Question about Pinnacle Systems Studio AV/DV Version 9 Deluxe (202261744) Audio Input
After burning the DVD once,
I make a movie on studio 12 plus. The DVD plays on my computers but does not play on my DVD player which is a Philips Q35
  • Geof May 11, 2010
    They player probably doesn't support DVD-R media, have you been able to play burned dvd's previously?
    President:
  • Pinnacle Master
  • 1,314 Answers
Several possible solutions.
1. If you are using DVD-R discs, your player probably does not support them. There are known compatibility issues with DVD-R discs. If your burner supports it, use DVD+R discs.
2. Try burning at the slowest possible speed. That can help your player pick up the disc better.
3. Did you remember to put a menu in the beginning of your movie? Even if you have the disc set to skip the menu when inserted, it still must exist for some DVD players to recognize it as a disc and play it.
Posted on May 31, 2009
Why Philips dvd player won't play all dvd movies?
This is not a fault. Some movie burned formats might not support the player.
May 23, 2012 | Insignia IS-DVD1001 DVD Recorder/VCR
Do I need a remote control to control the Philips magnavox model DVD 815AT. It plays the commercials on the video disc. When it comes to playing the movie, it keeps repeating itself and it won't go...
Usually most DVD's play movie trailers and sometimes advertisement before the movie will play. Once the ads or trailers are done it should go to the menu screen and at that point "play" or something like that should be underlined. If it is you can press play or select on the DVD player then the movie should start : )
Jul 27, 2011 | Philips DVD815AT DVD Player
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
I burned a dvd in Pinnacle Studio Plus 11. I know stuff burned to the DVD, but it won't play on the computer or in the DVD player. Does Pinnacle not finalize the DVD, could that be why it's not playing? ...
Be sure to check if there is a file written on the DVD disk. Try to install a player like VLC and see if the .VOB file is playing.If not the DVD is not burned properly then try to recheck your settings on the Studio 11 Make Movie
Sep 13, 2010 | Computers & Internet
I just used Windows Movie Maker to convert my .avi movie files from my Nokia onto a DVD. WMM burned the files succesfully and the DVD plays fine on my computer's DVD burner, but WMM is supposed to finalize...
Movie Maker is NOT the software you want for this process :D I tried a few years back as did my friend but it didn't work. Movie maker is ver basic and designed to teach children basic slideshow/video techniques. Try installing the free trial of Corel Video Studio Pro x3, this can make propper dvds, and also makes your files HD.
Aug 26, 2010 | Computers & Internet
Dirty disc message
You might miss match the file associations while burning them as movie dvd (ie if you have the extension like making a movies cd of the file extension like .fly,.mp4,.3gp,etc...) makes a dirty dvd disc in dvd player it can only be readable under the computer in some cases. Try to read it in a system and convert it into .mpeg extension by total video converter available at http://dw.com.com/redir?edId=3&siteId=4&oId=3001-2194_4-10429299&ontId=2194_4&spi=54bb6302e3f8eb192d7c4d5e103edc96&lop=txt&tag=idl2&pid=11366878&mfgId=105109&merId=105109&pguid=Q7DsewoPjGEAAHsRE5EAAAEz&destUrl=http%3A%2F%2Fsoftware-files-l.cnet.com%2Fs%2Fsoftware%2F11%2F36%2F68%2F78%2Ftvc.exe%3Fe%3D1274206388%26h%3D61a08d8270b9777c717edcb3bb514fd4%26lop%3Dlink%26ptype%3D1901%26ontid%3D2194%26siteId%3D4%26edId%3D3%26spi%3D54bb6302e3f8eb192d7c4d5e103edc96%26pid%3D11366878%26psid%3D10429299%26fileName%3Dtvc.exe & burn it again as dvd format. It will now played in most of player.
May 18, 2010 | Pinnacle Studio Plus Version 11
Dvd format to be used
burn a dvd of each of the formats.
Jul 29, 2009 | Acer V193w LCD Monitor
The durabrand 1700
It could be the codec u use to encode the movie,
secondly could be a firm ware problem of your dvd player.
Other than this I can't think of any other reason. or just may be the type of recoreder u use or the recoding programe. If u had check these, then get another player
Sorry, this is all I can think of.
PS. the player firmware is the main reason to me.
Cheers
Rifaa
Nov 18, 2008 | Durabrand PDV-705 Portable DVD Player
Sense error
Every time i try to burn my home from windows to a Philips DVD-RW a message keeps popping up from my laptop saying that i need to place a DVD-RW cd in which i have done . The funny thing is that i edit my movie from my Pinnacle Studio 12 which i got last week, this was my 1st movie i burned well Pinnacle Studio did it for me really, it was so easy when i took the cd out of my hp pavilion laptop it played on my LITEON DVD Recorder & watched my movie clip on my tv, it worked fine but do you think i do this again NO SUCH LUCK i am really new to all this its so frustrating windows wont burn my move pinnacles not burning, what am i doing wrong, i ve got all new dvd-rw cds is there any one out there who can help me please :-(
Oct 05, 2008 | Computers & Internet
A DVD burned with Studio 10.8 plays on our stand alone DVD player, but it won't play on our computer.
check what mode the cd video is you may have to burn another one with the correct mode for pc
Right click program on cd go to properties check video name plus what is after the . ie home.wmv as you need to burn cds with a general code
Try VLC Media Player on computer this plays all my video media
Jul 22, 2008 | Pinnacle Systems Studio AV/DV Version 9...
Pinnacle Systems Studio AV/DV Version 9 Deluxe (202261744) Audio Input Logo
109 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
