Question about Sony ECM-44B Lavaliere Microphone Microphone
I have a bunch of ECM 44b microphones, I'd like to repair them.
I've opened a couple up. There's a little transformer inside. The mics I have with no visible wire damage, and which have either intermittent or permanent outage, I suspect have transformer failure. But this is just an educated guess.
How does one test that transformer? All I have to test them is a little multimeter, but I don't know how to use it. I assume its a matter of "Set the meter to ____, touch the positive tip to ___ and the negative tip to ____, and if the meter reads _____, then it's bad." Is it safe to just assume that the transformer is the problem? There's a little diode at the other end of the barrel. How would I test that, before I go replacing the transformer?
It has been my experience that the wires going into the amplifier assembly is broken. What I do is cut the wire about 2 inched from the strain relief, remove the old wires from the amplifier and reterminate the amplifier. This fixes 90% of my problems. The other 10% is a broken wire at the microphone end of the cable. This cannot be fixed as the cabling has been injection molded.
Posted on Dec 08, 2009
Need help repairing N-soundtube PSU for AKG Mic
Define what you call the transformer. The microphone has a power supply in a separate enclosure. Usually the output has 7 pins to connect to the cable to the mic. First you need to verify that the cable is good. With a multimeter, check continuity of each end of each pin. If one pin has no connection, the replace the cabble and your problem will go away. Try this first, then if needed we'll talk about the power supply.
Roy
Walker Labs
Aug 10, 2014 | AKG SolidTube Professional Microphone
My mic has a very nasty hum please help!!!! I've had it for 7years now and it has never done this b4 so i really need help.
Open up carefully.
Something came loose on the ground cables or the chassis inside.
Tighten screws, check cables, and connectors.
Peace-
Jul 21, 2011 | Marshall MXL-V69-MEDT Microphone
Through wear and too much handling the wire detached from the microphone. What now?
UNLESS YOU HAVE EXPERIENCE IN REPAIRING THESE DEVICES, YOU SHOULD TAKE IT TO A MUSIC STORE SERVICE DEPARTMENT THAT SPECIALIZES IN SUCH UNITS. REPAIRING THESE REQUIRES A HIGH LEVEL OF MANUAL DEXTERITY AND SOLDERING OF DELICATE WIRING.
Oct 07, 2010 | Sony ECM-44B Lavaliere Microphone...
I have a two yr. old 55sh series 2 that just quit working. Looking inside the on/off switch cover, there are no loose wires. What to do next?
If you do not have experience in repairing these mics, you should probably have a pro audio technician do the work. The problem is an open circuit in microphone's internal wiring; either the mic cartridge is dead, or one or more of the fine wires connecting it to the microphone output connector are disconnected. Sometimes the fault is caused by a bad solder connection, or a faulty switch. As I mentioned, unless you have experience with these items, you can permanently damage a potentially salvageable mic. A goos tech should be able to identify the problem in a few minutes, and if the mic is repairable, it should be a cheap fix. Worst case scenario, a dead cartridge replacement may cost half the price of a new mic. But then, it's essentially a new mic.
Oct 06, 2010 | Shure 55SH Series II Professional...
How can you open an AKG 220 perception mic to repair it? the mic got knocked over and still works, but the inside seems loose, moving around from side to side.
at the bottom of the mic where the xlr connector is you'll find a ring screw with two notches. unscrew this and you con remove the lower housing. The upper housing is hold by 5 screws.
May 13, 2010 | AKG Perception 220 Professional Microphone
I've had a Marshall MXL 2001 mic for seven or eight years, and it's worked without a problem. Yesterday, it stopped working. I opened it and don't see any loose wires. Where should I take it for repairs?
mics are very delicate . a lot bundled into a small area. If you are handy..take it apart. All you may be able to do is check for loose solder joints..mics are dropped, moved a lot so they go through a lot of physical stress. My last mic repair ended up being a bunch of loose solder connections. if not..if its of value to you..send it in. Trace Electronicss..Canada.
May 06, 2010 | Marshall MXL 2001-P Professional...
Left channel only
If you take it to a store then you can probably have it sent to sony who will give you an estimate before fixing it. This mic offers one of the best cost performance ratios so you will probably end up buying another one. Upon that assumption, ifthe repair quote is less than about 70% of the retail price then it may be worth getting it repaired. I have found sony repairs (to a digital camera) to be reasonably priced.
Sep 03, 2008 | Sony ECM-MS907 Professional Microphone
Low Audio Level
I found this happens with a bad capsule.
On the end of the wire you have the microphone capsule. If I remember correctly, the capsule can be unscrewed from the microphone amplifier case assembly. This part can be ordered from a supplier for Sony professional parts.
I have also had the wire go defective, and need replacement. With most of these models, the complete capsule assembly has to be replaced along with the new wire.
If you are not used to servicing this type of microphone, Sony has service reps that can service and test the microphone for you.
Jerry G.
Aug 10, 2008 | Sony ECM-77 Professional Microphone
Problem recording in stereo
Most likely you have a problem with the MIC. Has this ever worked with this unit? If not maybe the un it is not compadable with this Mic. The instuctions and specs are available for download Here http://esupport.sony.com/US/perl/model-documents.pl?mdl=ECMDS70P&LOC=3 Good luck
Jun 12, 2007 | Sony One-Point ECM-MS907 Consumer...
Battery corroded inside microphone
My experience with repairing Sony microphones for a television station is that once the battery corrosion eats the copper anywhere within the mic, the circuit (not the mic) is toast. I would send it in to Sony direct as they will have the parts and expertise to turn this around quickly for you.
Oct 03, 2006 | Sony ECM-MS957 Professional Microphone
Sony ECM-44B Lavaliere Microphone Microphone Logo
349 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
