Question about Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
I have apegasus 1.28 g toilet its not flushing correctly
Its leaking at the bottom of the caps too
    Problem Solver:
  • 10 Answers
Need more info but start by changing wax ring and reset toilet
Posted on May 31, 2009
Installed a new toilet this morning. Filled it and no leaks. Flushed the toilet and water spewed out the bottom of the back. How do we fix?
water in the bowl should not leak. but when you flush it it goes out the bottom into the drain. between the toilet and drain pipe there should be a wax ring gasket to seal the toilet to the floor drain if this wax gasket is damaged it will leak. replace with a thicker wax ring and after you put the toilet back in place sit on it to be sure it has smashed into the wax ring. and put nuts back on and tighten. do not over tighten sand crack the porcelain. this should fix your problem.
Jan 09, 2016 | Home
Why does toilet turn on and off several times after flushing?
The flapper at the bottom of the tank is not seating correctly, allowing tank contents to leak into the bowl.
Oct 05, 2015 | Home
TOILET IS LEAKING
Been there, done that. Does it leak all the time? Does it leak only when you flush? Please clarify this. If the gasket is off centered, it will leak there. The bolts could be leaking, got food coloring to use as a dye? You can do this while watching the bottom of the tank, as you flush. Hairline cracks in the porcelain can be seen, get out yur magnifier and look underneath the tank, as you flush.
Apr 15, 2012 | Home
Kohler one piece toilet. it is leaking around the bottom of the toilet but if I put the water in the back of the tank myself, it doesn't leak
if its leaking from bottom of toilet on the floor. its the wax ring that may be bad, if it does this when flushing it is either cracked or the wax ring under toilet is bad.
Mar 26, 2012 | Kohler Home
Kohler santa rosa fills, shuts off, a little water leaks from tank, toilet refills and repeats the leakage into the drain.
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
Dec 27, 2011 | Kohler - Toilet - One-piece - Santa Rosa -...
My toilet keeps leaking water and then fill ups on its own. Where could the leak be how do I fix it? Also I have to hold down the flush lever awhile for the toilet to completely flush. Can this be fixed ?...
If you are not getting puddles on the floor then it is probably the 'FLAP" that holds the water in the tank. It is the rubber part that is connected to your handle. Any hardware store will carry that part since it is an item that will fail, especially in hard water. It is probably the cause of both problems.
Jul 25, 2011 | Eljer & Titan Elongated Toilet Bowl
I have a dual flush corona and there is a stream of water leaking into the bowl. It periodically has to continue to fill when it gets low. I have replaced the round seal inside the tank at the very bottom....
There should be a float inside the tank of the toilet. Be sure that when the tank fills that the float is not getting stuck, or not floating all the way up and not sealing the flush valve at the bottom of the tank.
Apr 05, 2011 | Caroma CARAVELLE270ADAW-EL Caravelle...
Igenium Flushing valve will not shut off.
THE WHITE PIECE IS LOCKED IN YOU MUST PUSH DOWN AND TURN A HALF OF TURN .THEN LIFT IT OUT,DON'T DAMAGE YOUR O RING
Apr 05, 2010 | Kohler K-3422 - Wellworth Elongated...
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
My whip dual flush toilet leaks around the flapper
the flush neck must be pitted or someting, the part that the flapper sits on that needs to be replaced.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height Logo
98 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
