Question about Fujitsu Heating & Cooling
The compressor wont go on outside but the inside unit fan is working. it will not get cold.
Our fan is going but not cooling, Operation button keeps blinking. the outside compressor? is not turning on. Can we fix ourselves
    President:
  • 2,559 Answers
This could be caused by so many issues,It would be best to call a Heating and air company for a service call.
Posted on May 31, 2009
Very cold outside. The filter and operation buttons are flashing. We changed the battery in the remote. Lights continue to flash.
defrost outdoor unit, quickest way put unit onto full cooling inside and it will send hot gas to outdoor unit, once unit is clear operate as required the cause of this could be a gas issue fan motor issue.a sensor not sensing correctly and not putting unit in to defrost or infact unit is far to small for area it's serving, set temperature to a manageable temperature not all the way up to the max and see how this goes, if it persists gas charge on unit should be checked to see if there is a leak. And fan should be checked to ensure correct operation.
Jan 01, 2016 | Filter Heating & Cooling
Bought 4 small Gold Star units in 2009. One quit cooling altogether, one blows slightly cool while the longer another stays on the less it cools. One did not cool well when it was new. All filters are in...
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28700000&pkw_=basket&model_id=5520000&NewWindow=1
Download this illustration and then using a good multimeter start basic troubleshooting.
All residential window air conditioners have a cooling system made up of four primary components, a compressor, an evaporator fan, a control or switch, capacitor.When the thermostat is calling for a colder room temperature the compressor is energized. It is normally very quiet. The evaporator is always located on the front of the air conditioner. It also has silver fins. Be sure it is clean. Use a foaming type cleaner and rinse with plain water. Because the evaporator is absorbing heat, it is very cold to the touch. The temperature drop causes any humidity in the air to collect on the evaporator - sometimes called sweat. There is a fan inside the air conditioner that circulates the air for the evaporator and condenser coils. The circulating fan and compressor are running simultaneously. The fan motor has two fan blades attached to it on either end. The fan blade on the inside part of the unit continually draws room air over the evaporator coils, which are cold. The fan blade on the outside part of the unit continually draws fresh outside air over the condenser coils, which are warm. Because the evaporator coils are cold, they cause moisture in the room to collect on them, much like a cup of ice water on a warm, humid day. When the amount of moisture increases, it begins to drip down off of the coils into the bottom pan of the air conditioner.
If the compressor fails to start or the fan you may need to replace the capacitor.
You may need a hard start kit.
Thermostat control The thermostat on a window air conditioner works by sensing the air temperature entering the air conditioner. As the air entering the unit reaches the set temperature it will cause the compressor to turn off. The blower may continue to run depending on the selection chosen on the control panel. Digital thermostats work on a similar principle but display a more precise temperature.
Test for continuity with the multimeter between the two terminals . Warm you should read continuity (contacts closed). If not change it.
Selector switches The air conditioner selector switches allow the user to choose the fan speed. The compressor always runs at the same speed regardless of the settings. If low cool is chosen, for example, the fan runs at a slower speed but the compressor still offers the same cooling capacity. There are other switches to control louver operation and other features on some units.
Jul 23, 2011 | LG Goldstar GWHD5000 wall/window Air...
I have a Rheem heat pump/air handler; it draws 2.9amps with only the fan running, 13amps when the heat pump is running and 38amps with the heat strips on. My question is why the unit draws that many amps...
Sounds like it must be about a 2.5- 3 ton system. The 13amps has to be the compressor draw -normal. and 38 on the strips- normal. 2.9 fan -normal.
You may want to check your wiring to see where the outside unit gets its power. Theres nothing inside that can draw 13 amps. That almost has to be the compressor power wire.
Jan 27, 2011 | Heating & Cooling
I have a Rheem Heat Pump unit. This winter, the outside unit fan at times trips off, but the inside unit keeps running continuously. I woke up one morning & it was 62 in the house. The inside unit ran...
Dear Friend!
Due to very low ambient temp, the fan will not run. Once the pressure build up, it's automatically run for some time and again cut off. But if you keep Heat mode and still tem not raised in your room means the reversable valve not working and hence the compressor and out side fan also will not work. Keep "Heat" mode and temp setting +29 to get better heat. Hope is it helpful?
Dec 10, 2010 | Heating & Cooling
THE FAN IN THE OUTSIDE UNIT IS NOT WORKING. INSIDE UNIT RUNS BUT NO COOL AIR IS COMING OUT OF VENTS. IS THERE A REST BUTTON OLN THE OUTSIDE UNIT?
either the fan has went out or the capisitor for the fan is bad and needs to be replaced.if you have run the outside unit very long without the fan turning you might be replacing the compressor as well as the fan or capisitor.if the fan isnt pulling air through the cond coil outside,the compressor gets very hot very fast,and it locks down(burns up). get it looked at asap before it cost more because of other broken parts caused by the fan not working.
Sep 24, 2010 | Bryant Heating & Cooling
Sometimes, when the inside blower shuts down, the
I was leaning towards a bad contactor. Either sticking sometimes or not making good contact. I would inspect the contactor for pits or burn marks near the contacts. DO SO WITH POWER OFF of course...but, what's the reset button you are referring to?? I'm assuming this is a heat pump, please send model number!!
Jul 06, 2017 | Ruud UAKA060 Air Conditioner
Rheem heat pump,have to keep pushing red reset button for fan
Either the fan motor is going out OR the compressor may need a boost of power from a quick start.
When the compressor gets old, sometimes it requires a little extra power to get it going.
Your unit should be under work warranty if they installed it.
Jan 06, 2010 | Heating & Cooling
AC wont kick on....
The first thing to check is your breaker box. There should be one double breaker for the air handler unit, that's the inside unit, and one double breaker for the compressor, that's the outside unit. Check both breakers. If you're not sure if they've be thrown, click them toward the outside of the breaker box (off position) and then click them toward the inside of the breaker box (on position). If the breakers are on and you still are not getting any A/C take a look at your compressor, (outside unit). If the fan is running at least you're getting power. However, your compressor down inside the unit may not be getting power or it may need to be replaced. The compressor has a start-up cap. If this cap goes bad or the wires from this cap fry or corrode away, this will also keep the compressor from starting but the fan will still run. If the fan is not running it could be caused by a faulty relay inside the compressor cabinet. This relay is supposed to open and close based on a low voltage signal from the thermostat. I believe it's roughly 24 volts. This relay switches on and off the 240 volts for the compressor and the compressor fan. Often this relay goes bad or the wires leading up to it fry. If you?re going to work on the unit yourself make sure all power is shut off. There should be a shutoff switch on the outside wall near the compressor. I?d also shut the breakers off.
Jun 12, 2009 | Honeywell Programmable Thermostat Heater
Compressor shuts down when warm outside
make sure you provide shade for your unit. It may help keeping it cool.
Aug 27, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
224 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
