Question about Kyocera FS-1118MFP Laser Printer
Showing 'error occured call service person c6400'
Kyocera FS-1118MFP error C6400
  • Anonymous Mar 25, 2014
    shows c6400 error
  • 46 Answers
Defective power supply board. or Defective engine board
Posted on Jun 12, 2009
J'ai une imprimante KOYCERA FS-1118MFP qui indique : Erreur appeler technicien C6400
Posted on Apr 18, 2012
  • 48 Answers
To reset fuser code 6400 by pressing counter/system button, then go to service setting, then hold the start and hash button at the same time, now press enter and leave all buttons, press 163 and enter/execute, switch off and on, fuser will be reset, if not reset then replace fuser/fixing unit.
Posted on May 05, 2014
How do I unlock my printer a Kyocera fs 1118mfp when error C6000 appears?
Press the system menu/counter key,Select Service setting using the up/down cursor keys.While pressing the start key and the # key, press the enter key.then select 163 Resetting the fusing problem data Description Resets the detection of a service call code indicating a problem in the fusing section. When a service call concerning the fusing section occurs, turn the power switch off and open the front cover. Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode. Purpose To prevent accidents due to an abnormally high fusing temperature. Method 1. Press the enter key. A selection item appears. 2. Select Execute using the up/down cursor keys. 3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.) Completion Press the back key. The indication for selecting a maintenance item No. appears.
Mar 27, 2015 | Kyocera FS-1118MFP Laser Printer
My kyocera FS1118 MFP displays C6400 error. Can you help me?
C6400 indicates that the engine board is not recieving the correct signal.
I would suggest that you turn off the machine and ensure that the cable that runs from the document feeder at the top rear of the machine into the connector on the rear of the machine (if fitted) is securly tightened.
You can also try turning the machine off at the wall for 10 minutes.
If this fails you will need to call out a technician.
Jul 21, 2011 | Kyocera FS-1118MFP Laser Printer
C6400 error problem of kyocera printer
C6400
Contents: Zero-crossing signal problem
• The engine PWB does not detect the zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Causes: Poor contact in the connector terminals.
Check procedures/corrective measures: Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Causes: Defective power supply PWB.
Check procedures/corrective measures: Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
Dec 17, 2010 | Kyocera FS-1118MFP Laser Printer
Kyocera FS1118, error code C6400, how do I resolve This?
Hi
Error C6400 appears in Kyocera FS118 when Zero crossing signal problem occurs i.e when the engine PWB doesnt detect the zero crossing signal. This can occur due to --
#1 Poor contact in the connector terminals.
#2 Defective power supply PWB.
#3 Defective engine PWB.
To reset it from Mainatince mode turn the power switch off and open the front cover. Now, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
4. After this is complete press the back key. The indication for selecting a maintenance item No. appears.
Daniel Scott
Jun 21, 2010 | Kyocera FS-1118 Printer
Call service c6400
You have a FUSER error. You need Kyocera or Copystar Technician to reset the FUSER memory.
Jul 23, 2009 | Kyocera FS-1118MFP Laser Printer
Call service c6400
it is the problem fuser unite heater lamp or thermostater
Jul 14, 2009 | Kyocera FS-1118MFP Laser Printer
Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Jun 05, 2009 | Kyocera FS-1118MFP Laser Printer
Kyocera FS-1118MFP Laser Printer Logo
3,801 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
