Question about Indesit W 123 Front Load Washer
Clicking control knob
The control knob starts to click in mid cycle almost every time the machine is used
    Scholar:
  • 97 Answers
Try checking the filter, its normally located behind the kick plate on the bottom of the machine, best to tip machine back when you unscrew filter though as there will be quite a bit of water in the pipes more often than not.
hope this helps.
ps if the dial is just clicking the red light will flash as well, count the flashes as this indicates a fault code. there will be about a second gap between flashes.
Posted on Nov 07, 2007
My cabrio washing machine want start
start with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Post the results back to me.
Nov 30, 2012 | Washing Machines
Indesit D63 stops mid cycle
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 21, 2008 | Indesit 24 in. D63 Free-standing...
Washer will not start
I know how frustrating it can be when appliances do not function properly.
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc...
If there are no error codes stored, you will need to replace the control board. Here is a link to the part.
Oct 17, 2012 | Whirlpool Washing Machines
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Have Error Code E20 - won't drain. How do I approach?
The diagnostic test is used to check individual component function only. TO START THE TEST: • Turn the Program Knob to the start position, Spin Only. • Press Start/Pause to start the cycle and save it. • Press Cancel to stop the cycle and turn off the LEDs. • Press Cancel again to turn on the LEDs. • Within 5 seconds, press and hold the Options and Start/Pause buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.When the door is opened, the drum light should turn on. 6. Turn the program knob (5) clicks from the start position. The washer will fill and tumble. Once tumbling has started, the Boost Heater (if so equipped) will turn on. 7. Turn the program knob (6) clicks from the start position. The drain pump & door lock solenoid will activate and the washer will operate in high spin. 8. Turn the program knob (7) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting theDiagnosticTestmode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the start position. Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
Dec 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Timer clicks arround and arround
My Belling integrated washing machine will not stop at the end of the cycle. My partner had accidently moved the dial during mid-cycle. We have tried to reset the machine by turning it off and then moving the dial around to the stop section of the dial. However when we turn it back on it waits for a while and then continues to click around with starting any cycle. Can anyone help? Thanks.
Jul 02, 2007 | Belling SGE12X Front Load Washer / Dryer
Washer knob continues to click through cycles
Anything on your machine can cause this. The most common things are brushes in the motor , blocked / damaged pump, or control module. There are too many possibilities to go through, but check pump and motor first
Apr 17, 2007 | Equator EZ 3612 CEE Front Load...
Indesit W 123 Front Load Washer Logo
95 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
