Xerox copy machine
The letter  '' H '' show up as the machine shuts down after its warm up cycle. Took the lamp out which was green on the end from corrosion but not sure if this is actual problem. It says take to dealer repair.  Thank you, Frank White
MY COPY MACHINE IS XEROX MODEL XC-1255.
DISPLAY SHOWS "H" AND "4" CONTINUOUSLY AND INDIVIDUALLY. PLEASE ANSWER ME. WHAT IS PROBLEM AND HOW TO FIX IT. THANK YOU IN ADVANCE
Posted on Jan 29, 2010
    New Friend:
  • 120 Answers
The lamp is n/g Replace it. Lawrence
Posted on Feb 19, 2008
Xerox 3050 service manual
sir,
i want get solution for my 3050 xerox machine. while taking the copy the background coming black, idon't know the reason, i changed explosure lamp, primary corona end block, tonner, but till the problem is background black, if one copy comes clear another copy will be black. if know the solution kindly pass the message to my cell no.7760191629.
thankyou,
regards,
prabhu
Sep 11, 2010 | Xerox Office Equipment & Supplies
Xerox Phaser 8200 goes through post then hangs.
Sounds like a RAM problem. Go to the back of the machine, You will see  2 large, thumb Screws, Twist them about half a turn and remove the main board. Remove and reinsert the memory stick. If that does not fix it the main board or the electronics module has probably failed.
Mar 03, 2010 | Xerox Phaser 8200 Laser Printer
Black picture the lamp does't lit. no error message.
Hi sir;Try to make a copy with open cover ( check the exposure lamp is on), if exposure lamp not on andyou already replace a new one then check the thermos fuse at the end of the lamp, replace that one.
May 29, 2009 | Canon Office Equipment & Supplies
XEROX WORKCENTRE M20 WHEN POWERING UP MACHINE IT WILL NOT COME OUT OF WARM UP MODE. FUSER IS HOT. MACHINE DISPLAY WILL SAY WARMING UP, MACHINE WILL CYCLE, SCANNER WILL MOVE , PRINTING WILL APPEAR ON...
what you want to do is this, turn the machine off. Remove the back cover. Then on the main board you should see a memory stick or 2 depending on the model.
Remove the memory sticks, then power up the machine with them out. Let it come to ready, then re install the memory sticks and power the machine back up to remove any software corruption.
Apr 08, 2009 | Xerox WorkCentre M20 All-In-One Laser...
Shuts down during warm up
the fuser unit is not warming up, so the machine shut down
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 21, 2009 | Xerox Office Equipment & Supplies
Scanner locked
There is a lock that has been hit and has the scan lamp locked.
Where to look is on the botom of the scanner. Look in where you remove the copies, on the bottom of the scanner you will see the only green part there, it is about 2 inches long and a half inch wide.
Turn the machine off, reach in and push the latch full IN, toward the back of the machine, then pull it our toward you until it snaps into place fully forward, It may be a little tight with it against the lamp carriage, but once you get it latched forward it will return to normal.
That latch is easy to hit when you are removing your copies from the tray.
Dec 22, 2008 | Xerox WorkCentre M15i Laser Printer
Xd 120f xerox
An E7 is related to the scanner. The lamp carriage is gettiing hung up on something or a cable has broken or popped off a pulley. What I have seen most of the times, is the lamp carriage is hitting the sensor that tells the machine the lamp is in the ready position. Biased to the left side of the machine. remove the platen glass and see if you can move the lamp fairly easily. And when movine it back to the left, pay attention if you feel it hitting something.
Also here is the procedure to clear the code.
Performing a Fault Reset 1 01 will reset your Scanner, and allow you to check the Scanner for broken parts as it moves.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [1's] Key to enter 1 in the LED Display, as if you were to make 1 copy.
  5. Press the green [Start] button. '00' will flash in the LED Display.
  6. Press the [1's] Key to enter 01 in the LED Display, as if you were to make 1 copy.
  7. Press the green [Start] button. '01' will be in the LED Display and '100%' will be selected.
  8. Lift the Document Cover.
  9. Press the green [Start] button. The Scanner Bar should move from left to right under the Platen Glass.
  10. Visually check the Scanner Bar as it is moving to make sure it runs all the way across.
  11. Check the Mirror that follows the Scanner Bar to see if it is broken or cracked. NOTE: If you need to see the Scanner Bar and Mirror move again, press the green [Start] button again.
  12. Press the pink [Clear] button four times.
  13. The WorkCentre should now warm up and come to ready.
Oct 13, 2008 | Xerox WorkCentre XD120f Copier
Printer Error Code 15,004.45:9544
One of the halogen lamps that heats the drum has gone bad.
You can tell by shutting the machine off, and easiest if you turn the office or room lights off.
Once you shut the machine down, on the right side cover,( looking from the front its the right) there is a vented area, some rectangular slots where the exhaust fan blows outward. As you power on the machine look into the machine via those slots. In a 1-2 minutes you should see a pretty decent glow inside the machine, IF those lamps are working, I very seriously doubt you will see any light inside the machine. If you don't, you know one or both of the lamps are bad.
They are simply 120 volt , 150 watt halogen lamps, The 4 inch length lamps. They can be purchased at any Lowes, Home Depot etc. If you want to try replacing those yourself let me know and post me your E-mail address and I will send you the directions. Should cost you less than $20 to fix. Xerox will want about $250 to just show up and close to another $300 for the heater assembly which you DO NOT need.
Aug 16, 2008 | Xerox Phaser 8200 Laser Printer
Xerox 8200 will not boot
If it takes a long time to cycle, then shuts down. I suspect the drum heaters are defective.
Best way to find that out is, turn off yout room lights, then turn the machine on.
There is a fan exaust on the right side of the printer where there are sloted openings.
When you turn the machine, look in that fan slot and see if you see lights inside the printer. There should be a candesent type of glow you see about 20 seconds to a minute after you turn on the machine. Leave it on for a couple of minutes, but if you see no lights the heater or heaters are bad. They are standard 120 volt 150 watt halogen lamps. Tricky to change. But it can be done.
Dec 28, 2007 | Xerox 8200/DP Thermal Printer
Wont Warm Up
If it is a 8200 or older, 860,850 etc there are 2 halogen lamps in the drum heater. One or both of those are blown out.
Phaser or Xerox will only sell you a heater assembly.But you can go to any hardware store and pick up 150 watt 120/130 voe halogen short lamps and replace them.
What you want to do is look into the fan openings on the printer when you turn it on, and see if you see lamps glowing.
If you do not, that is the problem, It is very common.
Nov 27, 2007 | Xerox 8200/DP Thermal Printer
198 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
