Question about Dell Dimension 3000 PC Desktop
Usb port My usb port is not recognizing my iPod. When I inserted my iPod, the software loaded, but then when I try to sync my iPod to add music to it, I get the following message: '.. cannot by synced. The required disk cannot be found'
  • Dell Master
  • 1,183 Answers
If any other USB device is working on the system, other than your Ipod , there is a driver conflict in your system.
Try the following steps
1. Try a system restore
Click on start>all programs>accessories>system tools >system restore.
2. Try creating a new user profile
Start>control panel>user accounts >create new user
If nothin works OS needs to be redone ie complete system reset.
If still does not work its the motherboard thats causing the problem
Posted on Apr 01, 2008
    Scholar:
  • 90 Answers
Have you tried syncing on more than one computer and get the same error msg as a result?
Could very possibly be a bad hard drive in your ipod.
Or, your iTunes is having trouble locating the music your trying to add to it. Try adding music manually, buy using drag and drop. See ifyou still get the same error. Let me know.
Posted on Oct 23, 2007
  • Chuck Gluth
    Chuck Gluth Oct 23, 2007
    You can also try resetting the ipod.
4th generation i pod not reconizing
Hi james
First, make sure your iPod is fully charged and then toggle the Hold switch on and off.
Reset, Retry, Restart, Reinstall, Restore
Go through the 5 R's of iPod troubleshooting, which will often solve your issue. If you're still experiencing the issue after going through each of the steps, then continue for more suggestions.
To determine if your iPod syncs via USB or FireWire, check the table in the Additional Information section below.
Tip: If you are using Windows XP and have recently installed a Service Pack, check the Device Manager. Click the Start menu and click Run. Type "devmgmt.msc" and click OK. If no devices appear in the Windows Device Manager, go here.
Still can't see your iPod?
Several things could keep iPod from appearing in iTunes or Windows Explorer. The most likely causes are listed below-you'll find information for both USB and FireWire (IEEE 1394) iPod connections. Check each one starting from the top of the list to see if that is what's keeping iPod from appearing.
Make sure your computer meets the iPod system requirements
Make sure that your computer meets the system requirements to use iPod with Windows.
If your iPod displays an exclamation point folder or sad iPod icon
If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue.
Charge the iPod and make sure it is getting power
Your iPod must have enough of a charge for your computer to recognize it. Connect your iPod to its power adapter or to a high-power port on your computer to charge your iPod if the battery is depleted. If your iPod is connected through FireWire but isn't getting power from the FireWire bus, your computer may not recognize it.
Secure the iPod's connections
Make sure that there is nothing physically inside or blocking your computer's USB (or FireWire) port, and that the cable connections to your iPod and computer are secure.
Note: If you're using an iPod shuffle (Second Generation), make sure the iPod is inserted securely in the iPod shuffle Dock.
Restart your computer
Sometimes simply restarting your computer can resolve issues.
Connect iPod to a high-powered USB port
If you're connecting an iPod, iPod mini, or iPod shuffle to your Windows computer, make sure that you're connecting it to a high-power USB 2.0 port on your computer.
If you're connecting the iPod to a Windows laptop computer through USB, connect the laptop to a power outlet before connecting your iPod. Also, see iPod not recognized when connected to Windows laptop over USB to be sure that your USB ports are supplying enough power.
Typically, USB 2.0 high-power ports are located directly on your computer. Try connecting your iPod to another USB port on the computer.
Avoid connecting the iPod to a USB hub. Connect the iPod directly to a USB 2.0 port on the computer. If a hub must be used, make sure the hub is USB 2.0, and that it has its own power supply. Also, make sure the hub is connected to a high-power USB 2.0 port on your computer.
If the issue persists, try disconnecting other USB devices from the computer such as printers, cameras, scanners, external hard drives, and USB hubs to determine if there is a conflict in the USB chain.
Check whether your iPod's cable functions properly
Make sure that you are using the cable that came with your iPod. Some third-party cables may not work properly with iPod.
Make sure that nothing is in or blocking your computer's USB or FireWire port.
Check the connections to make sure that the cable is completely plugged in.
Try another known-good FireWire or USB through Dock Connector cable if available.
If swapping out your old cable for another resolves the issue, then your original cable should be replaced.
Place the iPod into Disk Mode
Try placing the iPod into disk mode to see if it is recognized by iTunes, or My Computer.
Check which format iPod is in
iTunes for Windows only recognizes Windows-formatted iPods. You cannot use a Macintosh-formatted iPod with a Windows PC. To learn for which platform your iPod is formatted, follow these instructions.
Check whether your computer's port functions properly
If another FireWire or USB port is available on your computer, try connecting your iPod to it.
If your computer recognizes your iPod after trying a different port, the original port could be faulty.
Note: iPod will not automatically wake up if you connect it to a 4-pin FireWire port. You must press the Select button (the wheel's center button) on the iPod to wake it from sleep.
Check if Windows confuses iPod with network drive
If the drive letter after iPod ("E" in most cases) is mapped to a network drive, both Windows Explorer and iTunes may exhibit strange behavior in relation to the iPod (including preventing iPod from appearing. See "Windows confuses iPod with network drive and may keep iPod from mounting or songs may seem to disappear" for more information.
Your USB or FireWire card isn't recognized by Windows
Make sure that Windows recognizes your USB or FireWire card. Follow these steps to find out if Windows sees your card.
Third-party software may be causing conflicts
Some third-party software (such as security software) may prevent your computer from recognizing your iPod.
Try adjusting the settings of such software, or temporarily disabling it, to see if that resolves the issue.
Also, try booting Windows to Selective Startup mode to disable any third-party startup programs and services, and isolate which software may be causing the issue.
Install or reinstall iTunes
Download and install the latest version of iTunes.
In some cases, you may need to completely uninstall and reinstall iTunes.
Make sure FireWire card is a WHQL-certified IEEE 1394 card
Only certain iPod models sync via FireWire. Refer to the table in the Additional Information section to make sure your iPod can sync via FireWire.
If you have a FireWire (IEEE 1394) card installed in your computer and are using it to connect your iPod, make sure that the card is Windows Hardware Quality Labs (WHQL) certified. If it isn't, your iPod may not be recognized, or you may not be able to send music to the iPod.
If you're not sure about your card's WHQL certification, check the inbox material that came with your FireWire card or contact the card's manufacturer. You can view a list of WHQL-certified cards on the Windows Hardware Compatibility List website. To view this:
Go to the Windows Hardware Compatibility List website.
Click on the link that corresponds with your Windows Operating System to view the compatibility list.
Select your Operating System build, and then from the Product Categories pop-up menu, choose 1394 Controller.
Click the Search Now button.
You can also check the list of recommended FireWire and USB cards that have been tested by Apple with iPod and Windows XP (Apple sells FireWire cards that are compatible with iPod at the Apple Store.).
To rule out an issue with your FireWire card, try connecting a different FireWire device to the card to see if your computer recognizes it.
Check for a conflict in the FireWire chain
Your computer may not recognize your iPod if there's a device conflict in the FireWire chain. To see if this is the case:
Disconnect all devices from your computer's FireWire ports.
Connect your iPod to your computer's FireWire port.
If your computer recognizes your iPod, you should troubleshoot for FireWire device conflicts.
There may be an issue with your computer
If another computer is available, verify that the same issues happen with the other computer. If the other computer recognizes your iPod, you may want to troubleshoot for issues with your original computer.
Your iPod needs service
If after following these steps your computer still doesn't recognize iPod, see the iPod Service website to arrange for service.
Please Take Time To Rate Me
Bud
Mar 21, 2013 | Apple iPod nano
Don't detect when i connect to computer
Tip: If you are using Windows XP and have recently installed a Service Pack, check the Device Manager. Click the Start menu and click Run. Type “devmgmt.msc” and click OK. If no devices appear in the Windows Device Manager, go here.
Several things could keep iPod from appearing in iTunes or Windows Explorer. The most likely causes are listed below—you'll find information for both USB and FireWire (IEEE 1394) iPod connections. Check each one starting from the top of the list to see if that is what's keeping iPod from appearing.
Please Rate Me
Aug 13, 2010 | Samsung YP-U3 MP3 Player
Ipod shuffle want connect to the computer
Please Rate Me
Aug 13, 2010 | Apple iPod shuffle Second Gen. Silver (1...
How to enable my itouch? My ipod touch did not regonized by my itune
Please Rate Me
May 24, 2010 | Apple iPod touch
Ipod touch 32G 3rd gen is not recognised by windows when i plug it in windows gives message, USB Device Not Recognized
Its a little lengthy but worth the read:
Please Rate Me
May 22, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
I am trying to sync music from a cd that is in my windows media player library to my ipod touch, but my computer or media player is not recognizing a device connected in order to sync the music..
you can not sync an iPod with windows media player. if you wish to add the music to your iPod, the only way is to download iTunes.
if you already have iTunesyou
*open iTunes
*insert cd into computer
* a notification will pop up. and you need to download the songs into your library.
hope this helps -_-
Jan 09, 2010 | Apple iPod touch
I can't put song from my computer to my ipod and when i connect it to my computer the icon of songs doesn't appear only device and accessories
  1. Double-click on the "iTunes" icon to open the program and then transfer all of your music filesinto iTunes. To add music from CDs, simply load a CD into yourcomputer's drive, wait for iTunes to see the playlist and then click"Import." To add music from another program, go to the "File" menu andselect "Add to Library." You will then be able to click on any musicfiles you would like to transfer.
  2. Plug your iPod into a USB port on your computer and wait for iTunes toautomatically recognize the device. You will be asked to name andregister your iPod, after which you can click "Finish" and begin toload music.
  3. Click on "Library," found in the left hand column to reveal all of themusic you have transfered to iTunes. To load songs onto your iPod,highlight one or more songs and then drag them to your iPod. Your iPodwill be found in the same column where you found the library, under thename you chose earlier. As soon as you drop the files into your iPod,they will quickly copy.
  4. Eject your iPod once you have loaded all of the music you'd like byclicking on the arrow next to your iPod's name. When the namedisappears, you can remove the USB cable and begin enjoying your portable music.
Here is where you can get ITUNES: http://www.apple.com/downloads/
Sep 25, 2009 | Apple iPod nano
Suddenly my pc re-boots when I plug my ipod into the front usb.
uninstall service pack 3 and ignore it when it asks you to re install it. go to add remove programs and uninstall it. obviously it worked befor. that is the solution. you dont need sp3 anyway.
Jul 18, 2009 | Gateway Computers & Internet
Apple Ipod isnt recognized on computer
You can only sync one ipod with one computer so if you put music on it already it will only work with the original computer you synced it with. Same with ANY ipod.
Jan 07, 2009 | Apple iPod nano
New nano 4 gb isn't recognized by my computer
Looks like the USB port of the Ipod is faulty.. use the warranty while you still can..
Apr 24, 2008 | Apple iPod nano 3rd Generation
Dell Dimension 3000 PC Desktop Logo
221 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
