Question about Sony CDP-CX235 200-Disc CD Changer
Music speeds up,skips pulsating noise
I have a sony cdp-cx235 that just started to speed up songs then skip words and finaly lock up (pulsating noise).turned it off and restarted will work awile and do it again.different cds.most are copys of my orginals.we did move it and cleaned behind and reloaded with copys of original cd
  • 6,784 Answers
Ok, this is optical lens assembly failure. the lens assembly is a whole device that runs on a rail with rail motor. the spin motor is also attached to this Assembly as well. the entire assembly will need to be replace due to the damage that has occurred.
Replacing the optical lens assembly will fix all the issues you stated.
Posted on May 31, 2009
Cdp-ce315 skips in songs
My answer here only concerns if you're trying to play burned audio CDs. Burn your audio CDs at the lowest speed (1). Try the JVC/Taiyo Yuden brand.
Nov 09, 2011 | Sony CDP-CE315 5-Disc CD Changer
How do i skip to the next cong quickly
According to the manual, which can be found online here: http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/55041503_PM_EN.pdf, once you start a song using the Play button, you can immediately press the Next button to skip to the next song. It appears that the next button is the right button on the control pad.
Here is the layout of the control pad, from what I can determine online: Play/Pause Previous Next Volume
Jun 02, 2011 | Mach Speed Eclipse 180 MP3 Player
My Sony CDP-XA7ES CD Player can play only up to 6 to 9 tracks depending on the length of the tracks n then stops.
replace the spindle motor. the motor's speed varies while playing cds and a worn motor will not keep to the correct speed for playback of certain tracks on various points of the disc and will cause skipping and even stop altogether.
hope this helps.
Apr 02, 2010 | Sony CDP-XA7ES CD Player
Music jumps and skips
The laser beam may be "seeing" through dust, try compressed air in a can. Buy at computer stores. Make sure all discs are clean, wipe only in straight lines from center outward....
Feb 21, 2010 | Sony CDP-CX235 200-Disc CD Changer
I have a sony CDP-CX235 200 disc CD player? If I want to create my own cd with music, any idea what type of disc and file formats I need to use?
First, I'd get a CD recorder. This machine is only a player.
Consumer CD Recorders will require CD-R Audio or CD-R Music blank media to record.
I have a 200 cd mega storage unit from Sony that skips during songs and from song to song
Try cleaning the optical pickup, if it doesn't work you'll need to replace the pickup.
Dec 23, 2009 | Sony MegaStorage CDP-CX355 300-Disc CD...
The player works fine for a few songs and then it starts skipping in the middle of a song. It is just like something get warmed up and then it starts skipping
It's got a deffective laser assembly. You know the whole mechanism with little circuits where the laser diode is sitting on, and slides back and fort. There is also a ribbon attached to it which connects it to the main circuitboard. That ribbon could also be the culprit. All in all this problem is too complicated for the do it yourself person.
Nov 25, 2009 | Sony CDP-CX250 CD Player
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Sony cdp-cx235 cd skip
need replaced laser pick up part no:
Manufacturer Sony Part Number 8-848-415-13 Description DEVICE, OPTICAL
Apr 07, 2009 | Sony CDP-CX235 200-Disc CD Changer
Lens Knocking Against The CD - All CDs skip or diginoise then fail.
Take the small back cover off and take some electrical grade contact cleaner and spray all around the lens area, that worked for me.
Mike
Jul 29, 2007 | Sony CDP-CX400 400-Disc CD Changer
Sony CDP-CX235 200-Disc CD Changer Logo
309 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
