Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
Need wiring diagram for pressure off/on switch 5hp 80 gal 220volt Ingersol rand Air compressor double control 4 wire Montie geving I have the 80 gal tank, 5 hp motor, 2 stage. 3 black wires coming from the motor and 2 black wires coming from a box mounted on the tank. What do i do?
  • ed
    ed May 11, 2010
    clarify a double control 4 wire Montie?? Also is the motor mentioned the stock motor and if not is it a dual capable 110/220v? I ask this because it sounds like you have a 3 phase motor.
  • Samuel Charles Spriggs May 11, 2010
    Could you please clarify this:
    "double control 4 wire"
    I don't see that you have 4 wires either on the motor or on the line.
    What is the box mounted on the tank -- is this just an electrical junction box?
darjr
  • 378 Answers
SOURCE: wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
Posted on Jun 01, 2009
  • 5 Answers
SOURCE: how long should it take to fill up 80 gal tank
10 to 13 minutes from 0 psi to max and auto-shutoff. Tank will be extremely hot, also. Hope this helps!
Posted on Jul 15, 2009
bargainbin2
  • 123 Answers
SOURCE: i just bought a new ingersollrand compressor its a
This is simple it is a 220 volt machine so you would need 2 hot wires one red and one black each one is 110 volts now you have a green wire that in the grown wire and then the white wire with is the neutral wire. So black to black, red to red, green to green and white to white./
Posted on Aug 26, 2009
compman66
  • 169 Answers
SOURCE: i have a ingersoll rand type-30,model#2475 7.5
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Posted on Dec 06, 2009
  • 518 Answers
SOURCE: First stage psv lifting on a model 3000 Ingersol
do you mean the safety release valve ,if its blowing off at a lower pressure it needs dismantling and cleaning the seats
Posted on Jul 05, 2010
Ingersol rand 80 gal 5 hp manual
follow the link
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-877.pdf
Sep 07, 2014 | Ingersoll Rand SS5L5 Ir Electric...
I R Ts4 5hp 80 gal 175 psi 230 volt Air leaking from near pressure switch. Replaced switch but still leaking near 1/4 tubing. Thanks
You have a receiver tank check valve leaking. If you loosen the 1/4 tube slightly and air blows out more and will not stop replace the tank check valve. If you follow the copper line for the compressor HP head back to the tank you will see that the line screws into the check valveand the check valve screws into the tank. Bleed all air from the tank,remove the 1/4 line and the 3/4 line from the check valve. Then unscrew the check valve. Install a new check valve and connect the lines. Problem solved.
Apr 30, 2011 | Ingersoll Rand 2340/2475 Electric Air...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
Wiring diagram for 230v
Single phase motor for 230V, connect T4 and T5, to one line. T2, T3, T8 common connected. T1 to other line. Check Rotation, This should be for CCW rotation facing output shaft. Swap T5 and T8 for CW rotation.
Jan 17, 2011 | Ingersoll Rand TS4N5 Ir Electric...
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Ingersol rand model SS3-E runs but does not build any air pressure. Air just blows out the intake filter.
the back pressure valve has failed it costs about 15.00 and can buy from any truck parts store That's Peterbilt trucks or any large truck stores it's one of two sizes 1/2 inch or 3/4 inch when you pull it off be sure you know which way the air flow is or it will not build up.
Nov 26, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Ingersol T30 won't shut off and blows pressure release valve
the wire juction box on your compressor has a pressure switch that may be wound in to tight take the cover off the box there should be a switch with a machine screw with nut and washer and spring back this nut off and see if that helps if you go to far you just crank it back in until the switch hit although it may be the other way around you may have to tighten to lower the pressure some of them are made that way if this does not solve your problem send me a picture of the switch and can solve it from there
May 18, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Type of oil
Air compressor pumps can use different grades of oil depending on weather conditions and usage, however do not use engine oil. Some Ingersol Rand pumps use a synthetic oil available through WWGrainger on the web. (generally not model specific) If this pump is lightly used you can use the less expensive compressor oil sold at Lowes lumber made by Campbel Hausfeld. It sells for less than $3.00 a bottle. Generally speaking, under normal weather conditions and light duty use, do not worry about the weight of the oil; just make sure that it stays clean and at the right level. If your compressor is running hot, it may be due to other problems like the check valve, head gaskets leaking between cylinders or chambers or high usage. If, however you just want the best oil for your compressor, use the synthetic. It is usually colored blue or green. This oil is special formulation to prevent breakdown in high heat and will not allow carbon for form on parts or inside of the hoses. enjoy
Oct 30, 2008 | Ingersoll Rand Type 30 Reciprocating Air...
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
1,264 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
