Question about Kenmore 22422 Top Load Washer
Will not spin water will fill but its not spining i
We check the belt its ok
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    You may want to reexamine the belts ...if one belt gets scorched or overheated, it can affect the tension on the other belt...
    If you start it with the front cover off, and it enters the spin cycle... watch the pulleys and belts..
    President:
  • 1,136 Answers
Hi, Could I get the model # so I can see the exact washer you have?
Does this washer agitate at all? Dose the motor run but no spin?
Please let me know so I can assist you further.
Thanks
Vic
Posted on May 31, 2009
My washer fills with water on starting a load but then it does nothing won't start spining to empty water
If the machine loads ups with water and does not stop then the water level sensor is fautly . But if the inlet valve stops on fill up but there is no spin of the motor or thereafter there is no spin/rinse or drain then the program controller / drain valve/pump must be checked.
Jun 14, 2011 | Washing Machines
My top shelve sprayer arm does not spin
its just clipped over the cap remove and clean also check the seal is not damages on the pipe that goes into case.
Jun 18, 2017 | KitchenAid 24 in. KUDI02IRBS Stainless...
Not spining- water standing can't get water to
If your washer is not spinning ! You first need to drain it. Then underneath your washer you will find your drive system. It will consist of drive belt, drive pulley or pullies and motor. Belt could have come off , if so check the condition before reinstalling, also some times from overloading the belt will spin on the pulley which will make it hot and thanks to the manufacturer the pulley is likely plastic. Parts supply shops best source for belts and possibly pulley though sometimes they want to sale you the whole motor with pulley which you don't need. If so uae internet to find your pulley probably under 10.00 dollars. Hope this helps.
Feb 23, 2010 | Kenmore 23822 Top Load Washer
My ge washer starts spining to drain water then stops
Sounds like the belt is loose. The burning smell is the belt heating up. The motor shuts down because it's heating up from spinning on the belt.
Apr 30, 2009 | Washing Machines
Spin cycles not spinning, does drain water before spin
check the wig-wag.it is the part near the cam bar.has 2 coils on it. also check the yellow wire going to the solenoid it may look ok but could be broke internally.
Nov 04, 2008 | Washing Machines
Kenmore washer won't spin
This should help you get to the coupler between the motor and the trans.
Good Luck
Oct 11, 2008 | Kenmore 24032\24036 Top Load Washer
Washer not spining
i think there is problem in your water outlet pump problem first of all you check water is come out or not from machine
Feb 11, 2008 | GE Profile Prodigy WPSE4200A
My washer wont spin
on the motor there are what you call carbon brushes.. these wear out over time, this then the motor stop spining check and get back to me . cheers doc
Nov 20, 2007 | Zanussi FS1455W Front Load Washer
Machine does Agitate
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Kenmore 22422 Top Load Washer Logo
96 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
