Question about Philips 27PT71B 27" TV
My phillips ts2746c221 model
I hear the sound but no pictures, I have fine white line running across the screen and the tv cuts on  then  off
  • Anonymous Nov 28, 2007
    tv had a small block at top of screan where it was fuzzy .then ,i turned it on today and i have a small white bar across screan ,almost like picture shrunk into a single bar. still has sound help...............................
  • dbybdbmb Sep 22, 2008
    When I turn my tv on it has a white screen with lines going through it and it stays on for a quick then turns off. All I hear is sound
  • 24 Answers
If it is a horizontal line is straite or zig zag, if it is straite then problem in your vertical section,please check the supply of vertical section or output ic of vertical, if it is zig zag line then it could be dry solder in the yoke connector or vertical yoke open, please let me know the vertical ic no.
Posted on Jun 25, 2008
Our lcd phillips tv screen turns completely white after about an hour of use
The TV, most probably, the display circuit or the display itself has developed dry solder/components leaking and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Philips Televison & Video
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
32 INCH ZENITH PICTURE IN PICTURE ABOUT 15 YEARS OLD.PICTURE DISAPPEARED AND ONLY HAVE A THIN WHITE LINE RUNNING ACROSS THE SCREEN.THE SOUND STILL WORKS FINE. IS IT WORTHWHILE GETTING IT REPAIRED ??
When CRT TV's show only a white/bright line horizonatlly It is a failure of the flyback Transformer. Not all that costly to repair. Your old TV will probably still be working when all the latest plasmas and rear projections have been laid to rest. Fancy junk TV's dont get any better programs than those old reliable ones
Please rate my help++++Thanks for using FRIXYA
Aug 04, 2010 | Televison & Video
My large screen projector type tv has a picture but there is groups of lined running across the screen from top to bottom. audio fine.
Sounds like hum bars if there white bars.Try disconnecting the ground outside at your cable hookups or sat etc.
Sep 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
BLACK LINES ACROSS THE SCREEN Panasonic PT-47WX51E
Replace c7136 & c7154 on A board This should clear up your problem
Dec 11, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Philips 27PT71B 27" TV Logo
160 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
