Question about HP w1907 LCD Monitor
Screen comes on briefly then blanks out.
I have an HP w1907 LCD Monitor. Yesterday the monitor just went blank. When I turn off the monitor, and turn it back on, the desk top shows up for a few seconds and then blanks out again. When I test the "sleep" button, the "monitor is going to sleep" window appears and then disappers. Therefore, commands like this are visible, but the desk top is not. When I reboot my computer (HP), the monitor will come back up for a few seconds, but it then blanks out. The sleep function is off, all connections have been checked and double checked, I've removed the monitor from power and then re-connectetd, no chages were made to the monitor settings, but the monitor still only shows up briefly and then blanks out. As stared earlier, this just started out of the blue. Any ideas? I have the same problem, goes blank after a couple seconds, says its going to sleep, then sometimes I can get it to come back for a second by switching it off then on but it blanks right out again, and it does it on more than one computer so I know its the monitor..any suggestions for fixing it?
  • 822 Answers
Check inverter, memory, and powersupply.
Posted on May 31, 2009
  • maxpolaris Oct 16, 2011
    Same exact situation here. Monitor is HP2159m about 18 months old.
    Unfortunatly I'm afraid Rommel Dadula is probably right in suspecting hardware issues.
My monitor occasionally blacks out. I turn just the monitor on -- wait a few minutes then it works ok for a while until it blacks out again
There are controls that turn off the monitor, both in Windows control panel and the monitor itself. The system should know if activity is happening, and should not blank if active.
Look at screen savers, too.
Jan 28, 2011 | HP w1907 LCD Monitor
Monitor will come on, monitor status box will come on and then screen goes blank. How can I fix this?
rwhite97, If your pc is working fine with substitute monitor, and w1907 lcd unit does same (black screen, or blanknblack screen) when connected to a "known good" pc, then you should visit and read some stuff at this 2005 blog. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Then learn the flashlight test and what it means. Then go to YOUTUBE for video clips on lcd monitor disassembly and lcd monitor repair if you are into do-it-yourself repair. Remember this!!! Your w1907 unit uses the same basic design and operation principles that ALL brands of ccfl back-lit lcd monitors use. Good luck with the repair. Come back here and leave comment after doing your research/investigation and then rate this response. 12fixlouie
Jul 16, 2010 | HP w1907 LCD Monitor
Computer screen goes blank after a couple of seconds
the back light of my hp w1907 will only come on for a second than go back off?? the rest of the monitor is working can see the image if you shine a light on the screen ..any help??
Comments: Oct 26, 2009 - so this monitor was not in warranty so i took it apart i found a wire broken off one of the backlight bulbs, ( be very carefull the bulbs all four of them and the lcd screen are very very fragile ) so i soldered the wire back on and put it back together and rechecked it it has been working like new
Nov 24, 2009 | HP w1907 LCD Monitor
Monitor goes black
I also have a hp w1907 monitor which also powered on for a second and then go blank with the power light still on.. it was out of warranty so I had no loss so I took it apart..I found one of the wires broken at one of the backlight bulbs { becarefull they are fragile and there is four of them, two on the top and two on the bottom... and the lcd screen is very fragile } I soldered the wire back on and it all work fine... just remember where all the screen parts go.
Oct 24, 2009 | HP w1907 LCD Monitor
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
I turn my monitor on and it lights up then goes blank.
sounds like you have a backlight problem, the wires are known to burn off the ends of the bulbs of the back light..if you try to repair it yourself be careful the lcd screen and bulbs are frigile.. there is 4 bulbs two on the top and two on the bottom of the screen ,, keep every thing in order when taking apart
Aug 01, 2009 | HP w1907 LCD Monitor
The W1907 goes blank when i turned the monitor off and then on
I would say don't turn off the monitor at the switch at all unless you are not going to use it for a long time. I just leave mine switched on and the power save blanks the screen if I am away from it for 20 minutes. I leave my PC switched on all the time as well. If I need to use it for any reason it takes ages for it to start up fully so it's more convenient to just leave it all going so it's ready when I need it. If away from the PC for a day or more switch it off but I keep going back to it all day and night so it's easier for me to leave both on all the time.
Jun 17, 2009 | HP w1907 LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
HP w1907 LCD Monitor Logo
1,189 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
