Question about Pioneer AVH-P5700DVD Car DVD Player
Avh p5700dvd ..Noisy distorted sound from RCA output
When i connect my rca to my amp it makes distorted sound.. When i hook my avh-p5700dvd to my amp rca's i get engine noise. Sounds as if it needs to be ground...but it is! help!?!???
Bad output
Posted on May 31, 2009
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
Can i hook an ipod up through an aux cable that plugs in to the ipod . its the red and white aux cable and it plugs into the earphone place on an ipod
If you are talking about the cable I think you are, all you do is plug the red and white rca into the input of your choice on the back of your radio and the other end into your choice of audio output (anything with that size headphone port).
Sep 19, 2010 | Pioneer AVH-P5700DVD Car DVD Player
How to connect ipod to the Avh-p5700dvd
You should connect the cable to the audio in. You will then need to change input(source) on the radio to auxilary. Good Luck.
May 27, 2010 | Pioneer AVH-P5700DVD Car DVD Player
AVH-P5900DVD noise in RCA
there is diodes that you can change to stop the noice or even a capisitor but not fuses. if you look at the capsitors see if the tops of them are buldging or leaking. that is a sign of them being bad and will need to be replaced. the ones you want to look for will be right were the rca's come into the radio from the back.
Mar 11, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Help i need a wiring diagram for a pioneer avh-p5700dvd to connect to a wiring harness and a tr-7 output module
ftp://extra.abt.com/PDF_Files/avhp5700dvd_installation.pdf
This is the installation manual for the AVH-P5700DVD, including a wiring diagram for the wiring harness.
http://www.pac-audio.com/PACProductData/TR7/1_Instructions/tr-7_instructions_010505.pdf
This is the wiring diagram for the PAC TR-7 UNIVERSAL TRIGGER OUTPUT MODULE VIDEO BYPASS.
Jan 12, 2010 | Pioneer AVH-P5700DVD Car DVD Player
My subwoofers will not play
go into the menu screen on the pioneer unit and go to setting if you have a loud function there turn it on.... if that doesn't activate the amp ...(did you hook up the blue wire from pioneer deck to amp and run it threw the car to the amp)..if no than your pioneer deck does not realize there is an amp present in system....... if yes scroll threw menu till you see audio look for Sub Woofer or Amp you may even have a button on pioneer deck marked SW go press it and turn amp to on this will provide signal from pioneer unit to amp if this doesn't work other thing could be you hooked RCA to AUX input (but if you have a SW for RCA plugs on back of unit make sure the RCA wires are in it) the loud or SW button should activate it (if there is only F and R for RCA plugs on back of unit use R hope this helps)
Mar 04, 2009 | Pioneer AVH-P4900 Car Video Player
This model of Pioneer has a common problem with a couple of fuses that are inside the unit mounted on the main circuit board that will blow. These are surface mounted fuses, and must be replaced with the same type of fuse. They are very small and white colored and require some good soldering skills and the proper soldering equipment do this job properly.
I work at an authorized Pioneer service center and have seen this problem many times. These units are very difficult to open up and work on. It is very easy to damage the ribbon cable that connects the flip out monitor to the main circuit board if not done perfectly.
What you can do as a work around for a short time, until you can get it in for repair, is this shortcut. It will restore your audio, but should not be considered a permanent fix.
At the amplifier (since it is easier to get at than the RCA cords coming out of the back of the Pioneer) you need to connect a jumper wire from the RCA ground on the jack to the power ground on the amplifier. The outer metal part of the RCA jack is the ground, the metal pin in the middle is the positive.
Remember, this is only a short term temporary work around and is not a permanent repair. You just need to supply the RCA output ground with a good ground.
The repair of replacing the surface mounted fuses can cost anywhere from $100 to $160, depending on the service center rates. Just don't wait too long, or play the amplifier too loud in the meantime.
Feb 03, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Do u need the brain to hook up an amp to a Pioneer AVH-P6600DVD Car DVD
Hi. If I remember correctly, you won't be able to even turn the AVH-P6600DVD monitor on with out the brain. But if you need the brain for it. I do have one for sale. Email me at dumbo_ears13@yahoo.com, I will list it on Ebay for you. Thank you.
Jan 21, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Sound Distortion on Mlt1912
The hard way, if you have the skill, is to replace the speakers.  The bad news is that this probable won't fix it as it is likely that it is internal noise causing the distortion.
there is an easy solution that will probable work.  Using the audio output connection you could hook it up to a stereo system or boom box and use those for sound.   the only thing technical is making sute your cord has the right connectors/adapters on each end.  take a picutre or a good look at both devices audio connectors (output on the TV, input on the Stereo/boombox) and the salesman at your local electronics store should be able to help you find just what you need.
at a guess you will likely need an RCA female to RCA female cord or an RCA to stereo mini male.
hope this helps.
Long_Knight
Sep 02, 2008 | Memorex Televison & Video
Video ipod
you have to get an iPod cable that gives you RCA outputs. Just connect the RCA outputs from the iPod to the AUX inputs on the unit. I believe that should do it. Ebay sells the iPod cables, and most electronics stores should as well
Dec 22, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Pioneer AVH-P5700DVD Car DVD Player Logo
360 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
