Question about Jensen JHT525 System
The subwoofer JHT525 is only making a BOO loud sound it does not matter if I move de volumen up and down, I would like to know what is the reazon, if it was on for a long time or for what other reasons
I had this problem, too, and ended up throwing away the subwoofer. The reason in my case was the amplifier had a blown resistor. I could clearly see the burn marks and the broken resistor. I could have fixed it, but the subwoofer is 9 years old.
To find this, I unscrewed all of the bigger screws on the back except the two with the "ring" around the screw head. I then unscrewed all of the small screws. The amplifier/controller will come apart. Disconnect the speaker from the amp and then open the amplifier itself. In the "box" you will see a metal bracket, which was where the burnt resistor is.
Hope this helps.
Posted on Jun 14, 2009
Subir volumen en dish
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 27, 2014 | DISH Network Televison & Video
My sub is making a rattling sound. I dont know what it is, and I dont play my movies that loud. I also have the sub power only about 40%, I dont know whats wrong with it
First pick it up and shake it, to see if something is loose inside it!
Sometimes the speaker cone can become damaged. If you can get at it, gently press it so it moves up & down. Don't press it from the side, just apply force all over. It should just move without scraping. If it doesn't the cone is damaged.
Feb 06, 2010 | Polk Audio PSW202 Subwoofer
I have a sub woffer JHT525 that bega humming. I have checked the fuze and did some reconnections but it is still humming. Anu suggestions? Anyone know where I can get a replacement. The model is JHT525
Disconnect everything, and turn it on. If it hums, it needs repair. Then try hooking up one cable at a time. If a connection hums, try another cable. If it hums no matter where you plug it in, try a 2-prong power plug adapter, or a ground-lift plug, as it's called. If nothing works, it may need a repair in its power supply. It would still turn on, but buzz no matter what you connect.
Dec 13, 2009 | Jensen Audio Players & Recorders
Loud hHum from Subwoofer
Sounds like the hum might be mains hum caused by the failure of the power supply capacitor(s) in the sub. It/they will be the largest on the pc board. You will find all the details (needed to replace it) on them. If you find more than one replace both.
Dec 10, 2009 | Audio Players & Recorders
Jensen jht525
See if any electrolytic filter capacitors are blown (bulged at the top), badly soldered or if they have broken contact pins (legs), a loud hum in the audio suggests there is a non rectified (AC) voltage present which could be caused by a bad or badly connected filter capacitor.
There may as well be other reasons for the hum (a bad earth connection,a loosely plugged or badly soldered audio or internal connector, bad rectifier bridge or diodes, as the case may be, bad solder joints on any component, possibly other components that are faulty).
I just suggested some of more common possibilities.
Hope you can fix it.
regards
Triarcuate
Sep 23, 2009 | Audio Players & Recorders
Subwoofer jht525
That's what subwoofers r meant to do.For a proper sound u need to connect the rear,center or surround speakers with the subwoofer.
Subwoofer jht525
Sounds like your connection is bad on the wiring to the Subwoofer. Try rewiring the connection with new wire.
May 31, 2009 | Jensen JHT525 System
No tengo volumen , no puedo escuchar musica....
Yo comprendo un pequito de Espanol, pero nada de Windows en Espanol.
Control Panel, Sounds and Audio Devices, Volume.
Sea seguro; "mute" no se comprueba, y el volumen es máximo
Buena suerte, amigo.
Jul 20, 2008 | Computers & Internet
Intermittent, random, loud popping noises.
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
I lost the installation manual on JHT525.
plug your low input into the subwoofer output of your reciever.that should get the sub working then you have to run speaker wire from your speaker outputs on your reciever into your sub in the top row of inputs then the outputs on the back of sub(the bottom row of speaker hookups go out to your speakers....my email is bsharp76@hotmail.com if you still cant get it i can talk you through it on there or ill give you my instant messenger name is you still have problems good luck,b
Apr 05, 2007 | Jensen JHT525 System
Jensen JHT525 System Logo
276 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
