Question about Panasonic DVD-S35 DVD Player
Panasonic DVD-S35 Player H02 problem
I put a DVD into the player and it never passes reading it. It give me H02 and then says no disk when there is a disk in the player. What do I do? I already unplugged it and tried again. Please help. I have the same problem. Opened up the unit and found that the DVD was not spinning. If I rotated the DVD a bit it would start spinning and was read OK. It appears that the motor has a dead spot. Sometimes it will start and other times it will not. It depends on the location it previously stopped. As to how to solve the motor problem, I have no idea.
  • Panasonic Master
  • 586 Answers
    This problem is related to OPTICAL BLOCK ASSEMBLY. Two things are involved in this situation.
1- sleg motor start malfunctioning.
2- Optical Lens problem.
In both situations you have to replace the OPTICAL LENS BLOCK.
Therefore your DVD need lens replacement. And it would work fine again.
Thanks for using fixya.
Posted on May 31, 2009
Problem playing dvd with panasonic sa-pt660 keep getting an H02 error message?
Thousands of annoyed customers of Panasonic, Yamaha, and Denon DVD Player owners have encountered the infamous H02 / H07 /H03 erors and many others on thier players or maybe the "No disk" error even though a disk is in the drive. Well many people have spent hundreds on repair or bought a new unit. But i am here to tell you that it is okay to open up your dvd player and mess around in side. If your DVD player comes up with one of these errors the first thing you might want to try is to open up your DVD player by removing the screws on the side and the back (depending on the model), then plug the dvd player into power outlet with cover removed. Stick a disk in and press play and give the disk a little push. Most of the time the Spindle motor is dieing out when you get a H02 error. In this case that little push may get your spindle motor to rev back up back into action. And if your as succesful as me then hopefully you have just fixed your H02 error for free without doing much work. I just got a Panasonic HT95 Reciever/DVD player to play all disks again by giving the motor a little "kick start"
Jan 05, 2011 | Panasonic Televison & Video
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Error H02 for panasonic dvd s35
My Panasonic DVD Player Model S55 does not read the DVD disk. I get a H02 then no disk reading on the display.
Jan 17, 2010 | Panasonic DVD-S35 DVD Player
We have a Panasonic DVD-S35 wont play color
We have a Panasonic DVD-S35 wont play color UK dvd's, US dvd's are ok any idea what's wrong?
Dec 27, 2009 | Panasonic DVD-S35 DVD Player
Code H02
Your DVD player is having an issue with the spindle motor (the thing that spins the DVD around). The following solution works for most people, and you should only have to do this once.
  1. Unplug the DVD player.
  2. Take the cover off.
  3. Place a disc on the spindle.
  4. Put a little pressure on the disc (so it doesn't slip) and spin it around a few times.
  5. Remove the disc, reassemble, and plug back in.
  6. Try to play a DVD.
  7. Report back if this solved your problem, or if more troubleshooting is needed.
Aug 02, 2009 | Panasonic DVD-S55 DVD Player
Hi, this is an unfortunate error. this is referring to the lens assembly. it is unable to scan and read at this moment. it could be because the lens is dead or, it could be that the lens is simply dirty and will need to be cleaned. i would try cleaning it with a non brush type cleaning process. Once cleaned and you still have the same issue, i recommend replacing the lens assembly.
Mar 11, 2009 | Panasonic DVD-S35 DVD Player
Dvd player problem
panasonic dvd s35 it doenst plays always display the H2O
Aug 07, 2008 | Panasonic DVD-S35 DVD Player
No Longer Plays discs
You should try this site. It worked for me. Also after fixing you should try and remove anything that may be on top of the DVD as this seems to cause the issue. We have had our S35 for at least 4 years and today was the first time I got the error.
http://wiki.xdroop.com/gallery2/v/Random/0706_001/IMG00104.jpg.html
Sep 01, 2007 | Panasonic DVD-S35 DVD Player
Panasonic DVD-S35 DVD Player Logo
884 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
