Question about Sharp AR-5316 Advanced Digital Imager Copier
H4 error for ar-5316
Error h4 it's tingling H & 4 reapitedly
  • 469 Answers
Fuser not heating up, likely cause, lamp or thermal fuse.
Hope this is of some help
Ed
Posted on May 31, 2009
My sharp ar-5320 copier has an error code blinking it flashes h and 4.
The H4 stands for a problem in the heater circuit for the fusing unit, It could be a thermo fuse, thermostat, thermistor, bad heat lamp or worn fuser rollers. The H4 will not reset until either of these components is repaired or replaced. Hope this helps.
Sep 29, 2011 | Sharp AR-5316 Advanced Digital Imager...
H4 error on sharp ar-5316
H4-00 Heat roller low temperature detection
Nov 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316 errors
heat roller low temperature direction
Jun 24, 2010 | Sharp AR-5316 Advanced Digital Imager...
EROR- NOT RESPOND
h4 errors usually accur due to a problem with the fuser it may be it over heated or the thermistor has a build up of toner on it causing irregular temp reading check to see if it is heating up by turning it on and feel the heat from the fuser unit at the back.
Jun 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Reset the error by pressing [#] [interupt] [ C] [interupt] [1] [4] [start]
If the problem persists check the heater lamp and the thermostat by ohm meter
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
HELP, H4 ERROR
H4 is normally caused by the fuser taking a little longer than normal to warm up. Most of the time it is not caused by the hear rod itself. I will send you the process here is a few minutes.
Jul 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316
I am getting a problem code H4 for sharp copier when i start the machine. what is the problem. is ther any solution for the problem of the said model.
Aug 28, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
115 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
