Question about Danby DPAC90061 Portable Air Conditioner
Exhaust tube not staying in collar/not sealing correctly
We have a Danby A/C (Model number = DPAC90061), and the flex tube for the exhaust has come unscrewed from the collar that attaches to the window exhaust adapter in the slider kit. I screwed it back into the collar, but it doesn't seem to make a tight seal, and ends up leaking the hot exhaust air back into the room. Also, it doesn't seem to screw in tight, as I can feel the air escaping from under the collar and back into the room. I've tried to rescrew the tube back into the collar repeatedly, and it just falls out on it's own. Unfortunately, this has resulted in no cooling taking place. How do I fix this? Any help is appreciated. Thank you in advance.
  • satansdik May 31, 2009
    This is a good idea, but the flex tube is made of vinyl or plastic, not metal. That would likely cause ripping, which might cause more trouble than it seems to be worth...any other suggestions?
    President:
  • 3,433 Answers
Screw it back in place and put a sheet metal screw in it into the adapter.
Posted on May 31, 2009
  • 2 more comments
  • Ned C Cook
    Ned C Cook May 31, 2009
    ODuct tape couldn't hold up to the heat, that's why it won't stay in place. the hose gets hot.With the hose warm, will it screw over the outside of the adapter? Going with the flow direction of air, The overlap should be of the downstream hose over the discharge.. did I confuse thee? :). Male should be adapter and female the hose. Tried to avoid that terminology.
  • Ned C Cook
    Then clamp it with a nylon tie or hose clamp..
  • Ned C Cook
    Ned C Cook Jun 11, 2009
    did fitting it over the adapter and clamp work?
  • Ned C Cook
Where can in get a set of exhaust/intake hoses for a danby dpac120068 air conditioner
Is there a reason not to just go to the Danby site? Support Danby includes phone support, email and "Find Parts" Even if their source is out you should at least be able to find the correct part number, then Google Danby (part number).
You could also look to see if generic flexible vinyl tubing/hose can be substituted. It's doubtful that Danby created their own hoses.
Jun 09, 2016 | Danby Heating & Cooling
My danby model dpac90061 plugs in and wont turn on
Hi There,
I have just spoken to one of our technicians and he said that if the there is a red blinking light that usually means that the bucket or drainage system is full. If that is not the issue, it could be a malfunction in the touch pad. If the issue is not the bucket, please contact our customer service department regarding repair. (1-800-26-Danby) We are available Monday to Friday from 8:30am to 4pm EST.
Thanks!
Jul 18, 2012 | Danby DPAC90061 Portable Air Conditioner
Need i/o hoses for dpac90061
I would go through the manufacturer. I just tried sears and it doesn't recognize your model number.
May 11, 2012 | Danby Heating & Cooling
The exhaust on my rear cylinder is making excessive noise, i'm not complaining but on inspection, the manifold is split, it seems to have made out of 2 pieces! why would any1 do that??? shoud i replace...
Muffler putty, no. If you have it off, take it to the local welder. They can tell you if it is fixable. Usually your best bet is to just spend the money and order a new original equipment replacement part (if a good salvage/used part is not available. Be sure to replace the exhaust gasket in the head when you put the pipe back on. EBAY may be a good source of a good used head pipe.
Sep 27, 2011 | 2000 Suzuki VL 125 Intruder LC
2001 Ford Focus Flex tube exhaust leak
OK, flex tubes are notorious for leaking exhaust over time due to the overflexing of the tube due to engine mounts not being strong enough over the service life of the vehicle.
One solution, is to take the car to a custom exhaust shop and have them fashion a sleeved exhaust that will not break as easily as the original equipment.
For instance, in my area, we have Midas or Meineke Exhaust centers that can fashion a custom exhaust for the vehicle solving the problem for the life of the pipes, anyway.
Good luck on fixing this problem.
Nov 05, 2010 | 2001 Ford Focus
The exhaust on my 1999 chrysler 300m is making noise out of a strange looking ''collar''below the engine but before the muffler
Think your talking about the 'flex' pipe. They do go bad and will leak exhaust out, making wierd sounds.
Sep 17, 2009 | 1999 Chrysler 300M
05 susuki forenza
Removal Procedure
1. Disconnect the negative battery cable.
2. Drain the engine oil from the engine crankcase.
3. Remove the exhaust flex pipe retaining nuts from
the exhaust manifold.
4. Remove the exhaust flex pipe retaining nuts from
the catalytic converter or the connecting pipe.
5. Remove the exhaust flex pipe.
6. Remove the oil pan flange–to–transaxle retaining
bolts.
7. Remove the oil pan retaining bolts.
8. Remove the oil pan from the engine block.
Cleaning Procedure
1. Clean the oil pan sealing surface.
2. Clean the engine block sealing surface.
3. Clean the oil pan retaining bolts.
4. Clean the oil pan attaching bolt holes in the engine
block.
5. Clean the oil pan scraper.
Installation Procedure
1. Coat the new oil pan gasket with sealant.
Important : Install the oil pan within 5 minutes after applying
the liquid gasket to the oil pan.
2. Install the oil pan to the engine block.
3. Install the oil pan retaining bolts.
Tighten
Tighten the oil pan retaining bolts to 10 NSm (89 lb–in).
4. Install the oil pan flange–to–transaxle retaining
bolts.
Tighten
Tighten the oil pan flange–to–transaxle bolts to 40
NSm (30 lb–ft).
5. Install the exhaust flex pipe.
6. Install the exhaust flex pipe retaining nuts to the
exhaust manifold.
Tighten
Tighten the exhaust flex pipe–to–exhaust manifold
retaining nuts to 35 NSm (26 lb–ft).
7. Install the exhaust flex pipe retaining nuts to the
Tighten
Tighten the exhaust flex pipe–to–catalytic converter
or connecting pipe retaining nuts to 35 NSm (26 lb–ft).
8. Connect the negative battery cable.
9. Install the oil pan drain plug.
Tighten
Tighten the oil pan drain plug to 35 NSm (26 lb–ft).
10. Refill the engine crankcase with engine oil.
Jun 14, 2008 | 2005 Suzuki Forenza
Installation
This is apparently a new product, and not having provided me with a model number, I was only able to ascertain that this is a dual hose model? If so, then I would assume that since there is no direct correlation between 1 hose and the other, that it probably doesn't matter, since both hoses are utilized for proper operation. Click the link below for more information.
http://www.rainbowappliance.com/Air-Conditioners-1/Danby-DPAC90061-9000BTU-115V-PORT-AC-DANBY-3340.html?utm_medium=shoppingengine&utm_source=yahooshopping&cvsfa=673&cvsfe=3&cvsfp=DPAC90061
Jun 03, 2008 | Danby 7,000 BTU Portable Air Conditioner -...
Danby DPAC90061 Portable Air Conditioner Logo
223 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
