Question about Samsung LN-T4065F Television
Won't come on, only clicks
Samsung 46" lcd model #lnt4665f. t.v. does not come on.15 months old. Trys to come on but only clicks. I opened it up and believe I have the board out that holds the part that is bad. I am not sure where to go from here. The (2) fuses look o.k. There is a black part that is soldered to the board thaat is approx. 1 inch by 1/4 inch. I can feel the part click when the t.v. is trying to turn on. Can I take the whole board to someone and have a new part soldered in? Help Gary
  • 927 Answers
Dear Gary,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Samsung pn51 continuously cycles on and off (clicking).
? 4:41
Easy fix for new Samsung TV switching on and off power cycling.... My tv turns on and off by itself the ...
Dec 09, 2015 | Samsung Televison & Video
Over time, my 2007 Samsung LCD TV, model LNT4665F has developed random vertical pixel noise lines scattered throughout the screen. What could be causing this?
This TV is known for powersupply failures and this can be effecting the incoming voltages into the mainboard (AKA tuner board). This would cause the noise. Please have someone look into the powersupply and check that the proper voltages are coming from it. If they check out ok, you need to replace your mainboard.
Please rate if this helped :)
Mar 30, 2011 | Samsung LN-T4665F 46 in. LCD Television
Samsung LCD model LNT4665F went completely blank with no picture. I replaced t-con board today and now the t.v. is bright and greyish, has two vertical gray lines and screen images are colorless and...
It sounds like you did not properly reinsert the ribbon cables, also verify that you do have 12vdc feeding the T-CON board, you may have to clean the contacts on the connectors also.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Dec 30, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LNT4665F, small red dots on LCD screen when powered on
i've seen this several times. the power supply board is starting to fail. next symptom will be it will not turn on. call 1-800-samsung for nearest service center.
Dec 07, 2009 | Televison & Video
Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Have same tv and same problem samsung lnt4665f
We have the same problem with our 46" Samsung LCD Tv LNT-4665F. It's only 2 years old and unfortunately it's out of warranty too. Our tv would not power on and just does this clicking sound. We called to get it serviced and we will need to pay $95 to have somebody comeout and diagnose the problem or we bring it to the shop and pay $50 to diagnose the problem. we've never had any problem with our SONY TVs. we regret buying Samsung!
Jun 08, 2008 | Samsung LN-T4665F 46 in. LCD Television
Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
Unplug for 30 seconds from it's power source and then try it again. If that doesn't work, call Samsung for further troubleshooting and have your model number and serial number handy. Please be prepared to tell them how long the line is.
Mar 30, 2008 | Samsung LN-T4665F 46 in. LCD Television
Televison & Video Logo
580 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
