Question about HHB Radius 50 Tube Amplifier
Fender Stage 100 dsp, solid state amp volume (or power) problem
I own two Fender solid state amps. A Fender Stage 100 DSP, and a Fender Deluxe 90 DSP. The Stage 100 is supposed to have 100 solid state watts, but The 90 watt 'Deluxe 90', is louder on the clean channel, than the 100 Watt 'Stage 100' is on the clean channel. I'm wondering why? Please respond,
Thanks,
Jerry
    Problem Solver:
  • 10 Answers
The Deluxe may have more efficient speakers....which would cause it to sound louder. Also, the EQ settings could play a part in this. If the EQ's aren't set the same there could be a noticeable difference in sound.....usually the mids can have quite an effect on overall amp volume....
Posted on Aug 04, 2009
Cracked solder joint in the pre-amp section, ground issue.
Oct 28, 2013 | Music
The sound of the LEFT MAIN Cannel disappears on my YAMAHA DSP AX-1
The fact that sound appears at max volume means that it is getting past and through the pre-amp stage. So it would appear to be in the main power amp stage the problem. It would depend what drives the channel, but if it's transistor driven I would suspect one of them.
Oct 31, 2012 | Yamaha DSP-AX1 10-Channel Amplifier
Flexwave 120H Speaker wire shorted amp won't work
Solid state amps are very subject to blowing out the output transistors if speaker leads get shorted. Take it in for repair.
Aug 31, 2011 | Crate FlexWave FW120H Guitar Amp Head with...
Fender acoustasonic junior crackling loudly and electronic buzz when touch volume knobs
noise problem with fender jr accoustatics is the poor aluminum sheet ground design that wraps around the body of the amp. it happens to me all the time because i kept on moving/carrying/dropping the amp every time we do church service. i am thinking of using an aluminum cable to wrap around outside the body.
Jul 07, 2011 | Fender Acoustasonic Junior Dsp Combo...
I have a delux 90 fender amp solid state and it has a loud hum in it and it will not let you play a guitar or any thing else, nothing will work no sound except the hum thats all, thanks
This could be any of several problems including a failure in the power supply filtering, a tube that has shorted, or a broken ground someplace. Take unit in for repair.
Dec 07, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I'm missing the volume pot and dont know which one to buy. Its a champion 30 dsp fender guitar amp. Thanks
There are two volume controls. One is "drive volume" the other just "volume"
The plain volume control is a 50K ohm, linear taper.(A) old marking
The Drive volume is a 100K ohm Log taper.(C) old marking
Find suitablel parts at DigiKey.com or Mouser.com or find a Febder repair center to order the part.
From other than Fender, You may have to shorten the shaft with a hacksaw to match your needs.
Jan 10, 2010 | Fender Fm25dsp 1x10' Guitar Combo...
Low volume on acoustic and jazz amp type
Ok, so I hope you realize the Fender FM25DSP guitar amplifier is an "entry level" NON-valve amp with a DSP chip that has model shaping tones. I am sorry but this is a toy and Fender did not spend the tens of thousands of US dollars to have built-in tones that truly 'kill". This not digital modelling like Line 6 or Fractal Audio did and so you have a problem from the start. This amp was always intended as an entry level amp for the bedroom only and never to be used on stage.
Jazz and acoustic modes have some similarities requiring mid-range boost and some rounding. Not easy to achieve with a DSP chip that costs about US$10 to manufacture. Sorry, consider using the amp for practice but look at a more serious valve amps for live on stage
Apr 01, 2017 | Fender Fm25dsp 1x10' Guitar Combo...
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Flashing LED on the volume
i have problem with amp yamaha dsp-a1000 the led the volume it like blinks everytime is good the transistor the output is good, i dont no whats happening can u help me please
Jul 19, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Dsp-a1000 dead
output stage problem, systems trips due to protection. have the power amp transistors checked. the rotating of function switch is normal, its like a routine system check
Jun 22, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
HHB Radius 50 Tube Amplifier Logo
1,260 people viewed this question
Top HHB Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
