Question about Sony Cyber-shot DSC-W170 Digital Camera
Lens will not come out when Iturn it on..
The lens will not come out.. it trys but will not move.. was using it.. turned it off and now the lens will not come back out.. it is a sony dsc w150
  • Sony Master
  • 586 Answers
   Please replace the below part number and it will work fine again,
PART NUMBER          Description
1-788-689-21              OPTICAL UNIT (BE002)
Thanks for using fixya.
Posted on May 31, 2009
Iturn on the camera and the lens doesn't move
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Oct 27, 2009 | Fuji FinePix S1000FD Digital Camera
My camera light comes on and buy my lens is stuck
if u push te lense in it should pop right into the slot. =) have a grooovy day =)
Oct 13, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
Camera turns on beeps turns off
Hi there. Turn on. Before it beeps, take the battery's out. This may take some practice. Now us a Qtip almost soaked in rubbing alcohol and clean the outside edges of the lenses. Put battery's back in and cycle the camera on and off. I hope this works for you. It worked for me.
Thanks
Paul
Jul 12, 2009 | Olympus Camedia D-360L Digital Camera
Lens error 12 and 22!!!
The movement of the lens is motor driven. When you turn the camera on, the lens moves. The error 12, error 14, and error 22 refer to control stages in the lens movement ( I think error 22 means the lens won't retract). The lens housing and gear mechanism in this camera is plastic. If there is dust, sand, or debris around the lens housing, it may bind the lens when it trys to extend or retract. By banging it, you might work the gears loose or dislodge whatever is binding the lens (same with the "canned air" blowing out the dust). We've purchased a bunch of these cameras for our electricians in the field. Several have come back with this problem. I've taken the case off, and torn the lens assembly apart, only to find the plastic gears have been "buggered up". It's an inexpensive camera. Try to clean around the lens, give it a few slaps, push/pull the lens.... but failing this fix, buy a new one. Good Luck!
Jun 19, 2009 | Kodak EasyShare C330 Digital Camera
Lens will not retract.
try taking some canned air and blowing around the lens while you turn it on and off. you might be able to free it up. your lens either has a broke gear or dust or dirt in between them. or you lens motor could have gone out or froze. a gentle tap on a flat surface lens down can sometime correct this. I repair these all the time sorry for your problem. Let me know if I can help you any further on this problem.
Apr 23, 2008 | Canon PowerShot S230 / IXUS 179 Digital...
Zoom error
Just fixed the same problem on mine. This is what I did:
Unscrew 6 small screws around the lens casing and remove the casing (two layers ((rings)). Jiggle the inner most lens casing while you turn power on. The lens moving (i.e., auto focus) mechanism becomes unstuck. Voila.
The problem in my case was caused by the dust that accumulated inside the casing and caused the auto focus mechanism not to move freely.
Good luck.
Mar 05, 2008 | Fuji FinePix S7000 Digital Camera
Lens Error - Cool Pix L6 - Camera unuseable
helppppppppppppppp mne is stuck open and it wrks but whn iturn it off it stays open (1/2 of it)
Jan 07, 2008 | Panasonic Lumix DMC-FX10 Digital Camera
E 61:00
Omg, that's a problem.
Does it still move when the power is off ?
Oct 25, 2007 | Sony Cyber-shot DSC-H7 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
209 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
