running? Are you running a task manager app if so uninstall it? Try wiping the data in HTC Sense by going ini your phones settings then go to apps then select the all tab. Go down the list until you see HTC Sense. Hit Force Stop and then clear data. Hopefully this helps. Another recommendation is an alternative launcher from the Play Store such as ADW EX or Apex Launcher. Hopefully this helps. The old HTC Sense is a resource hog and replacing the launcher will improve performance. An even bigger step would be to root the device and remove sense all together. Let me know if you need help with this.
Nov 29, 2012 | HTC Wildfire Cell Phone
Mhy htc s620 occasionally slows down. It may take 10 seconds for it to respond to pushing a key. Any help?
On the phone, click setting, and then click accessibility. Change the multi key time out to the slowest time. Also, make sure your phone has at least 10 MB free of Program and Storage Memory. To check this, go to task switcher, and click menu. Then click on system info. Check the remaining memory available for Program and Storage memory at the top of the list. (If you have an SD card installed, it will show up below the program and storage memory.) If you want to remove programs to free up memory, click on settings, then click more, then click remove programs (or press the "2" key.)
Feb 11, 2011 | HTC S620 Smartphone
My htc HD2 touch screen not responding. Take the battery out no luck. Reset the phone and the same.
I can input the numeric code for my password but when I press the unlock key it is not responding..my phone is HTC HD2 touch
May 31, 2010 | HTC HD2 Smartphone
I hav htc t-mobile wing i have inserted micro sd card in the sd card slot of it but in the storage card memory it says "total storage card memory : not installed" i have also tried other cards (witch...
Take out the SD card.Turn off the phone and take out the battery. Now insert the new SD card and then insert the battery. Turn it on and then new card should get detected.
Aug 08, 2009 | T-Mobile Wing™ Smartphone
T-mobile wing - will they work together ideally
Yes, it does, for calls, phonebook, and data. I just upgraded from the tmobile Wing to the tmobile Touch Pro 2 which does not work for data on the tom tom 930T. If you have a problem still try the Xda-developers site look in the HTC Herald forum that is the HTC name for the Wing same phone... and get a custom rom for your phone.
May 03, 2009 | GPS
When i am switching on my wifi on the antena symbol appears but the search is not being done , it says no network found , it used to be normal and it used to get connected even with out a search, and the...
Just switch of the complete set once, and then switch on. This phone responds a bit slow. May be you are using eagerly so many functions at the same time. Avoid using like this.
Apr 26, 2009 | HTC Touch P3450 Smartphone
Locked internet on my tmobile wing
You need to have the network setting setup on the phone by your carrier. even though the phone is unlocked the current network setting are for t-mobile. if your not using t-mobile most of that stuff wont work.
Jan 03, 2009 | T-Mobile Wing™ Smartphone
Slow Responses
Do a backup with PIM Backup and them hard reset the phone (Factory default)
To hard reset the wing: Hold both soft keys down while hitting the reset button with your stylus (the little hole on the side). Should bring up a black screen with some text. Press "send" key to finish process.
*Note it takes a couple of tries to get all of the buttons pressed together. May not work first try.
Aug 14, 2008 | T-Mobile Wing™ Smartphone
Phone is slow
First backup all of your data...After that format your handset...
For format goto Start -> Settings-> System-> Click Clear Storage ...I hope your problem will solve
Jul 31, 2008 | HTC P3300 Smartphone
Rained on T-Mobile Wing
While holding down the soft keys insert the stylus into the side of the phone (small hole on left hand side) should bring up a prompt to say if you continue you will reset your device....if you can get to setting there is a clear storage option, both master reset device. Good luck..
Jan 11, 2008 | T-Mobile Wing™ Smartphone
BoxWave Corporation HTC Wings DirectSync - Car Charger Bundle Logo
47 people viewed this question
Top BoxWave Corporation Cell Phones Experts
Computer Repairing
Computer Repairing
brian soufane
Andrew Taylor
Andrew Taylor
Are you a BoxWave Corporation Cell Phone Expert? Answer questions, earn points and help others
