Question about LG Washing Machines
Flashing FE and wont stop filling with water
Lg model washing machine reads fe wont stop filling with water
  • 1,543 Answers
FE means Fill Error, but you already figured that out. If you unplug the machine and it still fills, and the only way to stop the filling is to turn off the valves supplying the water to the fill hose(s), then you need to replace a fill valve. It is best to figure out which one by turning one off at a time while the machine is in that FE condition. There is a separate hot and cold valve. (they are the part that the hose screws onto on the machine.) To replace valve, cover comes off machine by removing two screws at the back of the top. (not the two which go into the top, the ones just below them) Then, standing in front of the machine, use the palms of your hands to give the top a sharp push to the rear to slide the top back about two inches. Then lift the top off.
Posted on May 31, 2009
Have an LG FRONT LOADER WASHING MACHINE THAT IS OVERFILLING
Make sure that you get the correct pressure switch and also check that the rubber hose that comes off the tub onto the pressure switch is completely clean inside. Any gunk that prevents the pressure build up in the tub, when water is being taken on, from going up the pipe to the switch will cause an overflow error FE.
This could also be a faulty water inlet valve, but more likely the switch.
Apr 21, 2015 | LG Washing Machines
FE Code for model WM1812CW LG Washer
Hot water inlet valve most likely needs replacing
May 14, 2017 | LG Washing Machines
When the wash cycle is going it starts to make a tune and then FE starts flashing I need to know what FE means
Hi there Celina the code FE has a few differant meanings depending on the dishwasher model. If you can provide me with the model code I can help you with this problem.
Nov 21, 2011 | LG Dishwashers
I have a LG washer model WM2487 H*M suddendly water started coming out from underneath and also the front panel shows a light saying FE....I read that means something about is due the faulty water...
FE = Fill Error. Not a faulty water valve in your case. (FE codes if it takes too long to fill the machine, but if the water is leaking out, the valve is not the problem, the leak is) If you take the back cover off, you might be able to see where the water is comming from. Possibly the black rubber hose from the tub to the pump has a leak.
Mar 17, 2011 | LG WM2487HWMA Front Load Stacked Washer /...
LG TROMM WM1814CW won't stop filling. Says
Over flow error
Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
Jul 12, 2009 | LG Washing Machines
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
May 19, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Font Load Washer flashing error code FE
FE is Fill Error. If door is closed and washer is plugged in, FE means water is too high and water pump will turn on.
This happens most often when a water fill valve will not shut off completely, allowing water to continue to fill washer, sometimes very slowly. If you shut off one valve (where the hose comes from the household plumbing) at a time you may be able to tell which valve is the culprit. The hot is a single coil valve, the cold is a multi coil valve. Both are the part where the hoses connect onto the machine.
To access valves, remove 3 phillips head screws at the back of the washer holding the top cover in place. Slide the top back about two inches and lift it off.
Oct 12, 2008 | LG WM-2277HW Front Load Washer
FE error?
But does anyone knows what FE means?
Mar 05, 2007 | LG WD-3274RHD Front Load Washer / Dryer
Washing Machines Logo
204 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
