The power and all he lights turn on but when i hit the start button nothing happens!!have checked all the water cnnections etc. and everything is clear and fine!!ahh helpppp.....
These units are nothing but grief!! Problem sounds similar to my one, it caused me no end of problems from the time it was installed and don\'t bother calling F&P service coz it will cost you almost as much as a new dishwasher. They have an inherent prob with circuit board, even service tech (on the quiet) said they are bad.The best thing I did for mine was throw it on the scrap metal pile and bought myself a Meile, not one problem. its super quiet and designed to last 20 years. Use the bottom one till it completely craps itself (prob not long) and then buy a NON F&P one!!!
you need to check your pump and motor for shorts to earth, or low resistance readings across windings. the motor controller board will need replacing also most likely.
Hi - its highly likely the start/pause micro switch under the nice panel is faulty, only way is to replace the display module.
I have come across machines with same problems where you can select any function except of course - push start & nothing happens., if your machine does this then I suggest you invest in a replacement display module.
If it is a musical rippling sound & hot & cold lights are flashing that usually indicates it is not getting water quickly enough. You can open the lid while it is filling & look. If water is just trickling in and taps are fully open then replace the inlet valve with a new one.
Hi just read your posting.Just a couple of questions, Do you hear a beep when you push the start button?IF you don't then the problem is your display board.If you hear a beep and it does not start then the problem could be your lid switch.How old is your machine?Please reply with more information and I can help you track this problem and repair it.
