NO POWER TO RECEIVER /NO LIGHTS FRONT PANEL
NO POWER TO RECEIVER//FRONT PANEL NO LIGHTS
  • 822 Answers
Check power supply.
Posted on May 31, 2009
My Sony receiver amplifier model number Str-de315 has just stopped working clicks on 2 lights come on but nothing else k
no front panel display means one of twot hings: either the power transformer is blown, or the main power fuse. If the main power fuse is blown, then there are likely to be shorted output transistors that will need to be replaced.
May 03, 2014 | Audio Players & Recorders
Receiver wont play sound
Hi Sean,
it is time to clean up inside the receiver and replace the power smoothing capacitors and all the electrolytic capacitors if you can,
i think it happens because of power amplifier section failure and dont worry it will not too cost....
if you are familiar with repairs please open up the covers and contact us.
regards,
nuwan
Jan 08, 2014 | B&K CT310 3 Channels Receiver
I have two tvs on one receiver. and they will only play on the same chanels.
Your post caught my attention, paulholly497, as I found it interesting! What type of receiver do you have? The model number is located on the front panel in the bottom left corner. If it's a Solo receiver, which is only one tuner for one TV, that would mean that the secondary TV is being mirrored off of the primary. If it's a Duo, which is meant for two TV's because it has two tuners, it's likely that you have it in Solo mode. If that's the case, click the Mode button on the front panel of the receiver until both TV lights are lit up. Once both lights are lit, the receiver will then operate the TV's separately and independently!
Hope that helps!
Sep 22, 2011 | DISH Network IR Remote Control
The lights that are yellow in color are not coming on. the unit seems to work fine, but i was told it needs to be serviced.
http://media.onecall.com/Image_Products/Sunfire/ultareveiv2.pdf
Whoever told you that hasn't looked at the manual or the front panel.
Page 10 "PANEL DIM (button)
The front panel lights have four levels: bright, medium, low and
off (low intensity display with amber LEDs off)."
Aug 11, 2011 | Sunfire Ultimate Receiver
TV or control doesn't work need help know
ok my tv is doing the same thing and i need help if you found a solution please email me at pieces41096@aol.com
Jul 06, 2009 | DISH Network 322 DTV Receiver
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Hr22 hd dvr receiver has no front panel lights
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Dec 28, 2017 | Directv HDTV Receiver
I have the Denon AVR-3805 receiver and I can't get it to turn on. When I press the "on" button, it turns from red to green but nothing else lights up. Can you help me?
By now the person who asked this (eleanorr) has certainly solved her problem, but in case anyone else has this same question:
It *is* on, as the color change on the Power button indicator light shows. Most likely, the receiver is fine; it's just that your front-panel display is off!
1. Check the DIMMER mode by pusing the buttom on the front panel -- it may be set to OFF.
2. Push the PURE DIRECT button on the front panel (or remote control) -- it may be ON, which turns off almost all of the front-panel display. (Alternately, change the AV source, which turns Pure Direct OFF.)
Jun 24, 2008 | Denon Audio Players & Recorders
Receiver won't turn on. All I got is the flashing light.
Try pushing these buttons at the same timwe for a few seconds:
Advanced Surround + Enter..
'Advaned Surround' will be found in the front panel and 'Return' near the multi-jog dial.
cheers
Mohammed
Mar 09, 2008 | Pioneer VSX-D712 Receiver
90 people viewed this question
 Grubhead
Grubhead
