20 inch girl's Huffy Luxe single speed bike. I need help! I have assembled the bike, and I have no idea how to connect the brake wires to the handlebars, or how to calibrate the rear and front ones. The instructions cover multiple bikes, so there are not specific diagrams or step by step details. I'd appreciate the help.
1. the other end of the brake cable with the stopper,insert to the handle brakes.there is a guided slot for it.
2.go to the brake assembly.loosen the nut and find the small hole at the shaft of the flat head bolt.insert the cable.
3. adjust the brake.pull the cable until it is in the best tension,slowly rotate the brake nut to keep the cable in place.
4. try to grip the brakes and try pushing the bike while testing the tires if it skid.try to ride it to so that your weight will be calculated with the brakes.
5. adjust the brakes by repeating the above instruction until desired brake adjustment is achieved.
Pitch for rear axle of bike
