Question about Logitech Z-5500 Computer Speakers
Logitech Z-5500 DON'T POWER ON. HELP!!!
Recently moved around my room, got back to hooking up my Logitech Z-5500, plugged it in, switched on the master switch, and to no avail, the red light around the button no longer lights up. I'm sure it's all plugged in right.
Please help me ! I love these speakers and I'm supposed to be DJ'ing next week.
  • 1 more comment
  • billy101692 May 31, 2009
    I'm sure they're working, because when I unplug the system, and plug back in the house phone base it starts charging. All cables have been reseated.
    It was plugged into a UPS/Surge Protector. It was working before I unplugged it. This is all new.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    reseat the cables and make sure your plugging your power cord into a working outlet. I've made that mistake many times before. If you have it plugged into a surge protector then make sure the surge protector is turned on.
    Sergeant:
    Champion:
  • 255 Answers
Check its power supply if its working, first.check the outlets(electrical sockets)just to be sure of proper fit.
Posted on May 31, 2009
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
Hi, i just recently bought some logitech z-5500 and have tried to hook them to my mac. The problem is that the speakers are far too quiet they all work but they are not giving out 505watts rms. My mac only...
Hey there,
The 3.5mm socket is the only thing you can plug into on a mac for speakers.
Have you checked to make sure that the system volume is turned up? Use the volume buttons on the mac keyboard to turn it up.
Let me know if this does or doesnt work and we'll try something else!
Good luck :)
Mar 08, 2011 | Logitech Z-5500 Computer Speakers
Only the center speaker work well now.
I have the same problem but its all the speakers, move the control pannal around and it should work. If yours is broken like mine call Logitech and they will help you.
Feb 08, 2010 | Logitech Z-5500 Computer Speakers
The right speakers logitech Z 5500 do not work
try buying a new optical cable or change some settings on your tv.
Feb 04, 2010 | Logitech Z-5500 Computer Speakers
Well my 5500 amp has evidently stoppe functioning.
What I would do is look around inside and see if anything is burnt or broken, pay close attention to the heat sink area.
With neither channel working you have something that's common to both channels that is causing the trouble.
You should be able to see any fuse by looking inside, they might be covered up, but should be easy to get to.
Nov 25, 2009 | Adcom GFA-5500 2-Channel Amplifier
Logitech Z-5450 5.1 surround sound speakers - no sound from rear right only
Unfortunately I have the same problem. As an electronic engineer I suspect that the power supply part of the unit is damaged. I opened up the module (don' t try it, its a little bit tricky since there is a type of glue around the silver bezel, after you remove the 4 screws from the front holes) and did some quick static measurements with a multimeter, so far no luck. Since I am still in warranty I will try to replace the item. Hint: protect your electronic equipment with ups or surge protection devices.
May 30, 2009 | Logitech Z-5450 Computer Speakers
No power in Z-5500 logitech speakers
The logitech z 5500 digital is very sensitive to power peaks. One of the most know problems is that the fuse breaks because of these peaks. I´ll show you how to replace the system´s fuse.
First of all, you just need to write down the specification of the system´s fuse. The system´s fuse specifications are printed in the back side of your subwoofer, right next to the subwoofer´s on/off switch. In an european system it says: "T2AH250V (Time Delayed)". If you use another power voltage (120v), it may say something different. Anyway, write it down on a piece of paper and go to an electricity store and ask for a similar fuse (It is very cheap. Not more than 1$)
-The best way to get a similar fuse would be by bringing the broken fuse with yourself to the store-
In the back of your subwoofer, using an screw-driver, un-screw the fuse´s cover and remove the broken fuse. Replace it with the new fuse, attatch it to the cover and screw it back again.
If you turn on your system now, it will probably work fine.
Oct 20, 2008 | Logitech Z-5500 Computer Speakers
Recommendations for computer audio switching
I use the HT-391 in my home office video studio not sold anymore but it handles 3 PCs giving them 140w of power, plus 6" active power sub has excellent bass. The wireless remote can be programmed with Radio Shack 8-in-one LCD Universal Remote.
the HT-3917 is small but don't let the size fool you. It has 100w of power still not bad for small places.
For what you need to control you're better off getting the Z-5500.
Z-5500 Digital made by Logitech has 5.1 Dolby Digital 505w
Supports up to 6 audio inputs devices at the same time. Remote controls everything you want. 5 mini speakers 10" power sub woofer. with wireless remote control. $399
http://www.logitech.com/index.cfm/speakers_audio/home_pc_speakers/devices/224&cl=us,en
HT-3917 - handles 3 audio input devices it has 5.1 Surround Sound 5 mini speakers with wall mount 6" power sub vented port for bass and everything you need to two sources though. Wireless remote control. This can be found at Wal-Mart for $39.99
http://www.lenoxx.com/2005/audiosystems/HT3917.htm
Jul 31, 2008 | Computers & Internet
Operating with/without the control panel
You could try hooking them up to another speaker that has the input connections. I have done this before with several different speakers and daisy chained the connections with several speaker connections and they worked great. I had surround sound all over the room. You might run into a problem with the main speaker that you plug into not being able to push all of the speakers that you have but you might get lucky. Those speakers say that that carry 550 watts.
I recently bought a set of speakers that stated that they push 100 watts. The sub was putting out 50 watts and the others were only putting out 25 each. I hooked up a 100 watt speaker to it and it worked. You might be able to contact logitech to get the other speaker that you need. That set of speakers looks awesome on the site. This is the specs for the other speakers
I think that this is what you wanted to know. If it was not your solution, let me know. I will help you more. I might not be understanding your question correct. I have referred your question to someone on the site that works with logitech.
Jun 09, 2008 | Logitech Z-5500 5.1 Digital Speaker System...
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Logitech Z-5500 Computer Speakers Logo
587 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
