My tv shows backwards
The words that shows across the tube be in reverse
  • 822 Answers
Check deflecton yoke coil. wrong connection.
Posted on May 31, 2009
I have a Panasonic projector style TV that was donated to my nonprofit but the words all appear backwards. Is this an easy fix? What if anything can be done economically?
Press the menu button w/the projector on ,projecting a image.There is a reverse image selection that you just need to undo :)
May 26, 2014 | Office Equipment & Supplies
My picture is reversed.
The yoke of your tv has a reverse position try to put the connector in other yoke terminal
Oct 28, 2012 | Panasonic Televison & Video
My television is showing a reverse picture. All the words and picture is reversed.
I assumed your TV is CRT type right? so try to open the cover and find the yoke<it is found on tube and have a winding wires.
Then look at the connector of yoke,, you need to place it to other yoke terminal behind.
Oct 28, 2012 | Panasonic PT-44LCX65 Television
Philips tp3267 c102 i had this tv and it fell on its face and scratched up the tube.I then replaced this tube with a sony tv tube.the tube worked fine but it was upside down. i then flipped the tube and it...
I would use a tube from an identical unit. The voltages on the yoke connections can be different from different manufacturers. Otherwise you will need a spec sheet on both tubes from the manufacturer. If you can get the service manual the pin out of the tube should be in there. Hope this helps.
May 04, 2010 | Televison & Video
Hear both sides of tape on playback ??
It's a 4-head reversable deck where the Forward tracks are arranged across the physical tape surface, front-to-back as follows:
ForwardLeft ReverseRight ForwardRight ReverseLeft
...so it sounds like the Reverse playback heads are engaged at the same time you play Forward, so you would hear those adjacent tracks backward. If you play the tape in the Reverse direction, is the Forward program audible (but backward)?
If so and in otherwise high fidelity, something in the Forward/Reverse head selection may be hosed.
Or, if the out-of-phase tracks are mushy and low volume, the physical tracking of the tape across the heads could be WA-A-A-A-Y bad. That would probably be visible as sideways distortion in the tape path. Shine a high-intensity light on the tape where is passes over the heads, then reverse it while watching where it sets up on the heads. It should be centered on the heads and not change its orientation when reversed. Compare where it tracks in motion with the probable visible wear marks (shiny bars across the heads perpendicular to the travel) where the tape has polished the heads over the years.
Or, the heads are so worn the coils pick up signals from their neighboring tracks.
Mar 04, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
My tv shows i reverse
check the connection of deflection yoke coil. its a wrong connection from vertical.
May 31, 2009 | Televison & Video
Zenith picture problems
Your TV is showing signs of age. It's displaying something called "vertical foldover" which is due to capacitors in the set's vertical output section that need to be replaced. These failed parts can stress the vertical output integrated circuit, and if that goes bad your picture will collapse to a thin horizontal line. The capacitors themselves (usually 3 or 4 need to be replaced) are pretty cheap. A TV shop in your area (if there are any still around!) could fix it and the repair should be under $100.
By moving those rings on the tube's neck (which is actually the back) you have messed up the set's convergence. Those rings are magnets which adjust the electron beams in the tube so the red, green and blue images line up correctly on the tube face. The rings are often marked with a stripe after adjustment to show how they were lined up. Look carefully at them and see if there are any marks you can go by to reset them. To properly converge the set some equipment is needed to generate the adjustment test pattern. Again, a shop could do it for you.
All things considered, at this point you might seriously consider replacing the set. Not because the troubles aren't fixable, but because other parts can start failing because of age, and by now your picture tube is on borrowed time as well.
Apr 13, 2009 | Zenith C27A24T 27" TV
Source code of a program
import java.util.*;
public class StringReverse {
  public static void main(String[] argv) {
    String s = "Support Tech Problem";
    // Put it in the stack frontwards
    Stack myStack = new Stack();
    StringTokenizer st = new StringTokenizer(s);
    while (st.hasMoreTokens()) myStack.push(st.nextElement());
    // Print the stack backwards
    System.out.print('"' + s + '"' + " backwards by word is:\n\t\"");
    while (!myStack.empty()) {
      System.out.print(myStack.pop());
      System.out.print(' ');
    System.out.println('"');
Apr 07, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
Electro Med Services...
