Question about GE Refrigerators
Freezor is ok fridge is not working
MY GE GSH22KGREBB SIDE BY SIDE FREEZOR IS OK BUT FRIDGE IS NOT WORKING
    Problem Solver:
  • 8 Answers
There are a number of things causing this issue. First, make sure the evap fan motor is running. If that's ok then we either have a defrost issue (very common) or the damper may not be opening for some reason. Many things can cause the unit not to go into defrost.Unplug the unit then at the board unplug main connector w the 3 larger connections. put a jumper between the Line and defrost and plug unit back in (don't plug connector in) if heater comes on then it's a bad board. If heater does not come on check heater, defrost tstat or def thermistor(it's a white and right on top of evap)
Posted on Jun 22, 2014
Very Common problem with this mode of fridge. Spoke to a number of appliance repair outfits and all said to replace the Com board. Com board located on the back of the fridge. (lower right side behind panel) $175 Can. for the board. Part # WR55X10552 No need for service call. Easy to replace.
Posted on Apr 30, 2010
  • Dave Dawson
    Dave Dawson Apr 29, 2012
    Before you do that check the defrost heater. I have replaces mine twice in the last 10 years. Far cheaper than the motherboard and is usually the culprit
My freezor work good but the fridge does not cool
There is ice blocking the passage which allows cold air from the freezer to pass into the refrigerator compartment. Turn the refrigerator off. Find where the cold air passes into the refrigerator and remove/melt the ice. You may need to remove some panels to access this passage.
Oct 02, 2009 | LG LSC26905TT Side by Side Refrigerator
A side by side GE refrigerator with a loud hum
Hello Kchoffman73,
It sems we developed the same problem.
The hum seems to be coming from the bottom rear of the
fridge.
we have a GE side-by-side model TFX25JR.
The fridge is about 12 years old.
Whats the status of your fridge ? Did it ever stop
humming ? Did you replace or repair it ?
Does it still work ?
Thanks
Sep 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile side by side freezer not working at all. Fridge ok.
Is the fridge side working? If not try turning the defrost timer dial until it clicks. If it now goes you need to test the defrost circuit as there's still a fault but it'll go for 12 hours untill it trys to do another D'frost. If this doesn't work try bypassing the thermostat. cheers
May 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice dispenser will only dispense crushed ice
Ihave zannusi ZX99/5SI fridge freezer. Top-freezer compartment is not cooling. I have done as before, defrosted and cleaned both fridge and freezer but, with no luck. Freezer is working OK but top-fridge  is not cooling. Could you please help with advice in what to de next.
Thank you
GAZ
May 12, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Freezor barely freezing, fridge barely cooling
After the electricity came on what setting did you use? I would start out at 4 or 5.When a unit sits too long without running the coolant will settle to the bottom it can be hard on it because it is trying to push it threw the system.After it defrosts all the lines should be clear. From there it could be as simple as the fan in the freezer is slowing down or your compressor is on its way out. Also check the vent from the freezer to the fridge for blockage.
Len
Feb 19, 2009 | Kenmore Refrigerators
Refrigerator
You need a qualified technician for the leak repair and recharging of refrigerant. All of the refrigerant in the system are gone, next time do not use sharp object when cleaning your fridge.
Jan 11, 2008 | Refrigerators
Refrigerators Logo
244 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
