Question about HP PSC 1350v All-In-One InkJet Printer
Black ink won't print
The black ink won't print. i've refilled ink, cleaned the print head (both simple and intermediate) and aligned the cartridge, but it still won't print in black. i even changed to a brand new hp brand cartridge thinking that a refilled cartridge was the problem, but still not black ink. i can print a document in all blue or red or yellow, but anything with black comes out blank. the printer cartridge is moving back and forth as if it's printing, but the page is completely blank.
  • poloverlorna May 31, 2009
    i've already checked all the settings and preferences. i'm thinking there is plugged up ink somewhere?
  • 822 Answers
Check printer preferences and settings.
Posted on May 31, 2009
Epson picturemate photos printing all black
Maybe you set printer options to print color as black.
Aug 18, 2012 | Epson PictureMate InkJet Photo Printer
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
Will only print yellow, black and photo black-- red cartridge shows ink in window and I just refilled blue-- cartridge was only out of printer a few hours. I've cleaned the print head a number of...
There are a few things here that will do this. One is the cartridge is a smart cartridge and unless you reset the chip it either won't print or shows low. If you filled it before then this shouldn't be it. If you have refilled the cart more than a few times they sometimes just stop. This is either the ink has jelled inside or the little feeder sponge is dried out. If you changed ink brands sometimes the ink reacts with the old stuff and jells.The other is the jet or any feeder tubes are plugged with dried ink. Usually happens if you haven't printed for a while. You can try running the cleaning cycle and it will take quite a few of these sometimes before it starts working.
There are a few more tricks for cleaning such as using white vinegar to dissolve dried ink but that's a bit of the messy side sometimes. Usually we have just had to buy a replacement cartridge after spending the time on this. We eventually just got rig of our ink jets and got some of the cheaper color laser printers. Wish we had done that sooner.
Sep 01, 2011 | HP Photosmart D7560 InkJet Printer
I just replaced my ink cartridge and now it's printing blank pages. I've unplugged & restarted the printer however the problem still exists. The printer says there is an "alignment...
Run a few "print-head-cleaning" cycles, to get the black ink flowing through the ink-jets inside the print-head.
Some printers REQUIRE an "alignment" step every time you change the ink-cartridges.
It only takes a few minutes, and it prints one or two pages of paper.
Jun 20, 2011 | Dell 924 All-in-One InkJet Printer
My epson stylus cx6000 has stopped printing black. I've cleaned the print head, changed the cartridge and it still won't print black. What else can I do?
Be sure you are using genuine epson ink. Epson printers are "smart" and will not allow generic ink to work properly. Even after you replace a generic with a genuine it may take several print outs and alignments to get it to print again.
May 05, 2011 | Epson Stylus CX6000 All-In-One InkJet...
Canon MultiPass MP730 purchased 2004 NOT Printing Black INK- did: new canon ink tank inserted (never used refills) ran: printhead maintenance mannually cleaned print head w/ rubbing...
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 02, 2010 | Canon Office Equipment & Supplies
I just refilled black ink of my new printer Lexmark x5495. Does not recognise the black cartilage and keeps on asking for alignment. When it prints alignment page it does not use the refilled black ink....
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
All colors not printing
hi this is nichu, you have done everything correct but the ink is low in your catridges refill it or purchase a new one.
Nov 20, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Lost B&W printing
Hi marc, it sounds like the normal clean has not eliminated the clog you may have in back printhead. I need to know if you refil your own cartridges or not to be specific, but basically you need to remove the black ink cartridge, and clean the printers heads yourself, and right down where cartridge sits wth cotton buds and proper cleaning solution. Wipe the surface of cartridge if it has the printhead attatched (some printers have the printhead on them, some have it on the cartridge. Replace ink, reset black ink level, cancel the alignment for now, go straight to printing. Print a test page and see how it goes.
Jan 26, 2007 | Canon BubbleJet i560 InkJet Printer
HP PSC 1350v All-In-One InkJet Printer Logo
767 people viewed this question
Seeker5211
Seeker5211
