Question about Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 6100 Fuser Error
I need help please. I have a Phaser 6100 with an error message that says Fuser Error Low Temp. I just replaced the fuser because it was giving me this message. Now with the new one I still get the message. How can I fix my printer.
Thanks,
Ashley
  • 4 more comments
  • Anonymous Mar 17, 2014
    error message replace fuser
    error message says to replace fuser and replace belt. Is there a way to reset this?
  • Anonymous Mar 18, 2014
    xerox phaser 3428
  • Anonymous Mar 19, 2014
    Xerox Phaser 3600DN Laser Printer needs a new fuser
  • Anonymous Mar 30, 2014
    printer error fuser temp.
    DISPLAY INDICATES PRINTER ERROR
    FUSER TEMP.
    Novelist:
  • 208 Answers
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
  • 1 more comment
  • Rick Kasper Dec 05, 2007
    You may want to try removing and reseating the fuser. The AC connector sometimes does not line up well on that printer.
    Then go through the steps of resetting it again.
    Try reseating it again , then resetting.
    If that doesnt work then you obviously need a service call.
    1. Firmly push down on the left corner of the replacement fuser to ensure adequate contact to the AC connector and that the fuser drive gears mesh. The boss or alignment pin in that corner should be clearly visible above the base of the fuser.
    1. Secure the rear left screw first. Next secure the opposite corner screw and the remaining 2 screws in any order.
    Note: This sequence is critical for those fusers that do not easily align with the AC connector and drive gear.
    This assures you are not hung up on the drive gear and that you seat the connector firmly.
    Not hard for it to be just slightly off.
  • Rick Kasper Dec 14, 2007
    PROBLEM:
    A "Fuser Error Low Temperature" message is displayed on the control panel even after the Fuser is replaced with a new one.
    Items highlighted in Yellow indicate important updates from the previous service bulletin.
    CAUSE:
    Removing and reseating or, replacing the fuser can result in a misalignment of the AC connection or the deformation of the copper contacts within the Switch AC connector (PL9.22.3) that delivers power from the printer to the Fuser (Fig.1 and Fig.2). This prevents sufficient AC power from reaching the fuser which in turn prevents the heat lamp from reaching its required temperature.
    Printer error fuser temp
    You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
    Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
    You will need to replace the fuser. The heating element or one of the thermistors have failed.
    You can call 1-800-835-6100 to order that, I do not think it is very expensive. If it is in warranty they will just replace it.
    Feb 23, 2010 | Xerox Phaser 3100MFP/S Laser Printer
    Engine fuser low heat error on my xerox phaser 3500
    You may want to look and see if you just have a piece of paper wrapped around the roll, but most likely the heating element has gone bad or one of the thermistors have failed.
    Call 1-800-835-6100 and tell them the model number, and if it is a 120 volt or 220 volt fuser.
    Feb 10, 2010 | Xerox Phaser 3500/DN Laser Printer
    PRINTER XEROX 3100MFPX FUSUR TEMP PROBLEM
    Most likely you have had a fuser failure. It could possibly be the fuser and power supply board.
    If the fuser rolls melted together, I would replace both, if you can remove the fuser and are able to rotate the gear, then just the fuser needs replaced.
    Call 1-800-835-6100. They can take care of what you need.
    Jan 05, 2010 | Xerox Phaser 3100MFP/S Laser Printer
    I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
    please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
    Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
    Xerox Phaser 3100 Printer Error Fuser Temp.
    fuser Temp printer error problem.please give me the solution.
    Sep 14, 2009 | Xerox Phaser 6120/YN Laser Printer
    Xerox Phaser 6100/BD Laser Printer Logo
    3,724 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Philip Hughes
    docukaaf
    Level 1 Expert
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
