Question about Thermador MBYB Microwave Oven
Thermador Microwave shuts off after 34 seconds.
Thermador Microwave MBY stops after 34 seconds no matter what time is entered or the power setting. Tried reset and turning power to the unit off and restarting. Unit is 7 yrs old and worked a couple of hours ago.
SOURCE: Thermador MBY microwave
The problem is the push-on connector on the UPPER door-latch switch; if the white plastic around this connector is brown (burning), the connection is going bad.
Cut the three white wires back about 1 inch and strip; obtain a new push-on and solder the three white wires into it-- a crimp is NOT sufficient for three wires into this little connector (defective design). Also clean the two blade on the switch before reconnecting as the heat has likely left a burnt coating.
Posted on Jun 07, 2008
Master_Tech
  • 770 Answers
SOURCE: microwave turns itself off after a couple of seconds
try to press in on the door after you strat it or down on the door after you start it your interlock switches my be going out
Posted on Jan 24, 2008
SOURCE: Door not latching
One of my friend who can fix almost anything is coming once a year to fix all that is broken and not working. It has become a yearly routine. This works out way more cheaper than trying to fix all these "wonderful" appliances myself!
Posted on Jan 01, 2009
I HAVE A SYLVANIA MIRCOWAVE THAT THE SCREEN SAYS ROAST ALL THE TIME AND I CANT SET THE CLOCK OR ANYTHING.
Posted on Jul 07, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: goes to cooling down and shuts down -Thermador MBY
It sounds like the magnetron is overheating. There can be several causes:
- the vents are blocked
- the outside outlet of the air duct is damaged or has an animal nest in it
- the filters need to be cleaned (if grease filters) or replaced if charcoal filters
- the magnetron is failing
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can possibly download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your favorites.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well as your detailed symptoms.
Posted on Dec 13, 2009
How do I change the power level?
Usually, power level is selectable using the keypad.
Jan 03, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave shuts down after 2 seconds
unplug the appliance from the main socket and plug it after sometime
Jun 07, 2013 | Thermador MCES MCEB Convection Microwave...
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
Microwave shuts down after 3 seconds
you need a new magnetron and inverter board, this is an expensive repair, unit can be replaced with panasonic parts or replaced with same size panasonic unit
Jul 17, 2009 | Thermador MBBS Microwave Oven
Microwave turns itself off after a couple of seconds
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Jan 04, 2009 | Microwave Ovens
Door not latching
Dec 30, 2008 | Thermador MBYB Microwave Oven
Microwave shuts off before time elapes
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
If you prefer, you can find an authorized Panasonic servicer here.
Dec 07, 2008 | Panasonic NN-T990SA Microwave Oven
Mar 10, 2008 | Thermador MBYB Microwave Oven
Jan 22, 2008 | Thermador MBYB Microwave Oven
Thermador MBYB Microwave Oven Logo
493 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
