Question about GE Profile JGS968 Gas Kitchen Range
No Bake; everything else works
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise temp always read 100 Degress Wooooo. We had this happen for the first time today as well. Broiler and stove top work. Fan also seems to work, but the oven bake/roast modes to not work. The oven just reads 100 degrees. We bought ours summer of 2005. Seems like a common problem with GE after 3-4 years.
    President:
  • 1,136 Answers
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
Posted on May 31, 2009
GE Profile Gas Range, oven doesn't heat up on any
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
Jan 28, 2010 | GE Profile JGS968 Gas Kitchen Range
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
Oct 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Bake does not work but broiler does.
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
The reason that the temp display reverts to 100 degrees is because that is the lowest default temp setting for the display and until the oven temp actually starts to increase, it won't change. So the temp display is working correctly for the BAKE function.
Here's a line drawing showing the part you may need. Ignitor Part # WB13T10045. The good news is that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one. These aren't cheap at $91 bucks, but you can shop around the web for a better price if you determine you need one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGS905SEK1SS&productCategoryId=0124250&brandId=3272&modelName=GAS-RANGE&diagramPageId=00001&componentDescription=GAS%20&%20BURNER%20PARTS&documentId=G6090295&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you out and remember to disconnect the oven from the electric power before performing any repair work. Best regards!
Aug 01, 2009 | GE Profile JGS968 Gas Kitchen Range
GE jgs968 range seems to be working fine except the oven, broiler works fine
Please note that sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking. That's why it's always a good idea to swap ignitors to verify you have a faulty one.
If you want to see what the part is for your oven, go to searspartsdirect.com and enter in your model number to view the line drawing for your oven along with the parts list.
Hope that helps and best regards!
Jun 07, 2009 | GE Profile JGS968 Gas Kitchen Range
Most likely a bad bake igniter wb13t10045 cant guaruntee thats the problem but I'd start there.
Jan 28, 2009 | GE Profile JGS968 Gas Kitchen Range
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
Dec 09, 2007 | GE Profile JGS968 Gas Kitchen Range
GE Profile Spectra JGBP85
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
Jul 15, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JGS968 Gas Kitchen Range Logo
852 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
