Question about Acer AL2016W 20" LCD Monitor
Extended monitor wont extend
Up until an hour ago the extended monitor on my Acer laptop worked fine. Laptop, main screen, monitor extended screen. All of a sudden after pulling the monitor cord out as usual, I cannot get the extended monitor to be extended again. When I go to display setting and set the #2 monitor to extended, Acer won't take to it and makes my #2 monitor my main one and the laptop nothing just black. I cannot seem to get an extended monitor of either. I can get duplicate desktops but no extentions. Any answers?
Tony
Can you now see 2 monitor properties i.e. 1 & 2... then identify running monitor ... if it is 1 then select 2 in properties and set it again to be used as extended desktop... open any application and pull or drag it holding it from title bar to the extended desktop....
Posted on May 31, 2009
How do i fix a split screen of my Toshiba c600d-t36b laptop
The quickest way to change the display output settings is to use the
display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order
(the last two options are available if an external monitor is
connected):
? Built-in display only
? Built-in display and external monitor (simultaneously)
? External monitor only
? Built-in display and TV (or other external video device)
? TV (or other external video device)
? External monitor and TV
? Built-in display and external monitor (extended mode)
? Built-in display and TV (extended mode)
? External monitor and TV (extended mode)
? Swap-Switch primary display between internal display
and external monitor when using extended desktop
Feb 12, 2015 | Toshiba Computers & Internet
Dual monitor won't extend, it's clones the screen
Make sure the resolution is set up to split the screen.
Nov 11, 2013 | Acer Aspire 7741Z-4433 PDCW 17.3 Win7...
A few months ago my screen started distorting the picture now and then, and then would revert back to being fine. Now it stays mostly like that. I have it set up as an extended display from my laptop. I...
The resolution for the extended display could be wrong or on a setting the monitor cannot display. When you tell the computer to extend the display their should be a resolution drop down. Change it for the extended display monitor ( Click Advanced Display Settings or you may have to click the second monitor to see the resolution for it)
Jun 01, 2017 | Acer AL1912 19" LCD Monitor
LCD is back lit but no image, just black. It works sometimes and the laptop works fine if it's hooked up to an external monitor.
Sounds like the Screen is on its way out.
If you have the ability to set it up as a dual screen, and use your laptop as the main and your external monitor as the extended screen.
Dec 15, 2010 | Toshiba Satellite M65-S809 Notebook
How do I connect my Acer 5720-4126 to my HDTV (Sony Bravia) to watch tv shows from Hulu etc?
It depends on what connections your TV has, as well as your laptop. I am not familiar with your laptop, so I'll go with generics. Most laptops have a S-video connection, which also is a common TV connection. I would buy at least a 12 foot cord, otherwise you're sitting in front of the TV really not enjoying whatever it is you're putting on the screen. If your laptop has a HDTV connection like the TV has, simply buy a HDTV cord and go from there. One of the more important things is (usually) you have to have the connections made and the TV on before booting the laptop. If you are lucky enough to have a VGA input connection on your TV, you can get a VGA cable (many of the older monitors have a cord with a plug at both ends, simply use one of these) but you still need to have the cord connected as before, before booting. Usually you have to set up your display after the second display is recognized. Go to control panel, display. Or you can get there from right-clicking on the desktop. Either way, then go to settings, then advanced. Hopefully you have Catalyst as one of your tabs there. If not, I would suggest you get some updates as it is a lot easier with the Catalyst control to set up a second display. Once you get to the Catalyst control, you might have to click "detect" or it might be there - you should see a second display below the main display icon. Right click on it, and select either "extend main onto monitor" or "clone". The difference is: Clone makes the new screen match your laptop screen. This is sometimes annoying, especially if you have family or guests watching whatever it is you are putting on the screen. Extend onto main allows you to show only the focus of your presentation. Think of a Powerpoint presentation you have seen - you did not see anything but the focus, meaning the slides. The problem comes when you want to watch something that does not go onto the extended portion of your screen. You can drag some things to the other screen, such as a window with images, but not all things work in an extended window. Depending on how you watch Hulu, you might be better off to use "clone". If you get it to go full screen, clone is definately the way to go.
Plus, if you use "extend main onto monitor", you have to remember to move the screen back when you're done, otherwise the next time you try to use that program or window, it won't show up on your screen. So try clone first, and if that is acceptable, it causes the least problems.
Aug 10, 2010 | Acer Aspire 5720 Notebook
Acer 5920 wont turn on, we bought an extended
This is a common problem with Acers but usually it is the battery and the adapter. Replace the battery as well as the adapter and you shouldn't have any issues. Surges can be the main cause for this or running the laptop hot has also been the culprit.
Apr 02, 2010 | Acer Aspire 5920-6727 Notebook
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
Extended desktop rotated, can't turn back.
Click on the extended monitor which is out of sync with the main monitor and click CTRL + ALT + UP
Thanks,
Vasu
Oct 02, 2008 | Microsoft Windows XP Home Edition
Hooking up a second ACER monitor as an extended desktop
I have 2 acer AL2016W's and have the same problem. The earlier ones with the VGA only are the problem from what I can see, they just don't play nicely with the video card for some reason.
First, on your main monitor, click "Show displays in menu bar" on your monitor control panel. This will let you set the resolution for each monitor from the main one, click on the little monitor icon on the top right screen to do this.
If that doesn't work try this:
Connect one acer as the main monitor and one crappy vga crt monitor as the second.
Set mirrored desktop in the system preferences so that the crappy CRT is displaying the exact same resolution as the acer. (1680x1050 59.9Hz)
Disable mirrored desktop. You should now have an acer and a crappy CRT both running 1680x1050 in extended desktop mode.
Shut down, reconnect the acer in place of the crappy CRT.
This should "trick" your video card into having the right resolution, otherwise you'll just get the stupid "input not supported" screen, with no ability to auto configure or use any of the built in controls.
Nov 20, 2007 | Acer AL2016W 20" LCD Monitor
Nx 5000 dual screen problem
What program are you using for the dual setup? Place a shortcut in startup. usually an external monitor is used in place of the laptop LCD. The Monitor may need to be #1 and the laptop LCD#2 http://www.intel.com/support/graphics/intel852gm/sb/cs-009064.htm?iid=search& This site may help too. Good Luck, Tim
Feb 08, 2007 | HP Compaq nx5000 Notebook
Acer AL2016W 20" LCD Monitor Logo
332 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
